-   To relply to that post above, HDMI carries sound for the record thats how I have my 360 connected to my polaroid, well atleast until the sound went then I had to use components that way I could connect the audio portion to the reciever. So pretty much that is the only thing you can do with these tvs, besides using them as a paperweight for poster board, connect the audion portion of whatever your using to a reciever.
-   Guest
Oct 30, 2008
-   Less then two years after buying the TV, audio problems started with intermitten popping sound from speakers. Now the audio goes out all together, albeit intermittenly. Should I try to get it repaired through Polariod, or should we just replace the TV? I should have known the price was too good to be true.-   Guest
Oct 10, 2008
-   I have the same problem. Mine is out of warranty (of course) Called polaroid and was offered a factory-refurbished set with a 90-day warranty for $310 + s/h to send mine back.
There must be a better deal out there than this. Or a fix.-   tctrumanpe
Aug 15, 2008
-   I can't make the audio work w/ a receiver. It is so frustrating. I've tried every kind of audio cable to no avail.-   Guest
Are you using a set of sound wires in addition to the HDMI cable? - HDMI only carries the HD Video and no audio, so you still need either a digital or audio cable to pass the audio to the set.
Popular Solutions for Polaroid FLM-2632 Television
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as...
(More)
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as well as a HDMI cable.
i have a coby TF-TV1901 (19"lcd flatscreen).hooked cable up and had picture for 2 seconds then...
(More)
i have a coby TF-TV1901 (19"lcd flatscreen).hooked cable up and had picture for 2 seconds then nothing and i havent had any picture since. its not my cable box because all other tvs work. i brought mine down stairs to try a dif. connection but still nothing. ive done the factory reset and uto search countless times but im at a dead end
Same problem - after about a year, it just stopped producing sound all of a sudden, like I hit the mute button.
Comment by Guest, posted on Mar 22, 2008
No audio or intermittent audio is a common problem with a high
percentage of these Polaroid models. The service center I talked
to said not to bother bringing it for service, as it needs a $400
"control box" module.
