Question about Viper Vehicle Parts & Accessories
Turns over but won't start
Engine spins, starts, then engine quits. It's a new engine and battery was disconnected for the engine change. Now the remote start isn't working
  • 133 Answers
Do you have any obd2 code scanner to check the engine system. Make sure it don't get fault codes.
Posted on Aug 02, 2013
SOURCE: Lost key and alarm remote
first of all always take car of keys and locks of any of your belongings.. as it is very important..
i think you just go through the following link u ll get the answer
<a href="http://www.soundandalarm.com/car-alarms.asp">car alarm installation</a>
Posted on Feb 24, 2009
RAIN3R
  • 5 Answers
SOURCE: changed batter remote start not working
Hello, What has happened is your remote has lost its programming.. Just like with most electronics, when something is reset or powered off, or even when the battery dies ....the programming software is lost. The remote has to be reprogramed either by a dealer (suggested) or by an aftermarket outsource..Hope this helps...This could help with almost all remotes.
Posted on Nov 22, 2008
  • 34 Answers
SOURCE: Python 1400XP remote start system
yes you are correct the learn procedure is done by a dei 555L or a 555G bypass module.your car should have one or the other installed on it. simply unplug it,it will be a three wire plug. then plug it back in and then by turning the ignition on and off it will relearn the code.
Posted on Jan 09, 2009
  • 33 Answers
SOURCE: battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Posted on Oct 23, 2009
604Autosound
  • 162 Answers
SOURCE: I have the viper 5301
You should take it to a quality reliable car stereo shop and have them check over the unit and the installation.
Most likely it is the tach lead, or the tach learning on the unit.
Posted on Feb 05, 2011
Craftsman silver won't start
ground the spark plug to the engine block it should spark. sounds like you need to check the valves and push rods
Jul 04, 2017 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My1998 explorer just quit it won't start i got new
The 98 explorer is equipped with a power surge system to protect internal vehicle wiring, what this means is that if there is a short in the vehicles wiring the alternator will disengage. A way to tell if it is faulty wiring is to pull all the fuses out of the fuse block and try to start it if the engine turns over the problem is internal wiring. If not then you have to put all the fuses back.
Jan 31, 2013 | Cars & Trucks
Engine won't start and instrument cluster don't work at all
either a ground wire is disconnected somewhere or timing belt broke,does the engine still turn over but not start or do you not have any power at all ?
Jan 16, 2013 | 2003 GMC Yukon XL
Disconnected battery and now won't start
Won't start as in no rotation of the starter motor and no clicking sound? Or starter turns slowly with the engine? Or the starter and engines turns normally but will not start? Or starter turns normally but engine will not turn?
Oct 15, 2012 | 2004 Jeep Grand Cherokee
2001 dodge 5.9 cummins quit going down the road check engine light came on it cranks over but won't start
sounds like a injector pump to me had a 99 dodge cummins went through three of them in 350000 miles done just like you are describing.
Aug 21, 2012 | Cars & Trucks
I changed the oil in my 98 concorde and now it wont start. The oil light is on but not the check engine light.\
do you here the fuel pump working when you turn the key?If not could be a fuse that runs the fuel pump.
Aug 05, 2012 | 1998 Chrysler Concorde
My Husqvarna YTH2348 tractor won't start. Nothing
It could be a couple of different things. A couple of things that you can check yourself before having to take it to someone to look at it:
1. Open the hood and try turning the engine by spinning the round "cheese grater" looking part that is attached to the flywheel. - it probably won't turn.
2. Remove the spark plug(s) and try again. (Be careful, if the the cylinder is full of gas/oil it will come out as you spin it by hand.) - DO NOT use the electric start to try and turn it over! This sends spark to the plug wire and could ignite any fuel causing severe burns and/or other serious injuries.
-IF-
You were unable to spin the engine over by hand without the spark plug(s) in it, then you may be dealing with anything from a wedged starter gear to a seized engine. Fuel with ethanol added to it attacks the rubber/neoprene seals in carburetors and often times allows fuel to fill the crankcase and cylinder. If this has happened the above mentioned plan of action will let you know. As always, anytime the fuel mixes with the engine oil, you should change the oil to prevent the engine from locking up under normal operation.
I hope this gives you a little bit direction. =)
Dec 23, 2011 | Husqvarna Garden
The starter won't completely turn over even though
Sometimes on the Briggs and Kohler engines, the compression release fails to operate at the proper time or is malfunctioning. A remedy for this is to remove the valve cover(s) and adjust the OH valves per the manufacturers specifications. This enables much easier starting, produces less wear and tear on the starter and may allow your new battery to completely turn that engine over. Out of adjustment valves mimic a weak or failing battery quite well and the engine hangs up on the compression stroke because the compression release system is not working properly. Adjust those darn valves.
May 15, 2011 | Toro Titan ZX5450 (54") 25HP Zero Turning...
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
