Question about Craftsman Garden
Craftsman lawn mower
I put a new solenoid and a new switch but can't get any fire to the spark plug
    New Friend:
    Problem Solver:
  • 17 Answers
Take top off.Look to see if magneto has rust on the coil.if so,get a steel brush,and clean mag,coil.That could be it.Also check to see if you broke the key on the crank.
Posted on Dec 05, 2013
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
rwvanlue
  • 486 Answers
SOURCE: Craftsman lawn mower. Briggs & Stratton 6.75
1) check plug for being carbon fouled or fuel fouled. Even though it fires, it may not be firing correctly
2) make sure you have compression 75-100 psi. since the compression release so you can pull the rope works off of the exhaust valve, you may not get anymore than that.
3) Is there water or debris in the float bowl
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 26, 2009
  • 13 Answers
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Posted on Apr 16, 2010
philwalker78
  • 608 Answers
SOURCE: Craftsman 17hp 42" cut riding
Sounds like its not getting enough fuel. clean the fuel system and the carby. The valve clearances also need to be checked.
Posted on Apr 11, 2011
  • 6468 Answers
SOURCE: My scag mower won't run and spark plugs are not firing
unplug the harness and crank it over see if there is spark then is yes check the safety switches if not check the coils
Posted on Apr 13, 2012
I have a craftsman riding mower model 247.288810. While cutting my lawn the engine all stalled and would not start anymore. I changed the spark plug and the battery is new, what could it be?
there are 3 safety switches,clutch,deck and seat, Craftsman 247288810 Lawn Tractor Parts
take the cover off so u can access the coil,unhook the black wire from the coil,not spark plug cable,try to start it,if it starts then a safety switch is bad,if it doesnt,then jump the solenoid,if it starts then it is the seat or clutch switch,if you want to bypass safety switches,connect a switch to the ground and coil
Jul 28, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do i change a spark plug on Craftsman lawn mower
Mine takes a three quarter socket and disconnect the spark plug wire take the old one out and install a new one. Putting the wire back on after putting in the plug.To do it right check the spark plug gap but usually it is factory set anyway.
Jun 30, 2014 | Craftsman Garden
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
We have a murray riding lawn mower 287707 it turns over and it wont start. Spark plug new and it sparks and just changed oil, cleaned carbuator, new fuel line and new air filter we tried everything. Can...
on the bottom of the carb there is a solenoid if that solenoid doesn't have power it shuts it off a bad safety switch will cause it to not have power if so start with the clutch/brake switch
Jun 03, 2012 | Briggs & Stratton Garden
Just bought a 2007 LT1000, 16 hp Craftsman riding mower. The original owner bought it new and passed away in late 2008. The mower was not started but a couple of times since that time. Now, after sitting...
when they were jumping it with a car battery if could have damaged the stater solenoid. You may have to replace the solenoid or check for loose wires going to the solenoid, all so check and clean the wire plug on the key switch
Aug 18, 2011 | Craftsman Garden
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Will not stay running
This may be a bad capacitor in the ignition, change it. OR it may be a fuel blockage, check, all filters and lines. Check, Coil, & magneto/alternator. Check, for any loose connections. www.jackssmallengines.com/do_it_home.html
www.fixitclub.com › Parts & Components
http://www.hammerwall.com/Manuals/Craftsman/Description/917.275371/Craftsman%2017.5%20HP%2042%20Inch%20Mower%206%20Speed/L0412338/
Download this service manual above it isn't exactly the same, but follow the troubleshooting procedures and it will help you find and fix your problem
Apr 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
