Question about Mtd 22" Yard Machine Push Mower
Loose blade I recently hit rock with lawn mower and now bolt and blade keep coming loose, I added a lock washer to bolt but to no avail. Can you help?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 49 Answers
Loose the lock washer before you cut your own feet off or kill the neighbor with blade flying off ! Put bolt in and tighten make sure alignment pins on blade are where they are supposed to be . make sure no grass is caked up around any of the blade or drive shaft
Posted on Sep 13, 2013
4 Suggested Answers
SOURCE: I hit a rock and bent the blade on a yard machine.
I did the same exact thing over the weekend, try adjusting your new blade unscrew the main bolt to the blade about 1/2 turn that should get it spinning again, same exact thing happened to me. Good Luck
Posted on May 18, 2009
steve_lima
  • 181 Answers
SOURCE: I hit a big rock with my walk behind lawn mower
the flywheel key is broken.take the recoil cover off.take the nut off that holds the flywheel on.thake a hammer and lightly hit the flywheel oppisit side of key way.the fly wheel will come off.replace the key.replace the flywheel.replace the recoil cover and test run the mower.should be fine.let me know if this helped................
Posted on Jun 29, 2009
  • 10 Answers
SOURCE: How do you replace a belt to a riding lawn mower?
Basically, it is not a big job.
First thing to do is take the key out of the ignition Switch.
Secondly, Lower the deck to it's lowest position. Look for a belt that runs from the motor pulley to the deck. Now have someone move the lever that engages the blades.
A set of pullets should move when the lever is moved.
You need to get these pulleys unhooked from the cable or lever or both. Now you should be able to remove the worn belt.
Installation is the reverse of this. With the belt removed you should check the pulleys for wear on the bearings, especially the ones that the blades mount to.
You can also go to You Tube and search for lawnmower belt remove. There are about 1,000 or so there.
BE SAFE!
Paul
Posted on Jul 03, 2013
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What will cause the bolt and nut for the blades to keep coming loose?
This is usually caused by one of two things. If you have the right size bolt,put a lock washer on it and tighten until the washer is flat. If it continues to work loose you should check for the proper bolt size/ threads or the threads in the bolt hole could be worn out
Jul 02, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My blade keeps coming loose after hitting a rock on lawn mover
is the bolt stripped so it wont tighten?
Is the threaded hole on the Crankshaft of the mower cracked
Jul 26, 2013 | Mtd 22" Yard Machine Push Mower
My blade holder on my tornado lawn mower keeps coming loose
Sounds like you need to take the blades off and replace lock washers under the bolt heads and reinstall
Mar 22, 2013 | Garden
Guide pins for mower blade believed to be sheared. Hit rock and blade came loose on model #917.377682 Sears Craftsman 21'' with 6.75 turbo cooled Tecumseh engine. Threaded bolt came loose in between two...
Just enough to guide the blade in place so the screw can be tightened to secure the blade. BUT - you might have sheared the flywheel key that times the flywheel and ignition system.
Apr 12, 2010 | Garden
Hello, I have a Craftsman Model 917.377790 lawnmower, power-propelled, with Honda 5.5 HP engine. I replaced the belt that provides power to the rear wheels. The belt is ''caged'' by other parts, so I...
Sounds like you lost the drive key out of the crankshaft, it's usually half-moon shaped and keeps the blade hub and the crankshaft turning together, the bolt just holds it all on the end of the crankshaft.
Hope this helps!
Jul 03, 2009 | Garden
Mower hit a big rock and stoped running
If you hit something hard enough to partially shear the key on the blade adapter, you did shear the key on the flywheel, and it will need to be replaced for the engine to run properly.
Apr 11, 2009 | Garden
Craftsman Electric Mulching Mower 37051
i had the same problem i tried to bend the lift arm to the left put that didnt last /then try drilling 1/4 holes at diferent heights and put a 1/4 screw to hold it
Oct 04, 2008 | Electric Lawn Mower
Mtd 22" Yard Machine Push Mower Logo
163 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
