Question about Cisco TelePresence EX90
EX90 needs to be boot 5 or 10 times before it will accept a DHCP lease
Delete dhcp lease
You can only reset the DHCP lease, so it starts again.
Or you can set a new timeout.
Feb 15, 2014 | NetGear Computers & Internet
Tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 | Computers & Internet
Infinite lease period
Page 25 will change idle time to router to "always on"
There is no way on the router to set the DHCP lease time.
See manual http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf
Dec 26, 2013 | NetGear WNR2000 Wireless Router
Everyday I need to reboot SMC8024L as systems not getting IP address from stand alone DHCP server could you please suggest what needs to be done here ??
The lease time on DHCP IPs is usaully set for 24 hrs. Try assigning a static IP or changing the lease time. These settinbg are located in router.
Dec 21, 2012 | SMC8024L2 TigerSwitch Standalone 24-Port...
Steps to change lease time on a linksys E2100LWhat's your problem?
May I ask why you care about the lease time? All this does is indicate how long a computer holds an IP address via DHCP. If the computer is still connected it will merely renew an expired lease. One of the only situations you would care about the lease is if it were in a public location. In almost all situations default lease time is adequate
Jan 02, 2012 | Linksys E2100L Advanced WirelessN Router...
My belkin 54g wifi router is making a new DHCP request to my isp every 4 minute or so - the lease time is set to "1200"
the lease time should be forever..... even after changing the lease time if you have the same issue, try updating the firmware of your router.... you can download the latest firmware for your router from the link below....
www.belkin.com/support
Apr 13, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Some of my workstation immediately disconnects fron internet
That sounds (apart from a really heavy load on the little router) very much like you are running out of DHCP addresses.
Are your computers set to static or DHCP?
Are they connected via cable or wireless?
What is your DHCP range?
What is your lease time?
If the computers get rebooted i.e. 6 times per day and your default lease time is 1 day, that means that only one computer is blocking already 6 IP addresses per day. 33 computers therefore are blocking 198 addresses, which is almost your entire spectrum from 192.168.1.2 - 192.168.1.254.
So either set them to static IP or shorten the lease time.
Jul 04, 2009 | Computers & Internet
Dhcp renew
what has happened is the dhcp ip address lease time as ran out, you should go into the routers settings (type 192.168.0.1 in your web browser) and change the lease length, it should be set as infinite or the longest you can set it to. If unable to get into the router there should be a reset button.
Sep 09, 2007 | D-Link DI-604 - 4-Port Broadband Router [...
How do I configure DHCP server on my wireless router?
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK. Step 3 Click on the Home tab and then click on DHCP to the left. Note: If you are connecting to a DHCP server, the DHCP server on the wireless router should be set to Disabled. Step 4 By default, DHCP Server is set to Enabled. To disable it, click the Disabled radio button. To enable it, click the Enabled radio button. Step 5 Enter the Starting IP Address and Ending IP Address. To change the lease time, select a value from the drop-down list next to Lease Time. Note: The value for Starting IP Address must be less than the value for Ending IP Address. Step 6 Click on Apply then click Continue to save the settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Cisco TelePresence EX90 Logo
20 people viewed this question
Top Cisco Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Cisco Radio Communication Expert? Answer questions, earn points and help others
