Question about DIG Irrigation 9001EZ Hose End Timer
DIG Irrigation 9001EZ Hose End Timer won't start on its own.
I have pushed the start button without the battery to "clear" any memory. I've changed battery twice. There is no water in battery compartment. I start device right after I insert battery. It will time duration perfectly, but will not start on its own. Worked fine last year (new last year). Was kept indoors for the winter.
  • Jack Reid Jul 29, 2013
    If I manually start the timer, it will run for the specified time and shut off, but I must always start it manually. It won't start on it's own. See comments above.
Will not start
Replace the battery or buy a new one. They are cheap for a reason.
Mar 14, 2014 | DIG Corp oration, 3/4" Hose End Timer...
Dryer intermittently not starting.
The rat chewed up the power line and caused it to short out. Kill the rat!
Jul 14, 2013 | Whirlpool Dryers
Raindrip r672c
Possible water in battery compartment
Corrision in unit
May 11, 2013 | Raindrip Rain Drip R672CT Analog Electric...
Our auto irrigation system wouldn't turn off. We found the Davey XJ70 pressure pump was leaking so replaced the leaking pipe. Now the watering g system won't start. What do we do?
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
Mar 31, 2013 | Plumbing
My washer spin and unlock button starting flashing and when I try to unlock the washer, it won't let me. I have a feeling the load was off balance. What can I do to unlock it?
Access the drain hose and get the end to ground level in a bowl. Empty any water. Clear filter and make sure drain pump is free. Door will now open
May 19, 2012 | Maytag Neptune FAV6800AW Top Load Washer
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
I am looking for a battery water timer that does not need pressure to operate. Just gravity. Any ideas?
Google search: 'battery operated timer' and 'battery operated hose end'
Smarthome shows the Orbit: and has manual:
http://www.smarthome.com/31035/Orbit-57860-Battery-Operated-Sprinkler-Timer-with-Inline-Valve/p.aspx
The manual says 'turn down water pressure.' It looks to me like this timer opens and closes the valve with or without water pressure.
Sounds like it would be perfect timer for above ground cistern where gravity cause water to flow when valve is opened.
Amazon shows battery operated hose end, but doesn't show manual:
Hose end timers are not going to have a pressure gauge.
http://www.amazon.com/Hose-End-Battery-Operated-Timer/dp/B0001O0DXO
Apr 18, 2011 | GARDENA Water Timer
DIG Irrigation 9001EZ Hose End Timer Logo
103 people viewed this question
Top DIG Irrigation Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a DIG Irrigation Garden Expert? Answer questions, earn points and help others
