Question about Mtd 22" Yard Machine Push Mower
My blade keeps coming loose after hitting a rock on lawn mover
I recently hit a rock with lawn mower and now bolt and blade keep coming loose. I added a lock washer to bolt but it did not help. Do you have any ideas?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Is the bolt stripped so it wont tighten?
Is the threaded hole on the Crankshaft of the mower cracked
Posted on Jul 28, 2013
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
SOURCE: I hit a rock and bent the blade on a yard machine.
I did the same exact thing over the weekend, try adjusting your new blade unscrew the main bolt to the blade about 1/2 turn that should get it spinning again, same exact thing happened to me. Good Luck
Posted on May 18, 2009
steve_lima
  • 181 Answers
SOURCE: I hit a big rock with my walk behind lawn mower
the flywheel key is broken.take the recoil cover off.take the nut off that holds the flywheel on.thake a hammer and lightly hit the flywheel oppisit side of key way.the fly wheel will come off.replace the key.replace the flywheel.replace the recoil cover and test run the mower.should be fine.let me know if this helped................
Posted on Jun 29, 2009
  • 16 Answers
SOURCE: Have B&S 4hp lawn mower (20
If its the 4hp classic type Briggs engine with the red primer bulb on the side of the carb then it needs a new diaphragm. Very cheap and simple repair.
see this link for a good picture + price
http://shop.jungle-busters.co.uk/epages/es122164.sf/en_GB/?ObjectPath=/Shops/es122164/Products/795083
Posted on Oct 13, 2009
  • 198 Answers
SOURCE: my lawn mower starts easily, then shuts down. each
disassemble the carb and make sure the float valve is not sticking
Posted on May 10, 2010
Why do the deck vibrate on my cub cadet z force zero turn when I engage the blade?
Anon any vibration is down to something being loose, like a nut or bolt. It's possible the blade has also become very damaged and it is not completely straight anymore due to hitting a rock or something.
Aug 19, 2014 | Garden
Craftmans mover blade keeps hitting ground
Is the deck too low or one side lower than the other? Level the deck side to side, front should be a little lower than back (about 1/4 inch). check tires for correct air pressure. Make sure blades are balanced.
May 10, 2014 | Craftsman 42 in. Precision Cut Plus 24hp...
Hit a rock and shut mower off now every time I engage the blades it shits the mower down
look for a fock stuck between the mover and blades under the mower. pull the plug off before trying this. turning the blade to release something can start the mower with your hands in there.
Apr 23, 2014 | Garden
Loose blade
loose the lock washer before you cut your own feet off or kill the neighbor with blade flying off ! Put bolt in and tighten make sure alignment pins on blade are where they are supposed to be . make sure no grass is caked up around any of the blade or drive shaft
Jul 26, 2013 | Mtd 22" Yard Machine Push Mower
Mower shuts off when blades are engaged
Remove the deck and check the blades and spindles. I suspect your issue is electrical and not mechanical though.
Sep 24, 2012 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
My wife was mowing the lawn and she hit a rock. Since than the lawn mower does not start and when it tries to start a little smoke will come out of the carburator area. The mower is a Sears eager 1...
Unless the blade is belt-driven, like on riding mowers, then the blade is attached directly to the engine crankshaft. Hitting a rock with a mower like this is a very common problem. You probably have a bent crankshaft. In most cases this can be repaired, but may not be worth it, considering the age of the mower. But you should call a local small engine/mower repair shop to ask for an estimate. The repair is not something you would be able to do yourself.
Apr 30, 2010 | Craftsman Garden
Guide pins for mower blade believed to be sheared. Hit rock and blade came loose on model #917.377682 Sears Craftsman 21'' with 6.75 turbo cooled Tecumseh engine. Threaded bolt came loose in between two...
Just enough to guide the blade in place so the screw can be tightened to secure the blade. BUT - you might have sheared the flywheel key that times the flywheel and ignition system.
Apr 12, 2010 | Garden
The engine stalls
you may have trash in the gas tank. empty it nad wash it out real good make sure the gas you use is fresh the vibration could be the blade ; or it could be that when the rock was hit it bent the shaft and that would cause vibration also. remove the spark plug and rotate the blade with your hand, you should be able to tell ifi the shaft is bent or not if not try putting a new blade on
Jun 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Mower hit a big rock and stoped running
If you hit something hard enough to partially shear the key on the blade adapter, you did shear the key on the flywheel, and it will need to be replaced for the engine to run properly.
Apr 11, 2009 | Garden
Craftsman Electric Mulching Mower 37051
i had the same problem i tried to bend the lift arm to the left put that didnt last /then try drilling 1/4 holes at diferent heights and put a 1/4 screw to hold it
Oct 04, 2008 | Electric Lawn Mower
Mtd 22" Yard Machine Push Mower Logo
103 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
