I recently had a new engine installed in my Dodge Durango equipped with a Viper 476v security system. The starter spins then the engine runs then dies in about a second.
Hello Clark,
This sounds like an issue with the immobilizer. Please correct me if I am wrong, but I assume that your ignition key is grey in color. If so there is a RF chip inside your key, that when placed in the ignition reads the code on your key, and then allows the vehicle to start. When an aftermarket DEI remote start is installed there is a unit called a 555U installed as well that contains a spare key inside of it. If you pull your ignition shroud off you will see that there is a circular black cable that has been placed around your ignition switch. Typically this can come loose and slide out of place over years of movement. Try using a zip tie to tighten it back in place, and thy to start the car via the remote again. If this does not work, then there is a problem with the 555U, it may have lost power, or went bad. Again this is only with a gray manufacture key, not a black manufacture key.
SOURCE: No install instructions
email me at [email protected] and i will give them to you. i 've been doing install professionally for 10 yrs and have access to directechs (DEI technician website)
SOURCE: battery died in the remote and now car remote wont unlock security
try another battery. maybe that one is bad also. contact the security system manufacturer or a viper dealer. They will help You.
SOURCE: Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
SOURCE: my viper remote starter cranks engine but car
Did you connect the tach wire of the unit to your car? if not you need to refer to your documentation to turn on or off the tachless operation for the unit to work correctly.
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Testimonial: "One word,AWSOME!"
