Kenmore elite oasis washer Model: 11027042603
At Spin cycle, water pump not working. The control module do not send to it a signal?
SOURCE: Cycle signal keeps beeping
http://www.fixya.com/support/t160151-cycle_signal_quit_beeping
Posted on Nov 10, 2007
  • 7 Answers
SOURCE: my kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Posted on Feb 04, 2009
  • 572 Answers
SOURCE: I have a Kenmore Elite Oasis He washer. The washer
sd is suds error. add only HE soap. UL is unbalanced load. watch load size and balancing loads.
Posted on Feb 06, 2010
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite HE3 F02 error
If you checked the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, first and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Mar 06, 2010
blueextc3221
  • 15935 Answers
SOURCE: UL ( unbalanced load ) signal appears, washer will not spin
Re-balance the load, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Water pump shorted out. Now will not stop running unless washer is unplugged
oops you shorted the control board and now it needs more fixing at more expense
Jul 13, 2016 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite model 11027052602 clothes wet after spinning cycle why
You might have a restriction in the outlet hose. Worse, you might have a bad pump.
It is easy to check for the constriction. Pour water into the tub, set the timer for the spin cycle and watch how strong/fast the water leaves the hose. Check for water beneath the tub.
Oct 07, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washer Oasis Model: 11027042603 I have been getting a F1 code error with all wash cycles for the past month. It occurs as soon as I start the wash cycle and with 23 minutes remaining in the...
depending on its age take a look at the motors brushes. sounds like 23 mins would be spin cycle when the motor picks up speed. they may need replacing.
Dec 08, 2013 | Washing Machines
Kenore Elite Oasis top loading washer wont spin during the spin cycle, but will rotate during wash and rinse cycles
Since the motor turns regadless of the direction it turns itself is good and theirfore the problem with your washer i believe is going to be the control board,it is what tells the motor what direction and what speed to turn.
GENE
Sep 23, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
Nov 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
It's an Elite not sure the model number but I have a leak from underneath after the clothes are washed and when the water is discharged before the spin cycle.
this could be a broken hose or a leak from the water pump , if you have an access panel in the back u can check this , or access from underneath
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
