Question about Sanyo Heating & Cooling
Sanyo kms0912 After running for a short time, the unit leaks water. Is this a fixable problem? Please advise.
3 Suggested Answers
  • 674 Answers
SOURCE: SANYO SPLIT TYPE AIR CONDITIONER LEAKING
The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
Posted on May 04, 2010
jumptrout51
  • 3361 Answers
SOURCE: unit leak at high pressure
Sorry about your problems.
The StopLeak is expensive and does not work on leaks larger than 8 ounces per year.
Neither of these "technicians" confirmed the location of the leak and repaired it.
When the vacuum was done on the system a leak would have been obvious after the first tech replaced a valve.
If they did not see a rise in pressure,they are incompetent.
I apologize for not having an answer for you,but,without being there and checking your system,I do not know what your specific problem is.
Posted on Aug 16, 2010
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Why is insinkerator badger plus 5 leaking from the bottom?
Check hose and connection from the dishwasher to the unit. Look for cracks and proper installation.
Apr 22, 2012 | Electrical Supplies
Aprilaire 600 was leaking water from bottom of unit...subsequently filter pad replaced and all parts cleaned of residue; drain tube cleaned and is draining...The problem is that water is still dripping...
Sorry to read about your problem, I hope this helps you out.
you must have a defective water inlet valve, and its letting water in, just a little.. it maybe dirt in the valve, clogging it.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Aprilaire 600 Humidifier
Water is leaking from the motor?
If water is leaking out of the motor then the disposal unit is no good... it is fixable, but will cost more to fix then to replace it...
heatman101
Aug 26, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
May 04, 2010 | Sanyo Split System Air Conditioner
Retrofit newer Sanyo split AC system where old is installed
absolutly if you change refrigerants witch you prob would have to you may have to flush the linesets to cleen all the oil out but you should have no problems
Apr 08, 2010 | Sanyo Split System Air Conditioner
Sanyo split high pressure side tube icing
ok, on these units, if by high side line you mean the small tube going from outside to inside, that tube is actually on the low side, the metering device is in the outdoor unit. If you shut the unit down, let everything thaw then restart and find that small tube is freezing up right at the outdoor unit right away, my guess is its low on charge. I see that you put some in, make sure it is the right knid of refrigerant. they do not hold alot. Where is your suction pressure running. If you put 2 to 3 pounds with no change, you may have overcharged but that is telling you that there is a restriction in the line inside the outdoor unit, probably the filter if it has one, or the metering device itself. Let me know what you find.
Jun 16, 2009 | Sanyo Split System Air Conditioner
Punctured freezer
You should contact a local welding shop to fix the leak. The tubing is made from aluminum and can be hard to solder for someone who doesn't do it all the time. After that you need an appliance repairman to pit more freon in it. I guess the question is...how old is your freezer? More than 6 years old? Anything older than that, you may just want to get a new one.
Mar 20, 2008 | Sanyo SR-2410 Compact Refrigerator
36" Sanyo Tv
My television has wavy lines running from corner to corner it is due to power supply fileration is not proper. this might be due to your main filter capacitor.please take the help of tech person. Is this fixable or time for new one. it is fixable & not a major problem. no need to buy new one. good luck.
Oct 07, 2007 | Sanyo DS27224 TV
Heating & Cooling Logo
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
