Question about Worldwide 1996 Pontiac Grand Am SE 3.1L Alternator - 105 Amps
How do you reprogram cluster in 1996 grand am 3.1
I changed the instrument panel in the car and now the car does not start ,how do I fix the problem?
    New Friend:
  • 51 Answers
Hi you will have to recode with a scaner
Posted on Oct 02, 2013
How to replace the headlight switch assembly on a 1997 dodge grand caravan
The best I can offer is for a 1996 caravan:
REMOVAL
  1. Remove steering column cover.
  2. Remove over steering column bezel.
  3. Remove left end cover.
  4. Remove screw at left end of cluster bezel and headlamp switch.
  5. Remove screws holding cluster bezel to instrument panel from each side of steering column.
  6. Disconnect clip holding cluster bezel to instrument panel from above right vent louver.
  7. Separate cluster bezel from instrument panel.
Disconnect wire connectors from back of the bezel.
INSTALLATION
  1. Connect wire connectors into back of the bezel.
  2. Place cluster bezel in position on instrument panel. Use care not to place hands on louvers.
  3. Connect clips to hold cluster bezel to instrument panel. Use care not to add pressure on the A/C louvers to seat the cluster bezel clips.
  4. Install screws to hold cluster bezel to instrument panel on each side of steering column.
  5. Install screw at left end of cluster bezel and headlamp switch.
  6. Install left end cover.
  7. Install over steering column bezel.
  8. Install lower steering column cover.
May 02, 2015 | 1997 Dodge Grand Caravan
Is there a reset for security when replacing the cluster on a 1996 pontiac grand AM?instrument cluster
If you have a chipped key with a transponder you might find like the vw the clocks have to be programmed to the cars ecu as the car won't start part of the immobiliser system
Apr 06, 2014 | Cars & Trucks
I have a 1996 Plymouth Grand Voyager with a 3.3 L engine that has an instrument cluster problem.
check all motor to body ground straps and all wiring harness to body ground straps.
Dec 19, 2013 | Plymouth Voyager Cars & Trucks
1996 grand am instrument panel cluster is not working
Open driver side door, remove fuse access panel on the left side of the instrument panel and check the instrument cluster 10A fuse behind on the fuse block (third row from the top, fourth fuse position note: first two position may be empty). If fuse checks out the connector behind the instrument cluster may have worked loose. Remove steering column covers, remove bezel around the instrument panel (this is held on with push clips), remove four screws from the cluster and ease the cluster out just enough to see and correct the problem. hope this has helped.
Oct 16, 2011 | 1996 Pontiac Grand Am
Insturmentation panel lights fuse blows when i start car
Try to remove the instrument panel and disconnect the harness to see if doing that gets rid of the blown fuse when starting the car. If it does, then the instrument panel should be replaced with another. If the fuse still blows when starting, then there is a wire shorted to ground somewhere.
Instruments and Switches Instrument Cluster Removal & Installation To Remove:
  1. Remove the instrument cluster trim plate.
  2. Remove the instrument cluster mounting screws.
  3. Rotate the instrument cluster rearward and lift up on the top of the cluster in order to disengage the locating pins.
  4. Disconnect the electrical connectors from the instrument cluster.
  5. Remove the instrument cluster.
To Install:
  1. Connect the electrical connectors to the instrument cluster.
  2. Position the locating pins to the holes in the instrument panel.
  3. Install the instrument cluster by rotating the top inward.
  4. Install the mounting screws.
  5. Install the trim plate.
Nov 09, 2010 | 2001 Pontiac Grand Am SE
The speedometer needs to be reset it is working but not correctly
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Grand Prix instrument cluster repair
Dec 31, 2009 | 2005 Pontiac Grand Prix
'96 grand am starts but stalls out
I had the same problem. I changed the computor, the key switch, the box in the trunk and nothing helped. I traced wires looking for loose connections and found nothing. I did notice that the yellow wire goes to the instrument cluster before going to the computor. All of these parts came from a junkyard so I changed them 2 times each and had the same thing. As a last resort I asked for an instrument cluster. He looked at me like I was crazy. After I changed it it immediately fixed the problem. You have change the odometer from the bad one to the good one. It is easy to change.
Sep 23, 2009 | 1996 Pontiac Grand Am
1996 Pontiac Grand AM Instrument Cluster same as that of 1997?
it is not the same.
if you are changing the cluster because some functions are intermittent,check the solders on the pc board...
May 08, 2009 | 1996 Pontiac Grand Am
1967 Pontiac Tempest
Have you replaced or removed the battery before this happened ? if so disconnect the battery and let it sit for a few minutes. Reconnect the battery and it should reprogram the computer system. I am not completely sure if your car has an instrument cluster fuse but check inside the hood and the fuse panel box.
Oct 31, 2008 | 1996 Pontiac Grand Am
Worldwide 1996 Pontiac Grand Am SE 3.1L Alternator - 105 Amps Logo
Top Worldwide Electrical Supplies Experts
Lawrence Oravetz
Are you a Worldwide Electrical Supply Expert? Answer questions, earn points and help others
