Question about Remington F5790
How fit new cutters - Remington F5790
  • Remington Master
  • 1,602 Answers
See instructions at link below
http://shaveroutlet.com/media/catalog/product/cache/1/image/640x480/dadea5f42f6055071f0acad1550113cd/f/i/file_34_10.jpg
Posted on Aug 07, 2013
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
I have a 2006 impala LT & I don't know how to get
Disconnect the tie rod and it should come off. Is this the type which has a metal band clamp holding it in place? Cut the band. New part should come with new clamp band which (wait for it...) requires a special tool to install, but can often be fitted by careful use of dull side cutters or bull nose cutters.
Oct 13, 2014 | 2006 Chevrolet Impala
My chainsaw has started to cut on an angle could the bar be up for renewal
The most likly cause is that you have sharpened the cutters shorter on one side than the other, all the cutters must be the same lenght, if this has been going on for some time it will wear the guide bar rail on one side and make it even worse, remove the bar and dress the rails with a file, get both sides as level as you can, now re sharpen the chain to get all the cutters the same lenght, or fit a new chain
Jan 24, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
This is an inquiry about Waring food processor model FP510; SN# 11FP10. I need a new driver (the thing with a hex head that fits over the axle or drive shaft (one side of the axle is flat) of the electric...
I broke mine too, but luckily I found an extra machine at a thrift store. The driver was missing (of course), but I cut the blades off (hacksaw, easy) and used the resulting shaft as a driver. It works well: better and tougher than the original! Though they are expensive, you can order a new set of blades and do the same thing with the blades you have now. -Paul
Dec 13, 2010 | Waring FPC15 10 Cups Food Processor
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 | Garden
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
I was cleaning my bobbin case and the cutter and blade came off. Can you send me a picture so I can put it back together?
I don't think I have a picture but let me see if I can describe it to you.
The metal cutter has a black plastic piece. The blade fits in the black plastic with the longest point on top. The black plastic piece slides back onto the metal cutter, riding on the ridge. Fit the metal cutter back on the unit, being sure to align the "stubs" in the holes of the black pieces attached to the cog wheel. Make sure the "stub" of the black plastic piece with the blade fits in the parallel groove so that only the metal piece moves out and brings the thread to the blade when the cutter is activiated.
If you are still unable to fix, make a comment back and I'll go take pictures of my machine's cutter system.
Good luck.
Sep 03, 2009 | Husqvarna Viking 1
My cutters don't lock on to the pipe when tighting down on pipe wheeler #90750 they seemed stripped is there anything other than buy new one some kind of replacement kit for the quick realese anything
I am not sure what brand that is but I have been plumbing for over 20 years and still use the origanal set of cutters I started with. They have been rebuilt many time so parts should not be hard to get.
Apr 23, 2009 | Plumbing
Need thingy that replacement heads & cutter fits into
Remington R 950 replacement heads is Remington SP 19 titanium MicroFlex replacement heads and cutters.
Jan 11, 2009 | Remington Titanium Microflex R-950...
Remington F5790 Logo
48 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
SHARCNET-USA
SHARCNET-USA
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
