Question about American DJ Mister Kool Fog Machine System
Mister Kool fog machine - heat problem...
I just bought 2 Mister Kool fog machines and at first they worked out fine...I was using it with timer about half hour...then the hose that supply with fog juice melted on one of them, when looking at the still working one, I could see the hose was also heat-damaged on this one. It seems the machine gets so warm that the plastic hose melts. How can I fix it?
2 Suggested Answers
  • 773 Answers
SOURCE: i have a mister kool
There is either a leak in the feed hose, or the pump is going bad.
Posted on Nov 10, 2010
Do you need to drain the kool king ac?
What kool king? Some are fully evaporative, some partial. None the less depending on humidity and how much condensation machine is producing all need drained. Typically it will shut down when and if it needs drained but if you are concerned, pull the plug!!
Aug 26, 2017 | Kool King Heating & Cooling
Repair manual
I first tried to remove the mister but the way it is built make it impossible to take it apart without destroying the cauldron. So what I did was purchase another fogger for 20 bucks. [Found it on the web] It fits snuggly between the outside wall and the original mister. The wire went up her dress and out her hand that holds the stick. I used masking tape and taped the wire to her stick. then I painted so it was not as noticeable. I put the screen in the cauldron and you can't tell the there is a replacement. The only thing that is different is Now the mist has all different colors instead of just red. It is a easy solution
Oct 30, 2013 | Gemmy 5-1/2' Life Size Witch with Fogging...
Turned the fog machine on, all the lights come on- so electricity is getting to it- i havent used it for 5-6 weeks as I've broken my leg. The fluid is high, I switched it on, and it made no noise- nor...
Hello, Do you have the remote? Sometimes when they dont have the remote the unit starts to cry and it dosent want to do anything. Regarding the contact info for american dj they are only located in the U.S and so is there contact support. Here is there number. hope this helps
fo@americandj.com Phone: (323) 582-2650 Fax: (323) 725-6100
Jul 28, 2011 | American DJ Mister Kool Fog Machine System
My "Mister Kool" Fog machine
What about the Mister Cool fog machine, you pose no question here.
Jun 08, 2017 | American DJ Mister Kool Fog Machine System
Shoots out liquid instead of fog...
that thing(the heater) just doesn't work well,
bring it to someone to repair it
Apr 23, 2009 | American DJ Dyno-Fog-II Fog Machine W/...
The Drum turns, but no heat, is it ok? Different machine, same problem. I've switched out the timer, thermostat/fuse assembly, and element. Though the feedback for this machine was great when I bought...
check your breaker, sometimes if one side of the 220v breaker trips and not the other then the dryer will run with no heat. if you have a voltage meter then check the outlet itself for a full 220v.
Jun 27, 2008 | Haier XQG50-11 Front Load Washer / Dryer
American DJ Mister Kool Fog Machine System Logo
27 people viewed this question
Top American DJ Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an American DJ Audio Player and Recorder Expert? Answer questions, earn points and help others
