Dicon LD 400 visual field test how to set date
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Sep 05, 2012 | Office Equipment & Supplies
Need to change date
Press the MENU button. Use left/right to select "Date/Time". Use up/down to select "Date Setup" and press the SET button. Use left/right to move between fields, up/down to change them. Press the MODE button when done.
Full instructions are in the "To Set the Date and Time" section of the manual (beginning on page 25 in my copy). If you need a manual, you can download one at
http://www.vivitar.com/files_products/400/ViviCam_7022_Camera_Manual.pdf
Aug 30, 2011 | Vivitar ViviCam V7022 Digital Camera
Clock slow
Set the date and time To set the date and time displayed on the BlackBerry smartphone, complete the following steps:
  1. In the Clock application, press the Menu key.
  2. Click Options.
  3. Click Set Time.
  4. Set the date and time.
  5. Press the Menu key.
  6. Click Save.
Retrieve the date and time from the wireless network To retrieve the current date and time from the wireless network, complete the following steps:
  2. Click Options.
  3. Click Set Time.
  4. Set the time zone in the Time Zone field.
  5. Perform one of the following actions:
    • To retrieve the date and time from the wireless network that your BlackBerry smartphone is connected to, change the Date/Time Source field to Network.
    • To retrieve the date and time from the BlackBerry® Infrastructure, change the Date/Time Source field to BlackBerry.
  6. Press the Menu key.
  7. Click Update Time.
  8. Press the Menu key.
  9. Click Save.
Note: To set the time manually, change the Date/Time Source field to Off.
Sep 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
I have a Whirlpool Cabrio Top Loading washer model WTW6400SW1. During the past month, I have been seeing the "LD" error code ("slow to drain") but not the "F1" code during middle of the wash cycle before...
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
THE MACHINE KEEP ON DISPLAYING THE CODE SC0322 (COPIER RICOH AFICIO 1045 MODEL). HOW TO FIX THAT PLZ?
Ld unit problem. This code can be very frustrating, as it can be triggered by several things -top right door switches shorting out, toner on the LD unit board, laser synch board problem, bad connection between the BICU and the LD unit, etc.
The bottom line is, if you're not a technician, you will need one to solve this error.
Make sure to always perform the LD pitch adjustment (both 400 and 600dpi) after doing any service to the laser unit.
May 18, 2009 | Ricoh Aficio 1035 Copier
How do i use date in visual basic 6
I am not getting your problem clearly.
If you are referring to save the input dates as date in database with the help of sql query then you need to provide hash(#) mark at the beginning and end of date values. It will resolve your problem.
Hope this helps and let me know if you are not getting the solution clearly.
Thanks.
Mar 06, 2009 | Microsoft Visual Basic 6.0 for PC
SC 329 code Aficio 550
· SP2-109-1: Laser Beam Pitch Adjustment – 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment – 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting – 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting – 600 dpi
· SP2-902-2, no.12: IPU Test Pattern – Cross Stitch – 400 dpi
· SP2-902-2, no.13: IPU Test Pattern – Cross Stitch – 600 dpi
Use the value printed after “P” on the new LD unit as shown below.
NOTE: Do not use values printed after a “V”.
3. Press the “Enter” key.
5. Print the 400-dpi test pattern onto A3 (11”x17”) paper using SP2-902-2 no.12
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. “48”, “96”,
“192”, “240”).
dpi).
2. Press exit, then touch the “Copy Mode” key on the operation panel to access
4. Press the “Start” key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the “SP Mode” key.
Test Pattern Table (SP2-902-2: Test Pattern Printing – IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
Test Pattern Table (SP2-902-3: Test Pattern Printing – Printing)
No. Test Pattern
0 None
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
16 Not used
21 Blank Page
Dec 12, 2008 | Xerox WorkCentre 490CX All-In-One InkJet...
Visual basic
Please Check the format of date time that is comming from record set
Aug 02, 2008 | Computers & Internet
Changing time on Nortel networks Phone system
Sorry, the tester012 was an accident, so I wanted to repost in case there were more questions on this.
The answer still stands for most Nortel PBXs:
To set the time and date of your system you program in load 2:
Step 1) LD 02
Step 2) STAD "Day Month Year Hour Minute Second"
i.e. STAD "24 11 1976 15 41 49" =
November 24th 1976 3:41pm 49 seconds"
To test it...
Type: "TTAD" - (this tests time and date)
But I also wanted to clarify that it is in the manual, but since there are multiple manuals with a Nortel PBX, that you need to look in the LD (or Loads) in them. This particular one is found in LD 02.
Another site to check out for a crash course in LD for Nortel (in case you have similar issues that you need assistance on) is this one here:
http://www.pbxinfo.com/meridian-systems/16288-meridian-crash-course-programming-guide.html
I hope this has been helpful, again I am sorry for not having logged in properly to be notified on more explanation when I posted Solution #1.
Apr 15, 2008 | Nortel Norstar 16-Line PBX Speakerphone
About visual basic coding
The standard way of creating a database using VBA, which can be modified to suit your needs is this--> Note: the code (wspDefault.CreateDatabase("Newdb.mdb"...), can be altered to save the database in a folder  such as "C:\NEWDB\text.mdb". sub NewDatabase()     Dim wspDefault As Workspace, dbs As Database     Dim tdf As TableDef, fld1 As Field, fld2 As Field     Dim idx As Index, fldIndex As Field     Set wspDefault = DBEngine.Workspaces(0)     ' Create new, encrypted database.     Set dbs = wspDefault.CreateDatabase("Newdb.mdb", _         dbLangGeneral, dbEncrypt)     ' Create new table with two fields.     Set tdf = dbs.CreateTableDef("Contacts")     Set fld1 = tdf.CreateField("ContactID", dbLong)     fld1.Attributes = fld1.Attributes + dbAutoIncrField     Set fld2 = tdf.CreateField("ContactName", dbText, 50)     ' Append fields.     tdf.Fields.Append fld1     tdf.Fields.Append fld2     ' Create primary key index.     Set idx = tdf.CreateIndex("PrimaryKey")     Set fldIndex = idx.CreateField("ContactID", dbLong)     ' Append index fields.     idx.Fields.Append fldIndex     ' Set Primary property.     idx.Primary = True     ' Append index.     tdf.Indexes.Append idx     ' Append TableDef object.     dbs.TableDefs.Append tdf     dbs.TableDefs.Refresh     Set dbs = Nothing End Sub
Hope this helps! Please let me know if you have any questions.Thank You,Raph30
Apr 10, 2008 | Oracle 10g Database Standard (ODBSEONUPP0)
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
