Question about Magic Chef Refrigerator. 10.0 cu. ft. Refrigerator in White MCBR1020W
Help My refrigerator is just over a year old and this is in my 32ft camper. The reset on the lower left corner looking at the back of refrigerator keeps tripping and the hole refrigerator warms up. It does this once a week but I go to the campsite every weekend. Does anyone know what may be causing this.. I know I'm not losing power to the camper and I turn every thing off but the refrigerator when I leave
5 Suggested Answers
muffteck
  • 202 Answers
SOURCE: refrigerator not cooling.
should in warranty
Posted on Mar 29, 2010
heatman101
  • 43501 Answers
SOURCE: freezer running hard refrigerator section
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 01, 2011
heatman101
  • 43501 Answers
SOURCE: A while back the refrigerator was freezing
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Posted on Jul 27, 2011
machinetech7
  • 1344 Answers
SOURCE: refrigerator not cold but freezer freezing
The first thing you want to do is open the freezer and see if the fan inside there is running. The reason is the freezer cools the refrigerator side by circulating air from the freezer. If the fan is running then your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
Posted on Jun 17, 2012
I need a manual for a fleetwood wilderness trailer camper 32ft long
one of my favorite sites to find free manuals is (PDF foo.com) I have been able to find every manual Ive ever looked for there and have been able to save them to my file folders for printing and future reference try them.
t
Sep 15, 2014 | 2009 Saratoga Pop Up Trailer
Does my old propane fridge have a element ?
Propane refrigerators have a gas burner to create the heat for refrigerant circulation. Some propane refrigerators that were used mostly in RV's also had an electric heat element that ran off a power cord or 12 volt battery.
To determine this look at the back of the refrigerator, you will see a gas line that ends in a burner on the lower left side (looking from the back). Just above that about 4 inches will be wires coming out of the box if an electric heat element is used.
Apr 18, 2010 | Dometic NDR 1062 Refrigerator
Philips pronto now 5 years old --touch screen has become unresponsive. what to do?
There should be a reset button on the back or under the battery cover. if that doesn't work, then you can try to connect to the computer and reload your program. If you don't have the software you can find it at the phillips website. If you can't find the website email me the model and I'll try to find for you.
Jan 31, 2010 | Philips Televison & Video
It's on lower left corner of display. looks like
This is your low tire indicator warning light.Air up all of your tires to the recommended spec, including your spare, then drive your vehicle over twenty miles an hour constant for about two to three miles, this should reset it, any questions get back to me, I'M HERE TO HELP!!!
Dec 04, 2009 | 2007 Nissan Titan LE
Loud sound coming from back of fridge. Pulled out from wall. sound like it's coming from the lower left corner when looking at it from the back. Looks like i'd need to take the lower panel off to inspect...
Hi Rick,
Sounds like the now infamous 'fan icing up' caused by a design fault of the fridge evaporator cover assembly & evaporator heater.Contact Samsung.You may find that these components are covered by by an extended 5yr. guarantee. Good luck.I was 30 days outside.
Cheers,
Ron Swift
Nov 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
Magnavox model S1MP6100D/37 I have a large screen
there are 2 stk392-120 chips mounted to a large heat sink. both are bad, also 6.8 ohm 1/4 watt resistors are bad . need ohm meter top check these.
Nov 16, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Looking for wiring diagram for a 1989 slumber queen camper Modle # SQ80w Trying to hook up to my truck
its in the front left corner, if you laid on your back and looked straight up you will see it
Jul 31, 2009 | Boating
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Kenmore Side by Side Refridgerator
it sounds like the compressor is short cycling,is it working at all?mike
Nov 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
KV-36XBR200 Green in lower left corner
The most common cause is, shadowmask inside of the CRT is magnetized. It sounds by your description that the TV's internal degausser for the CRT is not working. This is serviceable by a service tech.
Most of the time the cause of a failed degausser is the thermoresistor. This is a common type of failure.
Another cause that can show the fault you are seeing is if the shadowmask in the CRT is defective. Sometimes the mask is damaged when the set is being moved, and is accidently banged against something. The CRT is sensitive to this type of treatement.
If the mask inside of the CRT is defvective, the only fix is a new CRT.
Jerry G.
Apr 25, 2008 | Sony KV-36XBR450 36" TV
Magic Chef Refrigerator. 10.0 cu. ft. Refrigerator in White MCBR1020W Logo
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
