Question about Belkin Components F6D4230-4 Wireless Router 4 X 10/100base-Tx Lan 1 X
Wireless light flashes & can't connect
The wireless light on my router keeps flashing orange and non of my devices can connect to my wireless network. I have tried resetting the defaults, power cycling the router and the modem and resetting the router and nothing has worked. Also, there is no firmware upgrade available for this router according to the set up page. I don't know if my settings are messed up or what the problem is. Please help!!
  • Belkin Compo... Master
  • 15,746 Answers
    Master:
  • 325 Answers
Are You Sure You Have Signal coming into modem/router sometimes the red light indicates no connection is it dsl or cable or? if DSL can you use the phone disconnect the filter. and plug the cord strait into the wall plug.cable could be the connection check for shorts could be an issue with your carrier call them for a simple electronic reset Hope this helps!
Posted on Jul 26, 2017
Belkin f6d46304 v2
hold reset button unplug and plug back in after few secons make sure your ethernet is pluged in from sevice provider
Jan 16, 2014 | Belkin Computers & Internet
When i plug my dlink DSL-2640U router the lights start flashing and every time it flashs the wireless just drops down and i have to enable it from the settings .. then the router's lights flash an
The led always flash with activity. They are transmitting and receiving data. If they stop flashing your ISP signal has stopped. Could you explain this statement" the wireless just drops down and i have to enable it from the settings"?
Dec 20, 2012 | D-Link Computers & Internet
Light on printer keeps flashing orange. Router is working, if not I could not have wireless, right??? My printer is next to computer and router. Help
If your printer was wirelessly working before, try to unplug/replug your printer to the power outlet. Doing this usually fixes minor communication issues.
If that doesn't help, please reset the wireless network adapter for your printer. On the printer operator panel, press Setup button -> Network Setup -> Reset Network Adapter to Factory Defaults. The WiFi light will momentarily turn off, then turns on steady orange. You can now reconfigure your printer for wireless connection.
May 02, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Cant access internet through wireless network.
How do you know your notebook is connected to your wifi AP? Did you try pinging the gateway? If not, open your command window & type "ping 192.168.0.1" (put in your own gateway address.) If you get replies, then ping something outside of your network: "ping 4.2.2.2" (this is a verizon dns server). If you get replies, then "ping yahoo.com". If it does not fail at any of the above steps, you don't have a connectivity problem. If you fail any of the above, then report back & we'll continue the troubleshooting.
Jun 08, 2010 | Acer Aspire 5536-5224 Notebook
Flashing Orange Light
the flashing orange light is an indicator to tell you that your wireless adapter is working and has a connection to your router, if you are not wireless, press the button that is flashing and it will dissable your wireless connection,to turn back on press it again.
Aug 04, 2007 | Acer Aspire 3003LCi Notebook
Belkin Components F6D4230-4 Wireless Router 4 X 10/100base-Tx Lan 1 X Logo
42 people viewed this question
Top Belkin Components Computers & Internet Experts
William Miller
William Miller
David Payne
David Payne
Are you a Belkin Components Computer and Internet Expert? Answer questions, earn points and help others
