Question about Panasonic PT-AE700U Multimedia Projector
PT-AE700U Projector not working - orange light coming on
The projector power is on but where the light usually flashes red for standby and green when on, it is orange/yellow and no picture appears. I recently replaced the bulb and tried an additional bulb (the old one which wasn't done when I replaced it) and still nothing happens when I press the power button on the remote and on the actual machine. Any help would be most appreciated!
    New Friend:
Same problem
Posted on Nov 30, 2014
5 Suggested Answers
SOURCE: Panasonic PT-AE900E Projector not working???
I have this exact problem too, so anyone out there that can help it would be great!
Posted on Jul 03, 2010
Marrie
  • 563 Answers
SOURCE: PT-AE700U No Power
Hi ErnieN008
If there is no LED's flashing or even lighting up for that matter , then it could just be the fuse on the Poersupplyboard that has gone.
You can replace this fuse by opening up the top cover and looking for the board with the AC inlet on it.
If the problem however still exists , you will have to replace the powersupply.
Posted on May 06, 2008
SOURCE: Nothing comes on except the green standby light on PT-AE900E.
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Posted on Nov 28, 2009
astig1977
  • 88 Answers
SOURCE: I've just replaced the lamp
I'd recommend checking the fans of the projector, and make sure that they're spinning. Since you've mentioned that the lamp blew inside the unit, bits and pieces of the lamp might have lodged itself within the fans. It might also have to do w/ the after-market replacement bulb, which I normally wouldn't recommend.
Posted on Aug 10, 2011
I've just replaced the lamp on my Panasonic PT-LM2E projector and it will switch on but no light comes out. The previous lamp blew in the projector after around 2000 hrs. The indicators are as...
Aug 08, 2011 | Panasonic PT-AE900U Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
PT-AE700E projector appears to have gone kaput - not lighting up.
Because of high voltages and heat, there are many safety circuits inside these units. If you have a spare lamp, try replacing the lamp. Initial checks are made before the lamp is fired and sometimes a defective lamp can cause this. Also, can you descruibe what you mean by "noisier than usual"? Is the fan making more noise? Something elase making a noise?
Thanks,
Dan
Oct 15, 2009 | Panasonic PT-AE700U Multimedia Projector
Jul 24, 2009 | Panasonic PT-AE900U Multimedia Projector
PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Good Luck and Please Rate Fixya!
Feb 28, 2009 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700U
may be a heat problem: check the psu unit for components getting too hot...use a laser thermometer and keep you fingers away from the psu ! other possible problem may be a bad capacitor or the thermal protection before the psu..but this would be a very uncommon problem.
Dec 13, 2008 | Panasonic PT-AE700U Multimedia Projector
PT-AE700U No Power
Hi ErnieN008
May 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Nov 12, 2007 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Panasonic PT-AE700U Multimedia Projector Logo
309 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
