Question about Microtek 815C 18" Flat Panel LCD Monitor
Monitor wont turn on. it turns on for a brief moment to tell me there is a connection issue but then it goes into standby mode. everything is connected properly i even had my work double checked.
Im running a custom built desktop on it running an msi motherboard and processor.
  • 32 Answers
How old is the monitor?
it sounds like the inverter is shot on the monitor. shouldn't be an issue with the pc.
Posted on Jul 31, 2013
2 Suggested Answers
go-tech
  • 41 Answers
SOURCE: picture and video is not clear
Hi Scandle201
Yot have done every thing right on your side. You will unfortunetly have to take the monitor back to the repair shop. Ask them to test it at your resolution settings of your home desktop and play some video's and open some pictures on there test system.
Regards
Go-Tech
Posted on Dec 15, 2008
Monitor flashes, turns off
Try to check both ends of the video cable if it's properly connected. Also, check the power cable connections. I'm quite sure this is not an issue of a video card.
Jun 04, 2013 | Computers & Internet
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
TouchSmart 310 won't boot up .
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps you
Dec 07, 2011 | HEWLETT-PACKARD Hewlett Packard HP...
After turning on my Sony MHC-GX750 it goes into stand by mode. What can i do to fix the problem?
Turn the unit off and dis-connect the speaker wires, press power and turn down volume, if it comes out of standby mode and comes on it means there is a short in the wires or one of the speakers. But! if it stays in standby with everything dis-connected it proves that one or more of the audio output ic packs is shorted and needs a tech to resolve the issue.
Jan 28, 2011 | Sony Audio Players & Recorders
My monitor gets switched off when i connect to cpu,the moment i disconnect it from cpu,its switches on automatically.what may be the problem?
One of two things:
1.) Your video card is 'stuck' in standby mode, which in turn sends a signal putting the monitor in low power 'standby' mode as well. When you disconnect it, the monitor returns to normal 'on' mode. Rebooting the PC should correct this issue.
2.) Your resolution or refresh rate are set outside the range supported by the monitor. When you connect the monitor, it starts receiving a signal that it can't display, so it simply turns off. You'll need to reboot the PC and press F8 quickly to bot into safe mode and correct the monitor settings.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
ekwhoward@yahoo.com.
Thanks
Ekow
Nov 04, 2008 | Westinghouse 19" Widescreen Flat Panel LCD...
Power dies when video signal applied
I fixed this problem by replacing all the electrolytics 1000uF and 1500uF on the power supply/inverter board. All were either bulging or had burst at the bottom rubber seal. This cleared up all problems and I am using this monitor successfully at this very moment.
Jul 14, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
LCD monitor from "LCD Universe"
Inverter unit inside the screen may be defective
Apr 07, 2008 | Computers & Internet
When the PC starts the monitor does not come out of the power standby mode
Hi The problem is to do with a 680uf capacitor that tends to bulge and fails.this stops the monitor staying on when trigerd to do so,change this and happy day.
Jan 16, 2007 | LG Flatron L1715S 17" LCD Monitor
Microtek 815C 18" Flat Panel LCD Monitor Logo
Top Microtek Computers & Internet Experts
William Miller
William Miller
John Anderson
John Anderson
solver2010
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
