Sunon gc125025vha is there a substitute for this fan?
Optoma HD65 Fan Replacement?
im after a fan for the optoma hd65 projector its a sunon 12v 3.0w 20x60x60
Mar 14, 2012 | Optoma HD65 DLP Projector
What is the replacement fan for Netgear FS524
Just took mine apart and the fan is Sunon KD0504PKB2
Jan 13, 2012 | NetGear FS524 24x10/100 Mbps Networking...
I need a Sunon fan for a TouchSmart IQ770 desktop.
Had the same problem. Run part number 5188-7284 through Google. You can find fans for $50 - $100. Go for it!
Apr 17, 2010 | HP TouchSmart IQ770 PC Desktop
Where can i get this fan sunon kde1209ptvx?
Almost any 90 x 90 x 25 mm computer fan with 4 pin connection will replace that fan.
Unless it is an odball version that is.
Any computer store should have one to replace it.
Sep 10, 2009 | Computers & Internet
Dc fan with this part number12-87366-02
Fans are interchangeable parts in computers.
alright bust out your ruler and measure the diameter across.
typical sizes are 60mm, 80mm and 120mm
you can buy all of them and awesome light up ones here
http://www.frozencpu.com/cat/l1/g36/Fans.html?id=iW3bmbvy
Jun 29, 2009 | Sunon (16-02-006) Fan Kit
I need a circuit diagram about heatsink and fan of the computer.
The heatsink doesn't use electricity, and the fan just has a motor inside that spins the blades, with a positive and negative wire going to it. Not much of a diagram to make...
Here's how a heatsink works though: http://www.overclock.net/faqs/115016-info-how-does-heatsink-work.html
From my home site :D
Feb 24, 2009 | Sunon (16-02-006) Fan Kit
Need quiet repl. fan (Sunon 50x50x15mm)
HEY BUDDY...............
U DONT HAVE ANY PROBLEM...IF U R CPU IS PROPERLY  U NEED NOT TO BURRY.ITS OK
AND FAN NOICE DOESNOT MATTER MAN.....MY PC  ALSO HAVE 3 FANS AND CREAT SO MUCH SOUND..............
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 25, 2007 | Sunon 50x50x15mm DC 12V Magnetic...
PROTECT UNPLUG
This is a common problem with sony it means unplug me or i will explode, it is a protection of the heat sync and usually means that a cooling fan has shorted out. If under gurentee return to Sony for repair if not under guranebntee as is generally the case check on the net for a replacement fan motor - as far as i know sony were sourcing thier fanns from Sunon there is a German based headquarters - just google sunon europe
Aug 09, 2007 | Sony DAV-DZ100 System
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
