Question about Jenn-Air JED8430 Electric Cooktop
Replacement of dual infinite switch 12002125 vs 7403P406-60.
Serial # is 13079884ZQ. I have to replace the dual switch 7403P406-60 (right-front burner)and I got the replacement part #12002125. My old switch has 6 leads (#1-orange wire,#2-black/doubled,#3-tan or white,#4-red,#5-red/doubled and #6-yellow) and the new one has 8 leads (S1,P1-twice,#2,#4,4a,S2 and P2). Can you tell me how do we connect the old switch to the new one? The instruction sheet with the new switch is not enough detailed... Thanks for your help.
3 Suggested Answers
SOURCE: I ordered a replacement switch
There was a design change related to this switch. I had the same problem earlier today and figured it out by getting the schematics from searspartsdirect.com. There are two different schematics there (in English). The old schematic is labeled "DIAGRAM NO. 8104P688-60". The new one has five notes in the lower left (that don't help). The key is to split out the red wire coming back from the double burner element. The old way had it connected to "N" along with the RED source power. The new way has it connected to terminal "2" all by itself with the RED source power now connected to terminal "P2". But in addition, you have to add an extra jumper wire that should have come with your new switch that goes from "P1" to "S1". The other connections simply move from the old switch to the new where the locations can be seen on the schematics by referencing the wire colors (example: TAN wire moves from the old "3" to the new "4", etc.). If you are not 100% sure of what you are doing - you shouldn't try this. A wrong wire in the wrong place can short out 240V when you throw the breaker (boom!). Good luck. -- Mark.
Posted on Dec 17, 2010
SOURCE: I need instructions for wiring in replacing a dual burner switch
We followed the instructions that came with the switch that addressed a "compound wiring" configuration. We also used the black jumper wire as shown in the instructions.
We got to this solution in a trial by error manner though, because the three of us working the problem were convinced the stovetop was wired in a "piggyback configuration" and tried that road first. It would have been helpful if the instructions had included an explanation of the switch manufacturer's interpretation of "compound" and "piggyback" configuration.
Posted on Jan 12, 2010
I ordered a replacement switch for the JED8430ADW. The previous switch was 7403P406-60. The replacement switch is 12002125. I have no clue how to re-connect the wiring. it looks nothing like the old...
Sep 10, 2010 | Jenn-Air JED8430 Electric Cooktop
I have a Jenn-Air cve3400 cooktop. The dual radiant burner doesn't work properly. The inside portion of the burner doesn't work by itself or in tandem with the outside portion of the burner. Is it the...
I just went thru this problem. There are TWO possible switch replacement parts. one is 12002422 and was my correct replacement number.
12002125 was the WRONG part..would not work no matter how you wired it. the failed switch being replaced was part number 7403p406-60. 7403p851-60 will NOT work.
my serial # was 12284711qz
call Jen air customer support and give your serial # and switch part # to get the correct part and diagram... Jenn air changed parts and wiring in the middle of a run.
Aug 14, 2010 | Cooktops
How do I replace a broken dual infinite switch on my Amana AKT3040SS ceramic cooktop?
raise cook top out of counter and remove screws holding glass top to base . remove glass and on the right is switch bank two screws holding each / remove and do not pull wires. but transfer one at a time noting that markings on old sw match new . . sw pt # is 12002125 and cost 49.35. and reinstall in reverse.. hope this helps . and do turn off the power before you start. mm good sailing .,
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
My Jenn AirCooktop Model CVE3401 burner problems
The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
The switch for the dual burner is 12002125, and 74011242 for the single burner.
The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
Apr 24, 2010 | Jenn-Air 30 in. CVE3401 Electric Cooktop
I need instructions for wiring in replacing a dual burner switch on a CVE3400B cooktop. The replacement switch is different from the original. Do you have a diagram for the new switch that shows how to...
Jan 09, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
JEC9530, dual element burner(right front) does not work the light does come on, the burner does not and the knob has play in it.
This coulb be either the switch or the burner. Either can be tested with an ohmmeter if you can read the wiring diagram. Hope this helps!
Feb 26, 2009 | Jenn-Air JEC9530 Electric Cooktop
Great old Jenn Air range needs advice!
YES THEY USE DIFRENT SWITCHES AND IF THE 1 YOU HAVE PROBLEN IS THE DUAL BURNER THER IS A SERVISE FLACH ON IT YOU NEED TO GO TO SERVISE MATER.COM AND FIND THE UPGRATE
Jan 25, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Jun 24, 2008 | Cooktops
Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Sep 04, 2007 | Cooktops
Jenn-Air JED8430 Electric Cooktop Logo
538 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
