Question about Gateway FX4710-UB003A Core 2 Quad Q9300 6GB DDR2 640GB NVIDIA GeForce 9800 GT Windows Vista... PC Desktop
CPU will not recognize the last memory slot in my FX4710
I upgraded my memory and discovered the computer is not recognizing the last memory slot. I have three 2G sticks in the first three slots for 6G but no matter what stick (1 or 2G) in the fourth slot is still only recognizes 6G. I have already reset all the cards several times and checked the BIOS and Windows 7 on startup.
  • Gateway Master
  • 27,725 Answers
RAM, or random access memory, is the physical memory on the computer but only holds data while the computer is on.
The benefit of adding more RAM is that it generally makes your computer faster.
Almost all new computers recognize your RAM after you install it and restart the computer, but if yours doesn't there are a few simple things to do to get the memory recognized.
Check the type of memory you have.
Computer motherboards will work only with the type of memory they are designed for regardless if the memory fits or not.
There will be either a sticker on the memory or a listing on the packaging giving the memory type and speed.
Check the computer's or motherboard's manual for the type of memory that is compatible.
Install the memory and make sure it is tight, otherwise it may not get recognized.
The memory fits into slots on the computer's motherboard.
There are tabs on the side of the memory slots to release it.
Release the memory if it is installed and put it back in by pushing it down straight into the slot until it clicks.
Restart the computer and hit the appropriate key to enter the BIOS.
The key will be listed on the screen.
Go through the menu choices by using the arrow keys.
Look for the memory listing under hardware.
Make sure all memory listings are not listed as disabled.
If so, change them to enabled.
Choose anything listed similar to "Auto detect."
Exit the BIOS and restart the computer.
Posted on Jul 27, 2013
melnavz
  • 1226 Answers
SOURCE: gateway sb-4100-b won't recognize new memory
REmove all the old memory and replace it by a new memory, you should test memory 1 by 1 .
first install the 1 memory in the first slot. then boot the computer using only 512mb. if this successful. shutdown and insert the second memory, then test again.
note: memory should be:
1. DDR SDRAM
2. the two 512 should be the same brand.
Posted on Dec 28, 2007
vincebeach
  • 37 Answers
SOURCE: Ram memory
I recently upgraded the memory in a Gateway desktop with a similar configuration as your. If you only had two of the four memory slots filled before you attempted to upgrade, those two originally used slots must be filled first before you add memory to either one or both of the other two slots. As far as the maximum amount of memory that can be used in each slot, I would need more specific information on your computer. My suggestion at this point is that you either refer to your manual if you have one, or if you do not have a manual, you can access this information online. I was just on Gateway's web site but for your specific information on memory upgrade I would need either a more accurate model number or, what would be best is the serial number of your machine. You seem to be fairly knowledgeable about computers so the easiest would be for you to access Gateway's web site. Once you are on their site go to "support", then go to "my support". You will be prompted to enter your serial number at this time. This page should give you all the information that you need. Listed there should be the maximum amount of memory for the system and also the maximum amount of memory per slot. For example, if the maximum memory of the system is 4 GB, the maximum per slot would be 1 GB. The easiest for you, and what I did on my recent upgrade, would be to leave the existing two pieces of 256 MB in their original slots and purchase two more, 1 Gigabyte pieces and use those in the previously unused slots. You would be under the maximum that you could use in your system but adding 2 GB will improve the performance a great deal and you would not waste the memory that was originally installed.
Posted on Sep 29, 2008
jmassengill
  • 345 Answers
SOURCE: my computer does not recognize
Drop a factory made music CD into the drive while the computer is on. Most CD Readers have a small headphone jack on the front face of the drive. After you drop a music CD in the CD reader plug in a set of headphones in the headphone jack (if your CD reader has one, some of the newer one don't have this feature) and see if you hear music. A CD reader will play a music CD with out you doing anything to your computer or the CD reader. If you do hear music the CD reader is most likely good and it will be a problem with a driver or a physical connection to the computer (physical connection = data cable going to the CD reader isn't pushed in all the way in the connector on either the CD reader or the motherboard).
Posted on Nov 09, 2008
leecom72
  • 4806 Answers
SOURCE: RAM Recognition 835GM PC Desktop
the memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
Posted on Nov 15, 2008
  • 18 Answers
SOURCE: Attempted to install NVidia 9800t on my Gateway
Do you have another monitor or TV with dvi/hdmi? Try to see if that works. And it seems like you changed the graphics output while in Windows. Try turning it off, swapping the cable and turn on again.
