Question about Dell Inspiron Computers & Internet
Internal speakers not working! earphones working fine. help
  • 4 Answers
Try reinstalling the hardware
Posted on Jul 26, 2013
Testimonial: "tried this , but still no speaker sound"
5 Suggested Answers
babes_ganda0
  • 381 Answers
SOURCE: No sound from laptop
The simple damage your laptop and here is you can not move but the socket earphone / headset of your laptop,the opening of outlets are you have seen lock switch is you just poke a gently using the little things like the end of ball pen.good luck and hopefully helped revenue
Posted on Dec 12, 2009
hothawk
  • 174 Answers
SOURCE: laptop speakers working, ear phones not working
Check when you plug in the headphone the laptop speakers get off or not also see the audio configuration under control panel sound that you choose digital sound or its having channels system like 5.1 or 7.1 channels you have to configure it to headphone
Posted on Jul 02, 2008
DCSE
  • 191 Answers
SOURCE: internal speakers not working
try reinstalling the audio drivers first
as it seems to be an issue with either drivers or with the sound card
provide more info like
when was it working fine
wots the operating system you are running
Posted on Jun 07, 2008
  • 6771 Answers
SOURCE: Earphone jack on my compaq presario c700 stopped working. How do I fix it?
You will need professional help on this, the laptop must be dismantled down to the motherboard level to access the problem. The earphone jack may have to be replaced and requires a high degree of solder skills to remedy the situation.
Posted on Apr 04, 2012
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
Apr 03, 2012 | Compaq Presario Computers & Internet
I have a mid tablet that i bought new from amazon. the internal speakers worked fine untill i put some earbuds into the jack. what is the safest and most inexpensive way to fix it?
Well, you need to find out what happened. Normally, the earphones will cancel the internal speakers, but the function of the speakers should return after you remove the earphones.
What you need to do is go into the control panel and then to the sounds icon and find out what the system is using for its output. It could be that it thinks the sound should be still going to the earphones. If so, change it to speakers.
Aug 22, 2011 | Computers & Internet
Television worked fine when I turned it off. The next day when I turned it on there still was a beautiful picture but there was no sound. Everything I read says no picture or sound. Please help.
Hi qlane1,
First make sure that the sound is not in "mute" mode.
Plug your headset to the earphone jack (if installed) of the TV.
If you can hear the sound there, the fault may due to open(defective) internal speakers or the earphone jack itself. Faulty internal speaker may replaced with new sets to back your sound to normal again. If the earphone jack was faulty, you may spray it first with electrical contact cleaner while inserting and pulling the headset plug into it for one minute to clean the contact. If nothing happens, this jack need to replaced with new one.
If you can't hear the sound after inserting your headset, this is an indication that the audio circuitry was gone bad. The most common caused of this trouble was the faulty sound IC(mounted in heatsink). This is the one converts the audio signal to sound and feed to your speaker's. I would advice you to look for a qualified technician to check this parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 11, 2011 | Audiovox Televison & Video
Dec 12, 2009 | Compaq Presario Notebook
The internal speakers on my ipod touch don't work
As far as I know, the sound quality coming out of the ipod is not so great to begin with. I have an iPod touch, and the speaker I have right now was only $12.59 and the sound quality is great. plus I have my headphones from UxSight. They are amazing. Here is the link: iPod speakers
Sep 30, 2009 | Apple iPod touch
Everything works fine on the unit no problem until
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
I have no sound on my HP Pavillion laptop
I had the same problem, but now its solved!
Brieftly speaking, my internal speaker stopped producing sound, but when I plug earphones in, there is sound in the earphones.
Just plug in-and-out ur earphones several times (it took me 5 tries) and voila internal speakers work again!
I think there is a mechanical sensor inside the sound output (plug for the earphone) so that once it senses a plug getting in, it shuts internal speaker.
Maybe the mechanical sensor was jammed (spring problem i guess) and it still believe that u have ur earphones plugged-in. "Clogging" the hole for the earphones would allow the spring to spring back to initial position...
Hope it helps
Jan 13, 2009 | HP Pavilion dv9000z Notebook
Jun 06, 2008 | Computers & Internet
No sound!
If you can hear audio through the headphone jack but not the internal speaker jack, then the speaker is bad.
This is a problem I have seen many times before. I will be posting an article soon on how to replace the internal speaker, however this is not a repair that just anyone can do.
You have to have skills in dissassembly & soldering.
- Jim
Jun 01, 2008 | Garmin Nuvi 660 GPS Receiver
Computers & Internet Logo
73 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
