Question about AT&T 1040 4-Line Corded Phone
Hold does this phone have a ring back feature after a call is on hold?
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Oct 04, 2013 | NEC Dterm DTP 32D-1 Corded Phone
I would like to know how to program the on-hold ring back feature to wait longer before ringing back. We had a power failure and I have figured out everything else but this one.
Hi this would be altered in MMC502, however if you put a call on hold by pressing the hold key twice it will hold (this is called exclusive hold) the call will be held there indefinitely. I've posted a video from http://www.abbeytelecom.com this has loads of videos to help with programming and training, I hope this is helpful
Jan 24, 2011 | Samsung Prostar 816 Phone
Ringtone problem
A ringtone is multimedia either music or video displaying on the phone device. The name implies that, a tune would be heard whenever a ring sound is expected instead. The features of ringtones takes into consideration the phone type and capabilities from designer.
Nokia E63 cell phones have ringtone capabilities enabled by manufacturer only requiring customer manipulation.
1. The ringtone area is manipulatable by menu features making possible alteration
a. The ringtones could be selected from preexisting programs
b. The phone owner could choose to customer already existing ringtones, explanable
1. The phone could be connected to a computer from which tunes are installed.
2. The phone that is connected to an internet could have features of tune acquirable by subscription.
Important notes about ringtones
1. The devices for a phone is incapable of holding every kind of ring tune considering decoding format
2. The device has space available to hold a number of tunes.
The kind of tunes acquires would have diferent expressions on the device
1. a subscribed ring tone could expire considering acquisition arrangement
Consult your phone provider experts for consultation
Dec 02, 2010 | Nokia E63 Cell Phone
Droid X phone won't ring for incoming calls.
Found on Motorola Support:
1. Make sure that the "Smart Profile: Face Down" feature is enabled.
2. Hold the phone face up in your palm.
3. Call your Droid X from another phone.
4. As the phone is vibrating, DO NOT ANSWER.
5. Still holding the phone, flip the phone face down as it vibrates.
6. Still holding it face down, hit your volume key to silence the phone.
7. Flip the phone back over so it's face up. You should feel a quick vibrating jolt indicating the ringer is back on.
8. End the call. It shouldn't matter which phone you end the call from, as feeling the jolt is the key.
9. Leave phone face up and call yourself again. If the ringer is now working again, turn OFF "Smart Profile: Face Down" until there's a true fix.
10. If it does not work initially, try all of the steps again a few more times and hope you get lucky.
Jul 29, 2010 | Google Android
How do you adjust the hold timer. when you place a caller on hold, it rings back too quickly, I need the feature code so I can change this to like 90 sec or higher
the feature code for adjusting the timer is in MMC 501, however if you place a call on hold and press the hold button twice in quick succesion it will stay on hold for a lot longer. On www.abbeytelecom.com there are around 60 videos which deal with the Samsung Prostar DCS, I have posted the most popular as an example for future reference
Mar 03, 2010 | Samsung PROSTAR816 PLUS PHONE SYSTEM Elec...
I hooked up a phone in the office on an extended line from another area and all of the memory buttons automatically worked, but the phone doesn't ring even after using feature *6 selecting a ring, and...
The easiest thing to do is use Direct Pickup Feature.
When the phone is ringing dial Feature 76
Dial internal number of a phone that is ringing (also refered as extension number)
You just answered a ringing phone at your desk.
If you have login information for Feature **config, I can help you set up your phone to be ringing as well.
Cheers
Jun 24, 2009 | NorStar M7310 Corded Phone
Ring back on 18D
If you have enough voicemail boxes go to ext 10 or 11
Press feature 00
Left intercom twice
#310
enter extension number
press 1 to assign
Feature 00
Jan 16, 2009 | Avaya Corded Phone avaparp18d
Inter-Tel Axxess holding.
In System Timers there is a Hold timer and an Alternate Hold timer. The max that you can extend it to is 255 seconds. Please be advised that this is a system wide timer. If you are the only one that wants this then you should change your keyset to have the alternate hold timer and then extend it to 255. If you want this system wide then you should change the Hold timer and you should be good to go.
Jan 04, 2007 | Inter-Tel Axxess Corded Phone
Prostar 816 On-hold ring-back feature
You can stop the recall function on any indidual call by double pressing the hold key to invoke exclusive hold. Watch this clip or see many more at www.AbbeyTelecom.com
Oct 18, 2006 | Samsung Prostar 816 Phone
AT&T 1040 4-Line Corded Phone Logo
18 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