Posted on Dec 30, 2010
PC won;t boot after memory upgrade
your comp can only handle so much ram,you also need to use the same ram,check how much ram it recognizes with only two,then 3,then 4,64 bit comps only recognize 4 gb,32 bit recognizes any gb ram.
May 22, 2015 | Computers & Internet
Memory Upgrade Not Recognized
bad sign if the memory slot is damaged then there is probably with the motherboard then in saying that try getting 2gb of memory and insert it in to the original slot where you had the original 1 gb
Jun 18, 2012 | Dell Inspiron B130 Notebook
I have upgraded my laptop's ram from 1GB to 2GB recently, but my computer is only recognizing 1GB. When I run a diagnostic program (like the one from Crucial.com) it says that I only have one ram slot...
Well, there is probably a BIOS switch or a physical DIP switch on the motherboard to fix this problem. I'm not sure which. But, if you contact the manufacturer, they have information on what memory is recommended for your computer memory upgrade.
I wish you luck on this one.
Jul 10, 2010 | Sony VAIO VGN-N250E/B Notebook
Memory upgrade not recognized
your motherboard does support 4gigs of ram but its not supporting may be because your other slot is defective try interchanging the memory i.e; remove one of the ram and run your pc then put the ram on other slot. this will verify if the slot is working or not.
If this information helped you then please vote for it and thanks for using fixya
Apr 23, 2010 | HP TouchSmart IQ770 PC Desktop
When upgrading from one 256 K memory module to two 512 modules how do you get the second slot to recognize the second 512 module?
I am sure when you say 256k you mean 256 mb? You should not have to do anything for the computer to recognize it. Almost all computers are set up to automatically recognize memory. When installed and you right click on my computer and select properties how much ram does it say is installed? If it is just shy of 1GB or if says something like 985MB then that would be normal. If it only says 512 or 469MB then you have a problem with the second memory bank.
Oct 28, 2009 | Acer Aspire 3000 Notebook
My panasonic toughbook cf 28 memory issue
i'm not sure what your configuration was in the computer before you tried installing the extra memory, but here's some common problems i see.
-it might exceed the maximum amount of memory that can be recognized in each slot or total for the computer
-it might have be installed in matching pairs (if it is a 2 memory slot machine which most are).
-it might not take that exact speed/rating
hope that helps
Jan 16, 2009 | Panasonic Toughbook 28 Notebook
Problem with upgrading processor
Sounds like the processor you're trying to upgrade to isn't the same frequency. The processor, motherboard, and memory have a matched frequency. For example; a motherboard with a frequency of say PC4200 will only accept a processor and memory of a PC4200 frequency. If you try to use PC5300 memory it basically won't do anything, blank screen, or maybe a beep. The same if you tried to use a processor with PC5300 on the PC4200 board. The best way to find the frequency rating is to look on the memory. They class the memory by frequency, but rarely ever list the frequency for the board or processor. Research the new processor to find out the memory class and then see if it matches the memory in your machine. If it doesn't then the processor won't work. If it does, then new processor may not be compatible, and that means more research.
Jul 18, 2008 | Shuttle AV42 Motherboard
Hp 530 notebook cpu upgrade
It's not posible to upgrade to a dual core, the motherboard is a different design. Keep in mind that the processor, motherboard and memory have a matched frequency. If the processor doesn't match the board then it won't recognize it. Since the board does recognize the T2300, it may be that you need to match the memory in order to get it to boot. Match the memory by going to patriotmem.com and entering the model that the T2300 came from, it will tell you the memory frequency. If the memory matches the processor simply will not work with that board.
Jun 25, 2008 | HP 530 Notebook PC
Memory Recognition
The BIOS recognizes the same speed chip. Say, "PNY 512mb 333mhz 12ns". If you mix and mismatch, the BIOS won't see it even though your motherboard will take the differant type chips. They should all be the same.
Jul 10, 2007 | MSI MS-6547 Motherboard
Gateway FX4710-UB003A Core 2 Quad Q9300 6GB DDR2 640GB NVIDIA GeForce 9800 GT Windows Vista... PC Desktop Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
