Question about Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum
Little green machine mod.1725-7
Machine is not sucking water into collection tank.
BissellCSR
  • 276 Answers
SOURCE: I need manual for bissell little green proheat
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Posted on Sep 09, 2010
reddevil6
  • 1673 Answers
SOURCE: bissell little green steam machine
There is a small pump inside the unit that may be bad.
Posted on Feb 05, 2008
SOURCE: Dirt/Collection Tank Bissell Little Green
I had the same problem, so I took out the black stopper, and soaked the whole thing in bleach water for about an hour, then I took a hand full of " aquarium " rocks and put them inside the tank, and shook them inside using a bit of the same water and then got rid of the rocks,( the rocks worked as an scrubber ) .... it worked pretty good
Posted on Jan 11, 2009
SOURCE: little green machine
The pump motor solution worked on my Bissell 1400. I did not have to take the vacuum motor out. I also lubed the motor although it looked like it might have sealed bearings, figuring a little WD 40 couldn't hurt.
Posted on Mar 08, 2009
  • 389 Answers
SOURCE: How do you operate the Bissell 1725 LittleGreen Machine Proheat
Go to www.bissell.com then click the Customer Service tab. In the next window click on the User Guides link (in green on left hand side), then enter your model number. You can then download the full instructions.
Posted on Mar 15, 2009
I need manual for bissell little green proheat 1725-7
Aug 17, 2010 | Bissell 1725-1 Little Green ProHeat...
Little Green pro heat is leaking from bottom with very little suction. I just purchased it.
Try the following suggestions for the leaking issue:
- Check to see if the black or white "duck bill" gasket is misassembled or missing from the collection tank; ensure the gasket will open where the flat flaps meet and then reinstall it. The duck bill should be inserted into the curved side of the collection tank.
- Check to see if the solution tank/cap insert is leaking.
Note: When the solution tank is filled and turned right side up, the straw on the insert may fill with water/solution causing the tank to leak for a couple of seconds. This leaking should subside after the straw empties out.
- Check for proper placement of the o-ring on the cap insert. The o-ring should be between the bottle and the insert piece (part with the "straw").
Try the following for the suction issue.
- Remove the Collection tank and locate the circular motor duct on the base of the machine. Turn the machine on and feel for suction at this location. If you feel suction proceed as follows:
- Remove the gasket from the bottom of the Collection Tank. Ensure that this gasket is open (not sealed shut) at the top of the gasket where the flaps meet. If the end is not open, simply squeeze the end to open it. The “duck bill” shaped portion of this gasket should align with the rounded side of the Collection Tank.
- Check to make sure there are no cracks in the flexible vacuum hose or in the tool you are using.
- Make sure the collection tank latch is locked down securely.
- Check for suction at the end of the hose with the attachment off by suctioning water out of the sink or a cup. If there is low/poor suction, check the hose for clogs by raising the hose handle above the unit to allow the water to go into the collection tank.
The issues may be related as you can see some of the suggestions are similar.
Aug 04, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Can't clean little green collection tank
You could try a solution of hot water and baking soda. Works very well for coffee residue on a carafe. Dilute and filter the soda before pouring solution into the tank . then hold the tank and swirl.
Sep 06, 2009 | Bissell 1400 Little Green Pro Canister...
Tank not collecting dirty water
You most likely have a break in your suction hose. check at the base where it attaches. When you bring back the handle release, you can see lt. If you have the type that has the external plug in for the water, then you probably don't have the hose part plugged in to the collection tank. in the front of the collection tank. Your motor shut off? Well, If you have the first variety cleaner w/built in hose, you may have sucked water into/onto your motor. If this is the case you need to bring it for service. otherwise, you could have a blockage in your collection hose, this would also explain the machine shut down, from the thermosat. A clogged machine will ultimately overheat, wont run again till cooled.
Jul 18, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaning the bissell little green
take the jugs off the sides and wash the base. out with bleach water,also fill the solution tank with bleach water and shake well to remove the mildew and dirt from the tanks
Apr 27, 2009 | Bissell 1400 Little Green Pro Canister...
Mar 15, 2009 | Bissell 1725-1 Little Green ProHeat...
Sep 22, 2008 | Bissell 1400 Little Green Pro Canister...
Bissell THE BISSELL LITTLE GREEN MACHINE Vacuum Logo
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
