Question about BenQ DC2300 Digital Camera
SET UP SCREEN WILL NOT GO AWAY
The camera was fine one day & then the next I turned it on & it shows the set up module. I can not exit out of it. Can't use the camera. I'm in Singapore and this is a colleagues camera. Please assist with a quick fix and if this is something I may have caused.
    Genius:
  • 2,985 Answers
I think this problem indicates a failure of the main board - possibly high humidity affecting the internals. You could try putting the camera in a snap shut poly bag with a cloth tie of rice or salt and placing all in dry environment. This is to attempt to dry out the camera. Remove the batteries and memory card when doing so. But please appreciate the condition may be Fatal already.
Posted on Aug 30, 2007
6ya staff
SOURCE:
Setting an ultronic touch screen alarm clock
TD00552: 12 hr--military time toggle= tap time set button. Set time= hold down time set button till up & down arrows show on r & l sides; set hour, tap time set button, then set minutes, repeat, seconds, repeat. Date change= tap hour if needed to show day & month; then hold set button on left till up & down buttons show at edges of screen. Up/down buttons to set year on lower right screen, tap set again to change # day of month, tap set again to change month, and the day will correct itself. Change temp c° -- f°= tap alarm button if needed to display temp b them tap set button next to it to change temp scale. Alarm- off/on= tap screen button if needed to show alarm time; tap alarm set button next to it- it will toggle on/off. To set= with alarm time showering, hold down alarm set button till up/down buttons show; follow same process as above.
You are all welcome ??
Jul 01, 2017 | Televison & Video
Micromax x510 - camera module not ready
I purchased Micromax Van Goh last month. Within few days of usage it is giving following error when I try to use camera or camcorder:Error ''Camera Module Not Ready''. Any solutions?
Jul 13, 2011 | Nokia N95 Cellular Phone
When I turn on my Canon PC 1130 to take a picture, the lcd screen and view finder just show a black screen. Camera is working fine in the play mode. Please help.
Set the camera in TV mode, (delayed shutter mode) set the shutter at 15 sec, click to take a picture and during that 15 secs (like, after 7 seconds) open the battery compartment which cuts contact with the battery circuit. Close the battery cover. At this point the camera works fine ... but only temporarily.... Here is the key to the permanent fix. While the camera is working via the temporary fix, take many, many pictures. Hundreds! I probably snapped 400-600 pics. The idea is to wear down the little patches of hardened oil on the shutter blades. For the next three days I took hundreds of pics each day. Basically, I just aimed the camera at the wall or whatever and snapped off several hundred pics.
Jan 05, 2011 | Canon Cameras
Utilitech model 0141224 wall switch timer. used on outdoor lighting to set up to 7 on/off cycles each day. im trying to turn on my porch light in the evening and off in the morning. there are NO...
As luck would have it I'm 60, and learned how to program your 0141224 wall switch timer.
You can see instructions with big print and pictures on following page.
Press CTRL key on keyboard and use scroll wheel on mouse to make web print bigger.
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Add a comment any time.
You have wired your timer correctly and the lights turn on when you push on-off button.
If lights do not turn on, we need to review the wiring.
Your timer looks like photo below.
I'm going to parrot back the manual with some extra words.
To start, press the reset button and clear any programming
Programing overview:
Each program has ON time ... and OFF time
So you set program1 ON and then set program1 OFF
When you set program1 ON, you choose the Day, hour and minute you want program1 to turn ON.
And then you set program1 OFF, and choose Day, hour and minute for program1 to turn OFF.
Your ON-OFF times for program1 should be on same days.
For example program1 ON for all-days-of-the-week, but program1 OFF is for TU Tuesday, then timer will not work.
IN this case, program1 OFF should also be set for all-days-of-the-week.
Let's start.
Setting the clock:
Press and hold CLOCK button
Keep holding CLOCK button and press DAY button until display shows current day (MO TU WE TH FR SA SU)
Press Hour button until current hour with am pm displays
Press MIN button until current minute displays.
Release clock button and current day and time show on display
At no other part of instructions do you press and hold one button while pressing other button.
Setting programs:
Press PROG button until "1" and 'ON' show on display
This is program1 ON
Press DAY button to choose which days for program1 ON.
