Question about 2006 - 2008 Dodge Charger Starter Relay Mopar W0133-1792621 Dodge St
Where is The Relay Fuse For The Starter On A 2008 Dodge Charger
    New Friend:
  • 3 Answers
It could be under the steering volume but you should get the number to the relay.is your car starting sometimes and then sometime it won't go....I just locate relay and tap it with screw driver like 5
Posted on Jul 27, 2013
I have 2006 dodge charger Rt. I brought new battery an starter an have alternator rebuilt an my car still wont crank
There should be power o the small terminal of the stater anytime the key is in the crank position. I would start with checking that. If there is no power you will need to trace that circuit back.
That wire gets power from the starter relay and the relay gets power from fuse 20 in the TIPM (underhood fuse box). The starter relay control side starts at the ignition switch. The pink with dark green wire should have power with the key in the crank position. That power goes to fuse #10 in the TIPM. it then goes to the starter relay. the starter relay is grounded by the PCM.
Give that a whirl.
Jan 20, 2016 | 2006 Dodge Charger RT
Where is the starter relay for 2008 5.7 dodge magnum
The relay should be located in the integrated power module, under the hood. My info showed this.
Dec 24, 2015 | Dodge Cars & Trucks
2008 charger...power lock won't lock with switch and alarm won't lock it either
Sounds like a fuse or relay, noticed anything else in the car not working?
Mar 28, 2015 | 2008 Dodge Charger
2008 dodge magnum has a few second delay, sometimes longer or not delay. battery has been checked and it is fine. could it be the starter relay fuse?
More likely it's the solenoid that pushes the motor gear into the flywheel. The solenoid turns on the motor once the gear is meshed to the flywheel. Replace just the solenoid. Don't let any one talk you into a new starter.
May 30, 2014 | Mitsubishi Electric Automotive 2005 - 2008...
Where is the fuse located for the radio of 2008 dodge charger
Radil fuse shoul be in the REAR power distribution fuse block located in trunk under spare tire carpeted panel. The black cover on top of fuse panel should have the fuse listed.
Apr 22, 2014 | 2008 Dodge Charger
Where is the Relay starter on a 2006 dodge magnum
IT SHOULD BE UNDER THE HOOD ON DRIVERS SIDE CALL DELER AN ASK OR GO TO THEM AN ASK FOR A DI GRAM AN PART # IT IS FREE
Nov 26, 2013 | 2006 - 2008 Dodge Charger Starter Relay...
I have a 2008 2.7 V6 Dodge Charger. It hasn't started for 2 weeks now. I've replaced the starter and the starter relay but it still will not turn over. The key unlocks the doors but that's it. The next...
What happens when you try to start it?? Is the secirity ligh blinking?? Might need a new battery in the key is it is an electronic key.
Try putting on the Parking brake then pulling it into nuetral to start it incase the nuetral safety switch is going bad.
Have a spare key you can try???? (come to think of it)
Also, check ALL of the batteries main cable connections as well as the MAIN FUSES (starter has a fuse in that one I believe)
Take the connections loose to check for corrosion and such, make sure the battery is disconnected to prevent sparks and shorts.
Oct 23, 2013 | 2008 Dodge Charger
Starter relay for 2008 dodge charger fuse
It's 25A fuse 8 in the totally integrated power module (TIPM).
Apr 24, 2012 | 2008 Dodge Charger
2006 - 2008 Dodge Charger Starter Relay Mopar W0133-1792621 Dodge St Logo
160 people viewed this question
Top Mopar Performance Vehicle Parts & Accessories Experts
Daniel McAmoil
Level 1 Expert
RAYMONDO1953
unosuave
Are you a Mopar Performance Vehicle Part and Accessory Expert? Answer questions, earn points and help others
