Question about Hoover S3755 WindTunnel Bagless Canister Vacuum
Red power light blinks even with completely clean canister and filter
Power light indicates the suction power selected in 3 increments. But all of the sudden the light starts blinking almost immediately upon turning on. But suction seems fine.
  • 4 Answers
Check for a filter where the air blows out of the machine. Could be clogged.
Posted on Jul 26, 2013
4 Suggested Answers
wayneard
  • 1901 Answers
SOURCE: Red light for HIPPA filter won't go off
Red light is sign of reduced suction due to a blokage of some sort. If you are sure the filter is thoroughly cleaned, check the hose, wand, and the nozzle connector for obstructions of any kind.
Posted on Oct 25, 2008
  • 3 Answers
SOURCE: Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Posted on Jan 07, 2009
SOURCE: no suction power ,brush wont spin on carpet power nozzle. When it
You need to replace the belt that turns the brush.
Posted on Jul 03, 2010
Filter queen vacuum head has no power
More information needed. When you turn on the vacuum do you hear the motor running? Is the problem that there is no suction at the head? Is there suction at the canister when the hose is removed? I would first check to make sure that there is no obstruction in the hose. Have you checked the filters to see if they are clean?
Sep 11, 2014 | Filter Queen Majestic Canister Vacuum
Red light indicator comes on with suction only
Hi there Christy! It sounds like you possibly have a clog in your main hose. To check the hose for clogs remove the hose completely from the vacuum from both ends. Use a broom stick or something similar to loosen and remove any clogs from the hose. Remove the bottom plate and the brushes. Use a wooden spoon to gently break up and remove any clogs from the lower hose. Hope this helps!
Jun 16, 2014 | Hoover Nano Cyclonic Compact Bagless...
Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Feb 13, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Lack of suction
I use a broom handle..works very well
Nov 26, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Nov 17, 2008 | GE 106766 Bagged Canister Vacuum
Oct 25, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Performance indicator light is on and suction is not strong
You do have a clog! trust me. Check the wand and the yoke which is on the brush assembly. its the part that connects with the wand.
if thats not it then it has to be in the hose. the only way to get it out of the hose is to take one or both ends off and push a broom stick through it
Feb 03, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Hoover S3755 WindTunnel Bagless Canister Vacuum Logo
246 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
