Question about Panasonic KX-TG3521BX cordless Phone
CORDLESS INSTRUMENT WORKING PROPERLY BUT DISPLAY IS OFF
The display is not working properly -- grids and lines are showing instead of numbers
If the display is not working properly, try to reinstall the operating system to see if that helps.
Aug 06, 2010 | Texas Instruments TI-Nspire Graphic...
The display does not work. The sounds are still
The LED Panel is dead.
Alesis has a parts company that they can refer you to for the proper LED panel. Price is high, however.
Contact Alesis 401-568-3131 or NuMark for the Alesis contact info. I was able to find QS6 and QS8 parts through this resource.
Jun 07, 2010 | Alesis Sr 16 Stereo Drum Machine
Display screen has gone blank
You would need to change the screen. Go to a phone repair shop to assist you in changing the screen. It will cost you a little.
Best regards
Jun 06, 2010 | Panasonic GigaRange KX-TG5432 Cordless...
I have a 2002 Windstar Limited and the "Message Center" on the dash is completely and does not display anything. Is this an easy fix, such as a fuse? Using the owner's manual, I cannot determine which...
If the rest of the instrument cluster is working properly then you probably need a new instrument cluster. A new or working used instrument cluster will likely fix your problem, but a dealer will have to install it and transfer the programming from the old cluster to the new.
Jan 30, 2010 | 2001 Ford Windstar
No display on handset but works fine otherwise. Trying to set up ringer but cannot see any display on handset screen
make sure that the power cable is input properly, if thats not it, make sure the power cablew isnt broken, other wise there souldnt bwe any problems
Nov 12, 2009 | Uniden Cordless Phone
Display is no longer working, phone still operational
Ok, this is common for most cordless sets, all the cordless set needs to do is to be re-booted. Like a computer.
-> I want you to gather all the cordless phones that do not work, and remove the batteries. -> Go to the base station, where the telephone cable plugs into, and I want you to unplug the power there too. -> Now re-install the batteries for the cordless phones. -> and now plug in your telephone base station.
This resets the phones and you should be able to get your call display back, unless your phone(s) are cooked -or- the display died.
Good Luck.
Sep 03, 2009 | GE 28031 Trio Cordless Phone
Problem with display
if you disasembled the phone to clean it, check the flex cable and see if it is all the way on, also use some epc (electrical parts cleaner) on all the contacts including the male and female ends of all the flex cable. this promotes proper connection of contacts. just be sure to completley blow dry it before sending a charge through the circuitry
Jun 21, 2009 | Philips Xalio 300 TU1322 Cordless Phone
Gagues stopped working, even the digital readout, on my 2003 Chevy Suburban The wire harness is connected properly. Any ideas on how to fix this problem?
I'm going to assume you checked the fuses, and say that the display panel will have to be replaced. On these the display is all one piece, and when one gage goes out it effects the whole thing. Some of these display panels had in line fuses on the inside circuitry, so you may be able to pull the display and change the fuse. Others were built as a sealed unit and cannot be taken apart.
Aug 21, 2008 | 2003 Chevrolet Suburban 1500
Static electricity
I had the same problem when I answered my cordless phone static charge went thru me and into my phone and I had now display, so i changed the batteries in the handset and it worked. So I hope this works for you.
Feb 29, 2008 | Uniden DCT646-2 Cordless Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
