Konica 4690 a used toner cartridge or non-konica minolta toner cartridge is installed on a Konica 4690
I have a 4690 with the message " wrong toner cartridge installed" after I replaced the magenta toner with a new OEM one
ronenfe
  • 91 Answers
SOURCE: how to install toner cartridge for konica minolta 2430 DL
here are the instructions:
http://onlinehelp.kmprinters.com/CPDocs/q0904029.htm#magicolor%202430%20DL
Posted on Mar 02, 2008
SOURCE: (the infamous) ?X toner not installed? error message
I just got off the phone with KM tech support for the same problem with my 2430dl.  Take out the drum and remove the toner cartridges, then look inside the printer.  You will see a piece of glass about 6" long.  Next to it, on the right side of the printer, there is a little white plastic enclosure that contains three spring-loaded contacts; this is the sensor that reads the chips on the individual cartridges.  First, try cleaning the three contacts with a swab/alcohol, as well as the chips on each cartridge.  If this doesn't solve the problem, then the problem is likely with the sensor.  The part number should be 4139-6306-02, and it runs about $5. This should solve the problem.
Posted on Jan 26, 2009
  • 192 Answers
SOURCE: After replacing black toner cartridge printer displays Drum Low
Ask you companey that surives you printer to look at it
Posted on May 20, 2009
  • 52 Answers
SOURCE: "Can't Detect Genuine Toner Cartridge"
minolta printers work on "chips" if the chip atached to the cartridge is not original minolta you better change it.
Posted on Jun 18, 2009
freetek
  • 5568 Answers
SOURCE: konica minolta pagepro 1350w fatal print spooler
A 'print spooler' is a range of memory either internal to the printer (sometimes called 'buffer memory') or set aside from the RAM in your system. A fatal error normally means the material you tried to print has been lost and must be sent to the printer again. If the error continues to show up, you may have bad printer memory or perhaps the driver software in your system has gotten stepped on by the operating system and needs to be reinstalled. Windows loves trashing files to keep life exciting.
This problem is not related to the drum or toner cartridge.
Posted on Oct 10, 2009
Not installed toner check Y error message
replace the yellow toner container with OEM NOT THIRD PARTY
Jan 27, 2016 | Konica Minolta Magicolor 4690 MF Laser...
Konica minolta bizhub C253 is showing me trouble code C- 2556. What should I do to pix this problem
Konica-Minolta bizhub C253 Trouble Error Codes List page 4
Code C2556
Abnormally high toner density detected yellow TCR sensor
• TC ratio in the developing machine, which is determined by toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively. • When the connector of the TCR sensor is disconnected.
Solution:
1 Reinstall imaging unit. 2 Reinstall toner cartridge. 3 M3, M4 operation check (At this time, IU must be non-installation.). 4 Change imaging unit. 5 Change PRCB
Extract from:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C253&page=4
Nov 14, 2015 | Konica Minolta Office Equipment & Supplies
Toner not insatlled magiccolor 4690
Remove a toner cartridge and verify a home position sensor or other components associated.If the cartridge is refill change the chip.
Dec 21, 2013 | Konica Minolta Magicolor 4690MF...
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
D C LIFE MESSAGE COMES ON
Which cartridge there are two one is toner the other is the drum which is where the toner cartridge is installed.
Feb 17, 2009 | Konica Minolta Minolta FAX3900 Digital...
Oct 28, 2007 | Konica Minolta PagePro 1350W Laser Printer
27 people viewed this question
jasbo
jasbo
