Question about Garden
HOW TO REPLACE THE STARTER ROPE ON A WEEDWACKER
    Problem Solver:
  • 8 Answers
To save the hastle of reading, here is a step-by-step guide.
Posted on Aug 01, 2013
3 Suggested Answers
s_s_m_o_k_i_
  • 162 Answers
SOURCE: Craftsman weedwacker 358.791070 suddenly stopped
could have been caused by any number of thing's,
take the recoil assembly off and try pulling the rope out while holding the center of the rope spool just enuff to prevent it from popping out in case there's nothing holding it there.
rewinding the rope is alot easier than rewinding the recoil spring Trust Me.. lol
Posted on Jul 31, 2009
lindsay836
  • 677 Answers
SOURCE: I have a Husqvarna line trimmer 123L AND i'm
Here is a link that will help you get started. Hope this helps.
http://www.partstree.com/parts/?pn=503858801
Posted on Feb 09, 2010
How to repair rope pull in craftsman weedwacker gas trimmer model No. 316.791940"?"
If you go to searspartsdirect.com an enter the model number for your weedwacker if will show you a diagram of how to remove the rope pull. Hope this helps.
Sep 26, 2016 | Craftsman Garden
How to fix the starting rope on a craftsman weed *******
is the pull rope in front of the engine ???
yes ???
you dont wanna know
Aug 05, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Starter rope is broken how do i replace it
Remove the fuel tank and starter cowl, remove snapped rope.wind the pulley to put tension on the spring approx 7-8 rotations. Put a screwdriver through gaps in pulley and through a gap in top of cowl in order to stop pulley from releasing tension. Burn end of new rope and twist end with a rag while still hot to make a point at end ( careful not to burn yourself) then feed the pointed end through rope hole on outside of cowl and through the hole in side of plastic pulley. Tie a knot in the rope once its through and on inner of pulley. Fit starter handle to other end of rope.hold rope and remove screwdriver and slowly feed rope back into starter
Jun 19, 2013 | Briggs & Stratton Garden
Starter cord
remove top starter assy. cut grip from old rope ease rope into spool,
when slack remove center screw and carefully pull out spool, tie knot in rope and thread into spool, wind rope [make sure correct size rope]
around spool until full,carefully turn spool into spring 1 turn then replace screw. put rope into notch on spool and wind up 3-6 turns,
replace grip
May 19, 2012 | Mantis 2-Cycle Tiller
Hi, My pull string broke and I am not sure how to get the shaft off to replace the string? I see it looks like there is a bolt down the middle of the shaft but I can not get it to come out. Please help....
Just remove the housing from the motor and let the rest of the machine come out of it. Not sure if this is a blower or trimmer. Some disassembly and removal of parts is required. If you get to your starter recoil unit, you are going to have to pre-load tension on the pulley that holds the rope BEFORE you install the rope, otherwise it will not draw it onto the pulley, This is a step that eludes most and its not that hard, you just turn the pulley so it gets tighter and tighter to turn about 4-6X and then jam it or hold it in place while a helper threads the NEW rope thru the eye in the pulley, ties a knot in it to hold it...then and only then do you let go of the pulley and it draws the rope in. Make sure you have the handle on it during this step or tension will be lost. As far as the bolt down the middle, you may be looking at a coupler for the flex drive on a weedeater or the crankshaft of the engine...otherwise, I'm not sure.
Aug 17, 2010 | Craftsman 27cc 2 Cycle Crank Straight...
The starter rope on my 14PZ push mower broke. How
The starter rope on my Masport push mower broke. How do I replace the rope and/or starter?
Sep 27, 2009 | Garden
Jul 31, 2009 | Garden
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