You can choose: all-days-of-the-week and MO TU WE TH FR SA SU show on display
Choose individual days and MO or TU etc shows in display
Choose weekdays MO TU WED TH FR
Weekends SA SU show in display
Next step
Press HOUR button to select hour for program1 ON
Press MIN to select minute for program1 ON
Now program1 ON is ready, next, you will set program1 OFF
Press PROG button until "1" and 'OFF' shows on display
This is program1 OFF
Press DAY button to choose which days for program1 OFF.
( Remember, you want same days for ON and OFF)
Press HOUR button to select hour for program1 OFF
Press MIN to select minute for program1 OFF
Now program1 ON and OFF are ready, next, you will set program2 ON by repeating same steps above.
You can set up to 7 programs.
If you don't want to set program2, or any more programs, that's fine.
To exit programming and save your program, press CLOCK.
Now current time shows in display.
Final step: set MODE
Press MODE button until AUTO shows in display. You want AUTO for programming to operate lights. That's it, timer is ready.
If you're going on vacation, press MODE button until RDM shows in display, and then timer turns lights on-off at random
Copy and save these instructions to your computer so you have them next year.
Dec 04, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How do u get hourly beep to turn off on digital watch
To set time, date, and options:
1) With time and date showing, press and hold SET.
2) Current time zone (1, 2, or 3) flashes. Press + or to select time zone to set, if desired.
3) Press NEXT. Hour flashes. Press + or to change hour (including AM/PM); hold button to scan values
4) Press NEXT. Minutes flash. Press + or to change minutes
5) Press NEXT. Seconds flash. Press + or to set seconds to zero.
6) Press NEXT. Month flashes. Press + or to change month.
7) Press NEXT. Day flashes. Press + or to change day.
8) Press NEXT. Year flashes. Press + or to change year.
9) Press NEXT to set options. Press + or to change value and then press NEXT to go to next option. Press DONE at any
step to exit and save settings. Available options are 12- or 24-hour time format, MM-DD or DD.MM date format, hourly
chime N, beep for button presses, customizable mode set (Select “HIDE” for unwanted modes – they are removed
from mode sequence).
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Aug 31, 2010 | Timex Watches
When I hold down remote lock or unlock button to set, horn doesn'
Setting can be accesed through the radio to change options. Follor the owners manual.
Feb 25, 2010 | 2005 Chevrolet Malibu
How do you change the Date Time Stamp in the GoPro Hero series of cameras?
Taken from manual:
SETTING THE TIME AND DATE
You can set the time and date on the camera as long as the battery stays in the camera. Once the battery is
removed the time and date settings will be lost:
Symbol on LCD Screen Function
When you see "dAt" on the screen, press SHUTTER button to set the
time and date.
Press POWER/MODE button to toggle from Y09 (2009) to Y30 (2030).
Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 01 (January) to 12 (December).
Press POWER/MODE button to toggle from d01 (1st day of month) to d31
(31st day of month). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from H00 (12 a.m. military time) to H23
(11 p.m. military time). Press SHUTTER to advance to next date setting.
Press POWER/MODE button to toggle from 00 (zero minutes) to 59 (59
minutes). Press SHUTTER to advance to next date setting.
1. Once you select the "minutes" setting and press the SHUTTER button, you will return to the SEt entrance
for the settings menu.
EXITING THE SETTINGS MENU
When you see ESC on the screen, press the SHUTTER button to exit the SETTINGS MENU.
Dec 21, 2009 | GoPro Motorsports Hero GMHW50 Digital...
How to set a timex i-control watch
switch to time mode, and hold the middle buton on the left side until the watch shows SET TIME. press the next track button to set the hour (blinking on the screen) by pressing the + and - buttons to change the value. press the next track button to move to minutes, then seconds, then month, then day, and then year all being changed by the + or - buttons. then press the left middle button to exit. Congratulations, you just set your watch :D
Sep 23, 2009 | Timex i-Control 29571 Wrist Watch
Flashing horizontal stripes on screen while shooting
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 18, 2007 | Canon PowerShot A70 Digital Camera
Auto Convergence
Let it go through the complete set up process again without stopping it. This might include letting it autoprogram the channel memory.
Apr 11, 2007 | RCA Scenium D40W20 40" Rear Projection...
BenQ DC2300 Digital Camera Logo
Top BenQ Cameras Experts
Damen Wong
Damen Wong
scramblepad
scramblepad
Vincent G
Vincent G
Are you a BenQ Camera Expert? Answer questions, earn points and help others
