Question about Solar 30 Amp Twist Lock To Rv Pigtail Adapter Kipor Generator
220 volt power coleman - Solar 30 Amp Twist Lock To Rv Pigtail Adapter Kipor Generator
Which holes an the 220 outlet on my generator are the hot ones
The ones on the left and right are the lines ( 120 volts ) the top one is the neutral and the botton with the small L is the ground.
Jun 19, 2014 | Coleman Powermate Premium Plus 6250W...
Won't generate power after hooking to home electrical system
You have blown the stator and possibly the rotor due to back feeding
Mar 09, 2012 | Coleman Powermate Premium Plus 6250W...
The generator produce onely 73 volts ac on the 120 volts plug and 146 volts ac on the 220 volts plug . what could be causing this problem
Check all wiring and fuses associated with you voltage regulator if they check ok, find a way to adjust your voltage regulator replace it. Make sure the unit is running at 3600 rpm as well and making 60 hz.
Jul 10, 2011 | Coleman Powermate Premium Plus 6250W...
I have a coleman powermate 6250 generator with a 4prong 220v female plug on the power panel. My travel trailer has a 3 prong male plug. How can I convert my generator or is there an adapter that I can...
You do not want to convert anything to a 220 v connection !!!! Your RV is 12 volt DC and 120 volt AC.
Use a 30amp female to 15 amp male adapter to plug in to regular household receptacle on generator. Available at hardware store and RV stores.
Apr 27, 2011 | Coleman Powermate Premium Plus 6250W...
"I was welding with a
Your generator is a welder?? Yikes, the 220 volts coming out of the genny is not the same as the 220 volts running a welder, it is, but it isn't, the 220 volts used to run the welder are transformed into DC, in the 50 -150 amp range, the 220 volts coming out of your genny is 220 volts, AC, at 30-40-50 amps. Now exactly how were you welding with 220 volts AC? Remove anything plugged into the genny, check the oil, check the gas, make sure it is fresh, check the breakers, check the fuses, get it running, now don't try to weld with it again. Unless you have a big welder to plug into it and I wouldn't even do that because of the generator spikes. I might be wrong, but I have never seen a genny with a welder on it for home use.
Feb 06, 2011 | Coleman Powermate Powermate 5000W...
Coleman powermate 4000 pops circuit breaker on the 220 side.
Don't know what you mean by "on the 220 side".
The generator has two joined circuit breakers that each are 110 volts. Between the two is 220.
If just one of those is opening WITH NOTHING PLUGGED IN, then there are only a few explanations.
1. There is a short in the wiring or the wiring has been tampered with and connected incorrectely.
2. The switch that switches the mode from 120 to 240 has gone bad, possibly with a welded contact. This would occur if the switch is changed with load on the generator. This could put a driect short on half the generator winding and cause one of the breakers to blow.
3. Worst is a winding short in the generator. Fortunately this is the least likely.
4. The 220 receptacle has been broken and insulation failed shorting one terminal to another.
Nov 14, 2009 | Coleman Powermate Premium Plus 6250W...
Generator starts but gives no 220 volt electric
This is a frequency issue 50 hertz for Europe, 60 hertz in US. It's speed related. Faster RPM for 60 Hz
Jun 26, 2009 | Coleman Powermate Premium Plus 6250W...
Runs great but will not produce electricity
To flash the excitor circuit on a coleman ( the generator is built by generac) you need a 12 volt battery. You quickly apply 12 volts via your 120vac recepticals. NO MORE THAN ONE OR TWO SECONDS! Then check you ac voltage. Most of the time the brushes are burnt up when voltage is low. Check the brushes first. You can access them by taking the end cap off of the generator via two to four screws. The brush holder is easy to spot, two wires leading to the front of the amature. Hope this solves your problem.
Mar 29, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman 11 gallon air compressor wont start
Sometimes the initial start up with the tank at 0 psi electric power is adequate. However when the tank is full or the garage is cold it is a bigger load for start up. Check your overload (reset button) and breaker. If 220 volts one side of the breaker could be tripped without showing.
Feb 14, 2009 | Coleman Powermate 11 Gallon Air Compressor
Solar 30 Amp Twist Lock To Rv Pigtail Adapter Kipor Generator Logo
15 people viewed this question
Top Solar Electrical Supplies Experts
Steve
loft404
loft404
Level 1 Expert
Craig Butler
Craig Butler
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
