Question about Air Conditioning and Heat for Hyundai Entourage
2007 Entourage AC Not Working, Check Engine Light On
Scan indicated problem with the fan controller. Replaced it. It worked well for 2 days and the A/C went out again and a little while later the check engine light came on.
Well you know where to start
You have a check engine light & if you
did not,you still check for codes & then go to
enhanced codes & body functions & A/C module
Without a factory diagnostic manual & service work
book to learn the system your done,even so for a dealer
or shop
Have to have that info
Not my place to ask who has worked on it
& what your plans are to resolve
Posted on Jul 26, 2013
2 Suggested Answers
  • 34170 Answers
SOURCE: Which fuse is trunk light fuse for hyundai entourage
In the rear area module, check the 7.5A LUGGAGE fuse.
Posted on Sep 27, 2012
Radiator fan
what engine, there are 3 in the USA. gas or diesel.?
the big engine has"?a
"two high pressure lines at hydraulic fan drive." 5.7L engine.
before working on any car, know what engine is there.......????????
the fan just behind the engine rad, comes on, on a dead cold enigine?
CEL (check engine lamp) on key on, then turns off , engine running
and then CEL stays off all the time.????? i no, scan it.
there are 9 DTC errors for the fan alone. scan it.
one one engine, p0692 , tells you , fan2 (high) is stuck on.
got that?
there are 2 fans on the electric fan type engines.
got 2 fans?
and 2 relays
and both are controls all the time by the MFC, module , front , control.
p0480/81 is for the hydraulic, fan...
controlled by 2 modules.... ill wait for engine size ......
Dec 24, 2013 | 2007 Jeep Commander 3.0
Room fuse poping
Short circuits are never the same in nature of what is causing the short, so the best advice is to have a trained electrical tech look in to this.
Jul 27, 2012 | 2007 Hyundai Entourage Limited Minivan
Check Engine Light on
When a 'check engine light' (MIL=Malfunction Indicator Lamp) is turned on, there is a DTC (Diagnostic Trouble Code) set/stored in the ECM/PCM (Engine Control Module/Powertrain Control Module). This code identifies which engine management system component/function experienced a malfunction. Once you pull/read this code, we can possibly help. But until then, it's anybody's guess.
Aug 29, 2011 | 2007 Hyundai Entourage Limited Minivan
My 2006 ford focus zx4 had a low battery indicator light come on in town. On the highway with the ac on full blast and the radio on and cruise control on she started to lose engine power and the radio shut...
With a multimeter check the voltage at battery terminals. Should be more than 12.6Volts when engine off, and at least 14 volts with engine on. If the battery voltage is less than 12.6 volts then you need a new battery. If the voltage is less than 14 Volts with running engine, then the alternator is not working properly. A stop at AutoZone might help. They scan codes, and check alternators for free.
Sep 07, 2010 | 2006 Ford Focus
1995 chev tahoe...AC quit working. fan would
There is a resistor panel that controls the fan speeds behind the glove box on the dash. You remove the glove box and you will see the airbox. Sitting down in the left top, with 2 screws holding it in, will be the resistor panel. It consists of 4 springs and a resistor. All out of veiw, inside the airbox. Remove the 2 screws and unplug the plug. Pull out the old resistor and replace with the new one. It only cost around $15-20 bucks at the local auto part store. This will get your fan blowing. If your fan is blowing but the air is not cold, I would suggest to check and see if the compressor clutch is working properly. If not, try giving it a light tap while running. If it is working, you may want to recharge your freon.
Jul 05, 2010 | 1995 Chevrolet Tahoe
Engine light on
hi check the battery is holding its charge / if the engine light flickers it may be the fan belt/ also check the alternater
Apr 19, 2010 | 2007 Hyundai Entourage Limited Minivan
Check engine light is on2007 hyundai entourage
Hi:
There are hundreds of reasons the Check engine light comes on, some as simple as a loose gas cap. You need to have your code scanned to see what tripped the light..Most auto parts stores will scan your car for free, and tell you what the code is on for..that way you can make a better decision as to what is wrong with your car.
Dec 03, 2009 | 2007 Hyundai Entourage Limited Minivan
Air Conditioning and Heat for Hyundai Entourage Logo
167 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
