Question about Pool & Spa
RHEEM POOL HEAATER
DISPLAY NOT SHOWING
    Champion:
  • 305 Answers
Check voltage to display screen should be 24volts. if getting proper power replace control screen
Posted on Dec 06, 2013
My heater is displaying a sensor failure message
Year, model, and size of the heater.
What is the error message exactly?
Oct 31, 2014 | Rheem Pool & Spa
Rheem SPK display
if clicks then check gas line to ignitor if no click replace sparker
Jul 19, 2014 | Rheem Pool & Spa
Rheem pool heater, M406A, display has failed. It is only partially readable and has a dark spot inside it. Is the replacement part the PC board/controller? Is this a job for a savvy homeowner or call
The display is part of the pc board and it is very easy to replace. It is also fairly expensive part just to read the temp(around $400.00). If the heater works fine except for the display you can get by. Hit the up arrow button about thirty times this will ensure you have max'ed out the temperature at 104 degrees. From there with the down arrow you can count down to the desired temp. The mode button should work normally to turn the heater on or off as desired. This is obviously not the repair but it will buy time until you are prepared to replace it or have a technician out for another call.
Apr 12, 2014 | Rheem Pool & Spa
Rheem pool heater there's no power to the display
ensure proper supply voltage to the heater....either 12 or 240 vac. display screen should get 24 vac.....if screen is supplied 24 vac then replace the display screen board.....if not getting 24 vac problem is occuring before display screen
Sep 13, 2013 | Pool & Spa
Rheem pool heater
The display can be decieving when the remote function is turned off it will be in all caps like REM OFF but when it is on it will look like REM oFF. In the on mode the "off" is actually reading the heater mode is off (not pool or spa).
Feb 11, 2012 | Rheem Pool & Spa
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
I have a Rheem Raypack pool heater and cannot locate my manual. The model is pr266a-ep-c. Is there a way to get the manual?
If you run a search for Rheem or RayPak the site should bring you to a menu that will have most manuals.
www.raypak.com/uploads/6000.52AG.pdf
This link may help but I think it goes to an older heater, but it will give you a start.
May 08, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Rheem model p-m266a-en-c digital gas pool heater runs, shuts down
CFH is call for heat not sure what spk is, but will find out and let you know.
Jul 05, 2009 | Solar Rheem Gas Fired Pool & Spa Heater...
Pool & Spa Logo
27 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
