Question about Seca Health & Beauty
We have a error code of 140 for our Seca scale
We have a Seca Scale Mod # 6441321139 we are getting a error code of 140
ptooshar
  • 19 Answers
SOURCE: scale appears to be inaccurate
this type of less resoluted scale hasn't repeatability. if you wish to repair it, change the loadcell. use 2 x scale capacity of load cell.
Posted on Dec 02, 2008
robocop
  • 90 Answers
SOURCE: need manual to reset scale to weigh properly
Either do a search for that particular scale brand & model, which should take you to the company, whom should have a manual on-line or go back under search and type in "users manuals". There should be several manual websites that come up. Just don't click on the websites that require money for their manuals, when you can get them for free at other sites.
Posted on Jan 22, 2009
SOURCE: error message
Try this, I have the same problem and I just got off the phone with Taylor, this is what they told me to do and my scale is now working again.
1. take the battery out.
2. put the scale on a flat, hard surface
3. stand on the scale for 10 seconds
4. put the battery back in, be careful not to touch any buttons or turn the scale on
5. put the scale back on the flat, hard surface
6. put one foot on the scale and apply pressure until the display comes on
7. take your foot off of the scale
8. wait for the the display to go blank
9. now stand on the scale to weigh yourself.
This worked for me. Hope that it works for all of you.
Posted on Feb 17, 2009
SOURCE: Error message ErrL
My scale had the same problem.  I replaced the battery, but still got the same message.  My wife noticed that one of the feet on the bottom of the scale was loose.  The feet are twisted on to the scale and held by two small flanges.  When I gently pulled the loose foot away I noticed that a small black wire had broke.  I used my fingernails to remove a small bit of the wiring cover and twisted the ends back together.  I then hide the wires back in a recessed area on the foot and placed it back on the scale.  Worked just like the day I got it.   Hope this helps!
Posted on Feb 20, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
Seca 769 error code e.10.11
showing error code " Seca 769 error code e.10.11" how can i solve this problem.pls help me.
Oct 07, 2013 | Seca 769 Digital Scale 400 Lb with Bmi and...
I have E10.11 code on Seca 869 scale what does it mean?
I have the same problem. I sent an email to the company and got no response, frustrating considering how much this scale costs for professional use. The manual says "Excessive weight has been applied in general or on one edge. Reduce load on scales or distribute weight more evenly. Restart scales."
I've done this, and it always starts with E10.11, making it unusable. If anyone has help or suggestions, please post.
Mar 12, 2013 | Seca 869 Portable Flat Scale W Cabled...
How to calibrate seca 780
I recommend you look in your local yellow pages for a scale company. Calibration is very easy to do, but we recommend that you bring the scale to a local scale company. All unit sold by Precision Weighing Balances are factory calibrated and should provide you trouble free weighing for many, many years.
Jun 15, 2011 | Seca 780 Digital Adult Scale, 440lbs/200kg
Seca 769 error code e.10.16
What does this code mean? How do I fix it?
Thank
Jun 03, 2010 | Seca 769 Digital Scale 400 Lb with Bmi and...
How to calibrate seca 354???please help me...
I don't know if the 354 can be calibrated.
Here are calibration instructions for the 374. It includes a toll free number to call seca in case this doesn't work.
http://ons.wvdhhr.org/Portals/20/PDFs/policies/2.12%20Anthropometric%20Measurements%20Attachment%20-%202.pdf
May 19, 2010 | Seca 354 Digital Baby Scale Pediatric...
Balance beam wants to stick at about 300 lbs. not smooth moving
I contacted the manufacturer and here is there reply.
No need for oiling or grease, but tip the scale on its side, and look
under the base. There will be four "connection points" where pivot pins
connect to the linkage assembly; see if any of those pins or linkage
points are bent or look different from the other ones.
Then, note down the serial number of the scale located on the side of
the base, or behind the column of the scale at the top or bottom of the
column, and call our Maryland repair center at 800-542-7322 ext. 111 and
speak with Tyson Long from 9:00 AM - 4:00 PM Maryland time to describe
the issue and for further troubleshooting over the phone.
I have attached our new catalogue in PDF format as well. FYI: The model
703 is a very popular, extremely heavy-duty, high-capacity digital
column scale that is a popular alternative to the mechanical physician
scales in the gym and schools environment.
Kind regards,
William Morris
Sales Support
seca north america west
Medical Scales and Measuring Systems seca corp.
3401 Centrelake Drive, Suite 320
Ontario, CA 91761
USA
Telephone +1 909 605 7600
Telefax +1 909 605 7654
E-Mail william.morris@seca.com
Internet www.seca.com
Jan 26, 2009 | Seca 700KG Balance Beam Scale With Wheels,...
Err 12 and Err 16
Dear FixYA
Was advised to send to Scales to another company to be fixed. Therefore no longer need your assistance.
Thank you
Julia
Jan 22, 2009 | Seca 354 Digital Baby Scale Pediatric...
Health & Beauty Logo
375 people viewed this question
Top Seca Health & Beauty Experts
Tom Chichester
Donald Ayers-Marsh
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
