Question about Refrigerators
Amana DRS2660BW - freezer not cooling - frost on intake wires/pipes
The freezer doors did not close properly when it was overstuffed. As a result the freezer no longer freezes. I removed the back panel and saw frost on the intake pipes/wires but the coils are not cold. See pictures: https://www.dropbox.com/s/9gbliydav0rp48c/20130726_080015.jpg and https://www.dropbox.com/s/o9w49i8bjbq7yg8/20130724_205912.jpg . Lights come on and fan blows. Already tired unplugging and turning freezer setting to off, but no luck.
    Sergeant:
  • 352 Answers
EXCESS HEAT IN A FREEZER WILL CAUSE COMPONENT "ICING"
1. REMOVE EVERYTHING FROM FREEZER
2. MAKE SURE ALL VENTS ARE CLEAR OF DEBRIS AND NOT BLOCKED
3. LET FREEZER COMPLETELY DEFROST...CLEAN OUT COMPLETELY ..RE INSERT FOOD AWAY FROM FANS, VENTS ETC..
4. FIX DOOR SEAL, AND DO NOT OVER FILL
Posted on Jul 26, 2013
catriver
  • 878 Answers
SOURCE: Freezer works fine refridgerator does not
anan, I think your display is giving you a code on these LG. See if you can find the tech sheet behind the toe panel. On your display panel from memory, 3 led's lit from the left means a failed defrost thermistor. This could be the reason you are frosting up and restricting the air flow. There is a main board in back that you can ohm out the thermistors. Connector 4, the two bright orange wires #5 and 6, should ohm at 19K ohms at 50 degrees. Now Im doing this from memory, if you can find your tech sheet, it will give you precise information. Catriver.
Posted on Jun 14, 2007
Techsim
  • 59 Answers
SOURCE: Amana SxS fridge not cooling or freezing
You have a sealed system problem. There is either a small leak or a restriction somewhere in the tubing. This isn't something you could've caused so don't worry about that. Unfortunately this isn't something you can fix yourself either. You require a certified refrigeration technician to fix this problem.
Posted on Nov 03, 2008
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
  • 272 Answers
SOURCE: freezer frosting over vents, refrigerator not cold enough
Greetings,
i work on this for a living 33 years..sight unseen, I'd say the evaporator is froze over. Its missed its defrost..I suggest leave freezer door open and unplug for 24 hours to melt ice..There still will be a problem and this will continue, but this gives you temporary service. You;ll need a repair-person to fix it. The evaporator frrezes over blocking airflow to fresh -food section. This in turn can cause a fresh food and freezer failure..
Bruce Denton appliance tech 33 years...
Posted on Jul 05, 2009
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
How to test Damper control in Amana DRS2660bw MFG No PDRS2660bwo S/N 10650033CT
the control damper does not control the freezer temperature call a repair man as it possibly needs freon added
Jan 22, 2017 | Amana Refrigerators
Freezer foods thawed, still cold
then the thermostat must have gone bad.
did u replace it?
Jun 19, 2008 | Amana ABB1927DE Bottom Freezer...
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
Frigidaire S XS wont' cool freezer or fridge. Condesor fan is moving, coils are clear and frost on back of freezer door. how do i determine what is going wrong?
Frost on back of door. Does it have a dispenser? Check to see that ice chute door is closing. If it is then door must not be getting closed properly or has a bad seal. If enough outside air gets in it will frost the evaporator up causing a reduction in airflow and loss of cooling.
Oct 20, 2014 | Refrigerators
Amana bottom freezer unit warms, then resets after being left unplugged
If the door does not shut correctly, humidity enters the unit and condenses inside. The defrost function is not designed to work properly under such a condition.
Ice (frost) builds up around the cooling coils, and actually insulates them, so you don't get good cooling. When you unplug the unit, the frost melts, runs into the bottom tray beneath the unit (can't see it).
When you turn it back on it cools like it should until the frost builds up again. You need a good gasket and a door that is adjusted properly. You also need the unit level at least side to side, but front to back also is preferable.
The unit has front leveling feet, and the back usually adjusts itself with self-leveling feet. The adjustments for the door are metal bars inside it, behind the inside storage panel.
The hinges are also adjustable. Sometimes the door sags from heavy things stored inside it. You must loosen the hinges a bit, lift the door and hold it while you tighten the hinges.
Sometimes the unit can be unsalvagable, because it's been situated incorrectly for so long that it's permanently bent out of square.
OR, the defroster clock might be bad.
Jan 20, 2014 | Refrigerators
Refrigerator on my side by side Amana not cooling
check to see if you have a the fan running in the freezer, if not replace fan. if fan is running do you frost on the back wall of freezer, if so defrost by opening door for 3 to 4 hrs. turn back on and if frost returns in 3 to 4 days call for service
Jan 07, 2012 | Amana Refrigerators
Refrigerator not getting cold
A refrigerator not cold enough is a hassle, because you are at risk of spoiling the foods you store in there. Most often, this problem is caused by something easy to fix.
1. Faulty Door Gaskets
The door gaskets in a refrigerator ensure a sealed closure every time you shut the door. Torn or loose gaskets on the door of the refrigerator can result in a leak in the cold air. As a result, the refrigerator is warmer. Repetitive and frequent opening and closing of the refrigerator is also a possible cause, because the warm air from outside replaces the cold air in the refrigerator every time you open it.
2. Dirty Condenser Coils
Dirty condenser coils can result in improper functioning of the refrigerator. These coils are located on the back or the underside of refrigerators. If you find this to be the cause of the problem, unplug the refrigerator before you attempt any cleaning.
3. Frost-free Feature not Working
If the frost-free feature fails, it causes a buildup of frost around the evaporator coils in the freezer. This causes a malfunctioning of the evaporator fan that blows cold air around. The fan can also be damaged if it hits the frost.
4. Faulty or Incorrect Temperature Control
A faulty thermostat can lead to a refrigerator that is not maintaining the desired coldness. Check for this problem and also ensure that the temperature is set to the correct level. Normally, refrigerators are set to a temperature of about 0°C, whereas the freezer sections are around -17°C.
5. Inadequate Air Flow inside Refrigerator
A refrigerator that is loaded with too many food items can fail to maintain an adequate level of coolness across all the items kept in it. The surface items tend to be colder, and the items underneath do not become as cold. A refrigerator that has very few items in it can also fail to function efficiently. Try to ensure that your refrigerator has enough food in it at all times, but is not so loaded that the air flow gets constricted.
6. Vents between Freezer and Refrigerator Clogged
The vents between the freezer and refrigerating section blow cold air from the freezer across to the refrigerator. If these vents are clogged with ice, the air is blocked and the refrigerator does not cool down. If this is the case, you can unplug the refrigerator, wait for the ice to melt and then connect it back to the power supply.
7. Faulty Door Switch
The door switch is found on the bottom of refrigerator doors. It turns off the light in the refrigerator and resumes cooling action when you close the door. If this switch is not functioning properly, the refrigerator will not be cold and it will also be affected by the heat of the interior light.
8. Refrigerant Leak
A refrigerant leak is very unlikely. This problem can cause malfunctioning of your refrigerator. If you suspect this to be the cause, contact a service technician.
I hope this will help in solving thee problem...
Jun 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
May 31, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
