Question about Samsung La32c530 32" 1080p Full Hd Multisystem Lcd Tv
How to fix double image?
Factory reset did not work
Double image
Use this link to get company support:
http://www.necvisualsystems.com/SupportCenter/SupportTracker/
Apr 13, 2008 | NEC MultiSync MT840 Multimedia Projector
Double image on the first copy only
try to reset your printer. Turn off, remove the power supply from the socket leave it for 30 mins and turn it on again. try one copy at a time
Sep 21, 2007 | Office Equipment & Supplies
My tv is showing a double image like a ghost image just slightly below the normal image.. is my tv bust or is there a way to fix it? i've alreADY tried resetting and factory reset
There are many reasons for this fault. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), or "Double image" in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 09, 2016 | Bush 42" LCD TV 1920x1080, 50 Hz, Freeview...
Hyundai lcd tv HY2240FHF DOUBLE IMAGE PROBLEM.. Solution please?tell me remte factory mode?
It seems to be the fault with its main digital board. [Vertical synchronization problem]. Anyway, try a factory reset.
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 19, 2016 | Hyundai Televison & Video
LCD Thomson 32LB040S5
I assume you have already tried using the buttons on the side of the TV to adjust it? I would just do a factory reset on it. Enter the TV main menu. Select factory reset to return the TV Menu settings to the factory default values. If this does not fix it unplug to TV for 45min to do a complete hard reset.
May 20, 2013 | Thomson Televison & Video
How do i fix double image and green and blue seperation
Typically it is fairly easy to determine weather you need to do a convergence repair or just make an adjustment with your TV's original remote. Take a look at this youtube video to find out which problem you have...
Nov 22, 2011 | Hitachi 51UWX20B 51" Rear Projection...
On my sony dslr a 300 the steady shot warning flashes at the bottom of the view screen like it is not able to steady the shot. this makes it is very hard to take a clear picture without it working...
Before you junk it, double check to make sure steady shot wasn't turned off. Also see if raising the ISO settings and increasing the aperture size fixes the motion blur (this will make image noise and depth of view blur increase though). Lastly Try resetting the camera to factory settings as a last resort.
Hope this helps.
Mar 25, 2011 | Cameras
I have a TSST corp CD DVDW TS-L632N ATA driver on my HP computer... Today it wasn't working, It said that the device could not start. It has the latest software. A month ago I had the same problem and...
Thats most likely your upper/lower filters, or drivers acting up.
Try drivers first, as they are easier and faster to fix. Go to device manager under system properties, and uninstall the dvd device and reinstall it.
If it doesn't work delete the upper and lower filters:
Press windows and R keys type in "regedit" and press enter
double click on "computer" on the new window that came up
double click on "HKEY_LOCAL_MACHINE"
double click on "SYSTEM"
double click on "CurrentControlSet"
double click on "Control"
double click on "Class"
double click on "{4D36E965-E325-11CE-BFC1-08002BE10318}
Look on the right side of the window
Delete the item called "lower filter" and "upper filter"
once deleted, close the registry editor and restart your computer.
Dec 30, 2009 | HP Computers & Internet
Image go off
I have had the same problem. I've just managed to get the monitor working again by VERY QUICKLY navigating through the monitor setup menu to the 'factory reset' option and hitting reset before the screen had a chance to blink off.
The problem I had is that the monitor suddenly goes black, but will come on for five seconds if I switch it off and on with the power button.
In that five seconds, I had to...
>Hit the menu button
>then hit the '+; button once
>then hit the menu button again
>then hit the '-' button
>then hit the menu button one last time
The above brings up the menu, scrolls up off the top of the list to the last item on the list (Factory Reset), selects Factory Reset, selects 'All settings' and resets the monitor.
I don't know if this is a permanent fix, but it just worked for me and mine has been doing this intermittently for the last week.
Give it a try, it's frustrating and will take a few tries, but it can't hurt.
Oct 27, 2007 | Dell E173FP 17" LCD Monitor
Samsung La32c530 32" 1080p Full Hd Multisystem Lcd Tv Logo
Jerry Greenberg
Jerry Greenberg
