I have a vtech v.smile and it turns on but only does the intro and doesnt pick up my games i also tryed the hold on to the on botton for 45 sec but nothing and it does not have a restart botton
I have tryed turning it on and off but I only get the intro and repeats over and over again and it never gets to my game what should I do
    New Friend:
  • 11 Answers
PROBLEM SOLUTION
u may problem
1. Plz check power supply section (SMPS)
2. start button is damage or only it power supply section of Main board and wire is damage.
if u this all step is already done. u have another solution that,
i.open your CPU cabinet cover.
ii. pull up start button power jack from main board and separate them.
iii. and shot the power pin in main board (where from u pull up the jack) using screw driver or other tools.
I home your problem is recover.
Posted on Jul 27, 2013
  • Robin
    Robin Jul 30, 2013
    Thanks it worked out thanks so much
  • 238 Answers
SOURCE: Error Maplestory
hi,first during power on hit f8 and boot in safe mode...then click on start...all programs.... accessorries......system tools..........then click on system restore.....click on restore to previous date.... click next and select some earlier date when it worked fine and follow... u will bw good to go...
let me know...
Posted on May 26, 2008
  • 99 Answers
SOURCE: Toshiba Satellite A305-s6864
no problem, glad it worked
Posted on Aug 08, 2008
  • 162 Answers
SOURCE: not responding? i bought the
         Ok best thing to try, which will quickly solve your problem would be to go here
http://www.systemrequirementslab.com/referrer/srl
Then Click where it says : "Find out if you can run
that game on your PC"
Look in the drop down list and select The Sims 2 Double Deluxe PC game. Then Click on the "Can You Run it" Button.
It wiil then Scan your System & Build a detailed profile of Hardware & Software installed, and will inform you of what software or hardware is/is not compatable with the game you want to play.
I have a Pentium 4 3ghz Processor, 1GB Ram, Direct X 9.0c, Win XP SP3 installed & after running a test to see if my Machine would handle The Sims 2 Double Deluxe, it passed on all areas except Video Card. & This is what it informed me :
Video Card
Minimum: A T&L-capable video card with at least 32 MB of video RAM. ATI Radeon series 8500 or better, NVIDIA GeForce series GeForce2 GTS and better
You Have: Intel(R) 82915G/GV/910GL Express Chipset Family (Intel(R) 82915G/GV/910GL Express Chipset)
 Video Card Features - Minimum attributes of your Video Card
 Video RAM: Required - 32 MB , You have - 128 MB
 Video Card 3D Acceleration: Required - Yes , You have - Yes
 Video HW Transform & Lighting: Required - Yes , You have - No
Posted on Dec 06, 2008
  • 73 Answers
SOURCE: TV freezes - is it the graphics card?
Possible overheating issue. If it's a graphics-intensive game, it tends to push the CPU and graphics hard harder than when you're just surfing the web, which generates more heat.
Trying opening the case and see if you have dust bunnies - any buildup of lint or dust on air intake areas. Canned air is good for getting rid of that. Also verify that all fans are spinning. The fan bearings will seize up after a while and will probably need to be replaced.
As a temporary measure, try removing the side panel on the case if that's feasible. May help some with cooling and can tell you if your problem is heat.
Posted on Feb 06, 2009
  • 357 Answers
SOURCE: no power light when on but can hear running, no screen image
First make sure the monitor is on and connected to the PC.
If the power light is not on you could have a bad power supply, it could also be that the onboard video went bad.
If your PC has four trouble lights in the back, let us know which ones are lit, this can pinpoint the problem.
The noise you hear is the drive spinning up and the CPU fan.
Good Luck.
Posted on Feb 22, 2009
Game will not start
Turn the cartridge the other way and try pushing it in with the game name facing towards you. This should work.
Dec 29, 2008 | Vtech V.Smile TV Learning System
V-smile will not load the game - what can be the problem? Thank you!
Make sure the system is turned off before inserting the cartridge. Things you can try to get the V.Smile TV Learning System to work:
1) Press the Reset – Press and hold the ON button for about 10 seconds
2) Make sure the game is inserted far enough into the system, and that it is pointing in the right direction. You may occasionally need to clean the contacts.
3) Also, make sure you are using the supplied power cord/adapter, not batteries. Batteries cause more problems than they’re worth.
-Tha Mp3 Doctor
Dec 24, 2008 | Vtech V.Smile TV Learning System
I Buy the Vtech V.Smile TV Learning System and it donot work
Make sure the power cord is plugged in and that the red/white/yellow cables are plugged properly into the TV. Also, as you plug the red/white/yellow cables into the TV, make sure you turn the TV to the right channel - it is different for every TV. For instance, the red/white/yellow on the front of my Sony is labelled Video 2 - yours might be labelled FRONT, AUX, or something else.
-Tha Mp3 Doctor
Nov 24, 2008 | Vtech V.Smile TV Learning System
On button doesn't work
-Tha Mp3 Doctor
Nov 18, 2008 | Vtech V.Smile TV Learning System
Our V-smile system will not turn on even though it is plugged in.
I got the system for my 4 year old daughter less than 2 weeks ago and it quit on me. It's rediculous! Anyway, at first we used batteries and it worked fine but the batteries went dead after she played it about 3 times so we went and bought the power cord. We plugged it in and it wouldn't work at all. I looked all over the internet trying to find a way to fix it because we also got her $100 worth of games and had already thrown away the box so we couldn't return it. Everyone was talking about a reset button and my system DOES NOT have one! I finally found a SOLUTION[most likely temporary] Take the batteries out. Hold the ON button down for 45 seconds, replace the batteries with FRESH ones and turn it on. Sounds like it won't work right?!? Well it did for me and before the game system would come on for NOTHING. Hopefully this helped! good luck
Nov 11, 2008 | Vtech V.Smile TV Learning System
New Vtech Smile won't advance to games in TV Mode
Try plugging the joystick into the opposite port - if it is on the Player 2 port, plug it into Player 1, etc. If it works in one port, but not theother, then one of the ports is bad/damaged. If it doesn't work in either port, it is the joystick itself. Replacement joysticks can be ordered from VTech, Amazon, Target or Walmart.
Other troubleshooting methods:
-Tha Mp3 Doctor
Sep 28, 2008 | Vtech V.Smile TV Learning System
V-smile will not turn on
My kids had there v-smile for about 11 months then it would not turn on so I called the v-tech help line 1-800-521-2010 I had to stay on hold for about 30 minutes then had to deal with a lady that was very rude to me but she did help solve the problem...she told me to unplug the adapter, take out all batteries and make sure everything is unhooked from the game then hold the on button down for 1 minute (NOT THE ON AND OFF) and that will restart the system.. I made sure i tried it before i got off the phone with the lady because i didnt want to wait another 30 minutes to talk to someone again...It did help my problem...hope this helps you.
Jul 13, 2008 | Vtech V.Smile Adapter
V smile pocket wont turn on
If you remove the battery door on the back above where the batteries are inserted there are 2 little buttons with the batteries removed press both buttons at the same time re-insert the batteries and the game should turn on. I am not sure if this is a system re-start but I find that some of out games are pretty beat and maybe they are causing the game to shut down. If it shuts off I preform this task and try a different game and it usually works it is kind of a pain but at least from what I can tell it must be something in the games themselves - maybe they just wear out after hours of play time.
Jul 07, 2008 | Vtech V.Smile Pocket
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
