Question about Eureka Enviro Steamer 310 Stick Vacuum
Leaking from bottom - Eureka Enviro Steamer 310 Stick Vacuum
Why does my Hoover F5906 Leaks from the bottom?
Water (cleaning solution) is gravity fed to the floor cleaning brushes, but the attachment hose is fed from a small pump. If it only leaks when turned on and operating, check the pump for leaks at the pump itself or the connecting hoses.
Sep 07, 2014 | Hoover F5906-900 Upright Steam Vacuum
I have a Hoover V Steam Vac model F7412. The tank for the clean water and cleaner fluid leaked out the bottom. I purchased a new tank but something in that area is still leaking. I know it is not the...
My clean solution tank is leaking from the bottom, too. It is not a hose or a valve. The clean solution tank is leaking in-between the clear plastic walls of the solution tank & the grey plastic bottom that are connected, together. I was thinking of caulking it all around the bottom where the clear plastic sides join the grey bottom plastic. I can't get into ordering a new one (spending $) unless Hoover will send me a new one for free. Purchased at Kohl's in Massapequa, NY in June 2008. There's a one year warrantee AND the directions say to EMPTY the solution tank after each use. Which I normally do because the tank runs dry.
Aug 08, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
After cleaning the heater, my unit now leaks when it's turned on.
Hi there. Sorry to hear you're having difficulty with your ProHeat 2X leaking. You may want to contact one of our Authorized Service Centers to have a qualified technician inspect your machine.
Here's a quick link to help you locate one: http://www.bissell.com/service-centers/?cid=ccsocial
Aug 11, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover steamvac
Let me start out with an apology. I did not ask my question very well - and you did not answer it as I needed.
If you wish, we MAY be able to communicate in your native language. We can do most indian languages, Turkish, Ukranian and some Russian - as well as Spanish. If any of those are easier for you - please feel free to use any of them.
The Machine storage tanks are 2 - one clean water, one dirty water.
I understand that, when OFF, no leaks happen.
I understand that when on a leak comes from "the side". Also, water comes from the bottom.
So, water comes out near the bottom brushes (even without trigger). Then, with trigger, MUCH water comes out near bottom brushes. Am I correct so far?
Water out the side concerns me. I am guessing that the bottom of the clean storage tank may have a small leak.
I am also guessing that the trigger valve (located in the small opening behind the black rubber seal that the clean water tank rests on) is not closing all of the way - or is broken (cracked).
Can you please remove the clean water tank and inspect the trigger valve with a torch (flash light). Can you see it open/close as you operate the trigger? Is it broken, cracked, or dirty?
If yes then it must be replaced. If no, the the storage tank is bad and must be repaired.
You inspect all of these things and you should be able to determine the failure. THEN, I an help you repair the failed item.
-Jim (Raleigh, NC - USA)
Nov 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
It is leaking water out the bottom when off and won't **** it back up through bottom chamber when on
I personally would dismantle the covers as much as possible. Look for any leaky hoses or tubes. Look for cracks in the canister that could leak. Any air leaks can cause lack of vacuum pressure and release the liquid that is already there. Or if the pump is faulty or leaking, it won't work to **** or to hold pressure.
Nov 12, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Clean solution leaking out the bottom
open it up again and check the pump there is probably a hose leaking ,did you put the clamps back on the hoses
Apr 14, 2009 | Bissell 1400 Little Green Pro Canister...
Bissell spotbot: leaking the dirty water from bottom. I took the bottom plate off and there is a really crappy rubber seal. I think it is leaking from there.
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Sep 07, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Air leak
Check the seal that is in place between the top and bottom sections. If it came out of place even a little, it will leak and you lose suction. Part number 03611180, it is called a buffer.
Dec 22, 2007 | Miele S251 Flamenco II Bagged Canister...
Hover steam vacume F5864
Is it running out of the bottom of the tank, or at the bottom of the machine. If at the bottom, you have a water line off. If at the bottom of the tank, there is a water seal that the tank sits on, may have to replace that.
Oct 03, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Eureka Enviro Steamer 310 Stick Vacuum Logo
23 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
