Reading usb no response after inserting into USB
If you are inserting the USB into a PC and it does not automatically recognize it go to "My Computer" then look for it there under "Devices with removable storage"
Click on the device and that should allow you to access you have on that USB.
If you are installing hardware with a USB connection, then you may have to go to the "Control Panel" then look for "Hardware and Sound" then "Devices and Printers" and then you can either install the device or the printer from there if you have the software for it.
Posted on Jul 26, 2013
USB hard drive to side USB inlets
Sometimes the USB socket is for setting up the firmware or to read photographs from a USB stick.
Jan 09, 2015 | Televison & Video
Re MiBody 360 Personal scale. downloaded software successfully (Windows XP) inserted USB into scale and stepped on . waited for a few seconds then put USB in PC but no data transferred (PC recognised USB...
Make sure that you have selected USR1 each time you weigh yourself.
When you stand on the scales it records your measurements against that user ID and holds them in the internal memory of the scales.
When you have taken a few readings and when you are not standing on the scales, insert your USB memory stick (any memory stick will do) and press the SET button. The scales display "USB" and write the data out to the memory stick and gives you a message "END" afterwards. When you insert the memory stick into your computer you can read the data into the Homedics software
Aug 26, 2013 | Health & Beauty
My printer is off line
1. check that ur usb cable is working by changing with a new one
2. remove d black cartridge n close door/lid
3. if no response, do same wit color cartridge
4. insert into another usb port on computer
5. if no response still, remove cartridges and clean printer interface with a cotton wool and methylated spirit
Jan 09, 2013 | HP Deskjet D2360 InkJet Printer
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pyle pl88mu its not reeding the USB flash driver everything else works fine but the usb its not working and i tried with 3 different USB's
  • Typically these units can only read FAT32 formated drives. check to make sure that the drive is formated FAT32.
  • You can insert the USB drive in to your computer. Go to Start -> My Computer then navigate to the USB Drive. Right click on the drive and view properties. Check under file system. If it says NTFS please continue reading.
  • You can format your USB medium on your PC to FAT32 then copy your media (music) to the the USB drive.
  • Insert your USB Drive to the PC On your PC navigate to Start ->MY Computer Then locate your the drive that is your USB Drive. At this time you will want to save any of your data before continuing. All Data on the USB drive will be lost. Next ensure that you have selected the correct drive.
  • Right Click on the drive on go to format... Under File System select FAT32. I would suggest leaving Quick Format unchecked. So you ensure that will information is removed. Then Click start. Next copy your media (music) back to the USB Drive.
  • Try inserting back in to your stereo.
Hope that helps, don't forget to vote.
Nov 16, 2010 | Pyle PL88MU
The computer reads the mouse and the usb thing as working properly but the when i move the mouse the cursor stays there so basically my mouse isnt responding at all
Hello Dear... Mouse cursor don't response, It possible your usb port fail to response because one of your usb drivers is missing ...To find out about it please, check in your setting control panel, click on system then on hardware then on device manager.. it will show a yellow icon ...this icon need to be install or re-install due to corrupt file inside your machine...To fix that problem delete that icon and restart your PC then your pc will ask you to insert you windows CD to re-install the corrupt file for your usb controller..
Oct 15, 2010 | Microsoft Wireless Notebook Optical Mouse...
The usb connection on my new Tevion 5705 won't read the music from my usb key. the usb key has been re-formatted to a FAT, and then a FAT32, file system and we have then copied the DOS files onto the usb...
Hello I have the same problem but no body do answers . Maby we change radio {panasonic or oder :-). The usb connection on my new Tevion 5705 won't read the music from my usb key. the usb key has been re-formatted to a FAT, and then a FAT32, file system and we have then copied the DOS files onto the usb key along with music files in mp3 & W4ma types though we still can't seem to get the Tevion 5705 car radio to read the music from the usb key when inserted. We keep getting an 'Error 13' message, can someone please help . my email : zadychladislav@hotmail.com Ladi
Aug 13, 2008 | Car Audio & Video
Sony microvault 2 gb
my laptop does not read the usb stick, when i insert it, a pop up says usb device not recognized, and has malfunctioned. I am having this problem after using this usb device in a car stereo system. please advise i need to recover my data from the device. please help me in this issue.
Apr 10, 2008 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
USB devices not seen
i'm looking for those with question marks or exclamation points...
Mar 28, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
