Question about Samsung Dishwashers
Fills, drains but does not wash
- About 1.5 years old (I am pretty sure this is it:http://www.samsung.com/ca/consumer/home-appliances/dishwashers/dishwashers/DMT610RHS/XAC) - Fills with water and display indicates it is washing however, aside from a few clicks nothing is happening inside. - Display continues to show the machine is going through the cycle and then it drains. Any suggestions? THANK YOU!
  • Leigh VanderMeer Jul 26, 2013
    I should add that there are no error codes
SOURCE: Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Posted on Sep 04, 2009
Rotu
  • 175 Answers
SOURCE: washer
If I'm not mistaken, these dishwashers are built by Asko for Viking. If thats the case then you probably have a bad circulation pump. Under Asko's warranty (not sure if Viking is the same) these pumps are covered parts and labor for 3 years from installation date, and 5 years for the part only. The pump is accesed from the back of the machine,so you have to pull out the dishwasher. Then you remove the lower plate in the rear and the motor at the very back center is the pump. You remove it by turning it about a 1/4 turn either clockwise or counter clockwise, depending on the style, then place the new one in and turn it to lock it in place, being careful that the sealing oring stays in place or youll get a leak. The part will probably cost you around $150 unless viking marks theirs up more than Asko. Good Luck!
Posted on Nov 23, 2006
  • 1462 Answers
SOURCE: Does not appear to wash
is there a low humming noise when it should be washing? if so may be the motor capacitor
Posted on Apr 04, 2007
bigg t
  • 640 Answers
SOURCE: Dishwasher tub slowly fills with water after after completion
the internal parts of the valve are sticking open randomley.the diaphram/piston in the valve most likley have lime deposits on it due to poor water quality.you would need the water valve assembly but before you buy this part i would look where the water line goes into the dishwasher and it will lead you to the valve.remove the valve from the unit and disassemble the valve.clean all the internal parts in the valve and reinstall.75% of the time this works ,if not change the valve.
Posted on Jan 24, 2008
  • 636 Answers
SOURCE: Dishwasher will not go thru wash cycles
if the water is not draining at all in any of the cycle it is probably the discharged line at the bottom of the pump has become blocked. there is an access panel at the bottom of the dishwasher which will allow you access the line. take the line off of the fitting , use a set of vise grips to remove the fitting from the base of the pump.You will probably find corn or rice lodged in the diaphragm within the fitting, remove debris and reinsert the fitting and hose. Hopefully this is helpful to you.
Posted on Jul 09, 2009
My whirlpool WDT720PADM1 dishwasher 1 year old fills & drains but will not wash
The only thing that can really cause this is the control panel of the dish washer.
Dec 03, 2016 | Whirlpool Dishwashers
Amana washer quit agitating and also drains and fills endlessly. Only 2 years old. What part is failing?
First check the drain hose isn't too far down the drain pipe it should only be about 6 inches down too much and it will siphon out
Jun 16, 2015 | Amana Washing Machines
My washing machine is not changing cycles. It fills, drains and refills. It sat unused for 1 year. 12 months ago it was working fine.
Hi there. I can help you.
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. If this is the case, turn off the water and remove the hoses. Check both hoses to be sure the filter screens are not clogged with crud and that the hoses aren't kinked.
Jun 18, 2009 | GE WSXH208A Front Load Washer
Washer fills but will not spin or agitate? 1 year
Check waste hose not pushed to far down tube.This would cause same problem
Jun 11, 2009 | Washing Machines
Will only fill and drain
It sounds like the timer/controler is broken replace it. Peter
Mar 18, 2009 | Washing Machines
Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Dec 18, 2007 | Washing Machines
Washer fills, drains instead of agitating, fills, etc
ON THIS MACHINE WHEN IT AGGITATES MOTOR ROTATES ONE DIRECTION, WHEN IT PUMPS OUT AND SPINS IT ROTATES THE OPPOSITE DIRECTION. YOUR MACHINE IS ROTATING THE WRONG DIRECTION WHEN IT FILLS., INDICATING THAT THE TIMER IS SENDING VOLTAGE TO WRONG WIRES. SOLUTION , REPLACE TIMER.
PS: MAKE SURE ALL WIRES ARE PLUGGED IN TO MOTOR. WHILE THIS IS UNLIKELY , I HAVE SEEN THIS BE THE PROBLEM.
FXIT
FXIT
FXIT
Nov 24, 2007 | Admiral AW22 Top Load Washer
Dishwashers Logo
50 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
