Question about Cat5e Computers & Internet
25m and no signal
Hello, I am trying to connect a 3Com Switch with a 25m CAT 5e patch cable to another switch. Not working, no signal. I changed the cable and switches. No signal. Any ideas, maybe the cable quality?
  • Marco Jul 26, 2013
    Cable: Patch Cable 4x24AWG CAT 5e UTP 4662 M
    I am using the same cable on the 3COM Switch with 15m lenght. Working fine!
    Master:
  • 678 Answers
Two equipments of the same type - two computers, two routers, two switches - should be connected with a crossover cable.
Posted on Aug 13, 2013
3com Switch Intermittently Losing Connection.
this could be a problem with the second switch unit. what happens if you connect a pc to this cable, is that intermittent, if so, that is your problem. try fault finding with a LAN cable tester to see if there's any issue with the link cable.
Jul 16, 2013 | 3Com Baseline Switch 2024 24-Port...
I have two computers. One is connected to the internet with a cat 5 cable. I bought a new cable for the new computer which is a fastcat 5. However, I cannot get this computer to work on the internet. If i...
I'm assuming that you have a modem or a modem and router combination with multiple cat5 ourputs. You have tried both computers with the Cat5 cable and they both work fine. If this is the case, I would suspect that you have a faulty fastcat 5 cable.
Feb 14, 2011 | PC Connection FastCAT 5e Patch Cable...
Hello I need to hardwire a tripplite n001-010-bl catse cable to a belkin cat5e keystone jack bel-r6d024-ab5e I do not know the correct wiring configuration to do this. Please advise?
The wiring is done as if you are building your own CAT5e wire. See the following URL: http://www.beginnercode.com/2006/11/09/connecting-network-cable-ends/ . There are other sites. As long as both ends are the same the cable will work (unless you want a crossover connection).
For a PDF version see: http://www.n-tron.com/pdf/cat5ecableschemes.pdf .
I hope this helps.
(Keystone jacks for ethernet come in two types: plug in RJ-45 and punch down the individual wires with the tool. All of the punch down jacks came with a diagram, had the wire arrangement indicated on the unit, and a cheap plastic punch down tool.)
Jan 17, 2011 | Tripp Lite TRIPPLITE N001-010-BL Snagless...
I want basic block diagram of plenum cable
All Cat 5e jacks and patch panels are color coded, making it simple to get the correct wire in the correct position on the jack or etc.
Here is a basic diagram:
Hope this helps!
Aug 14, 2010 | Superior Essex Marathon LAN Cat 5e Bulk...
Need to connect my adsl router (MT882)with D'link DES-1008V switch. I have used cross cable as well as straight cable to connect them. PROBLEM: "physical Connectivity is down".
Cross cable won't work on Router you need a patch cord. Buy a patch cord of CAT-5 category and you you will able to connect Adsl Router.
Apr 26, 2009 | Computers & Internet
How do I wire up a cat 5e socket to extend my network.
hi, good morning, i'm here to help, the modules should be color coded and the cat 5e will have the same colored wiring when you strip off the jacket, you should use a puch down tool, punch down the 5e wires into the corresponding colors of the module, strip a small portion of the 5e jacket but not the inner pairs of cable, untwist the inner cables and insert and punch down the pairs, the modules should come with some kind of instructions, please let me know if i can be of anymore help
Mar 19, 2009 | Computers & Internet
My eurovox wont update but i am with chorus in ireland
all new software, updates manuals and everything else to do with eurovox is here http://allsportsforus.OurToolbar.com/
Download my toolbar for free and there is eurovox tab on it that will give u access to everthing.
Feb 19, 2009 | Tripp Lite TRIPPLITE N001-010-BL Snagless...
What is UTP CAT 5e cabel?
This 1000 foot, spool-boxed roll of grey Cat5e bulk cable is a must-have for extensive networking. This unterminated and UTP (unshielded twisted pair) cable is perfect for a plethora of networking applications.
Cat-5e, enhanced Cat-5 cable, is the standard for modern networking - enabled for far end crosstalk and compliant with up to 1000BASE-T standards. This unshielded cable comes in its own spool box and is connector free, giving the user the freedom to customize the length, wiring, and application.
This cable is 1000 feet long and are marked at every foot (marked 0001 - 1000 at each foot).
Wire the cable as either a patch or a crossover cable, use it for Ethernet or any other data transfer applications. Sewell Direct works hard to bring you affordable Cat5e bulk cable solutions.
Jan 13, 2009 | Intellinet Active Networking CAT5e UTP...
Lan cable Setting for Switch & PC to PC LAN Connection.
If you are asking about connecting two computers together with a hub or switch, plug them into the switch/hub with standard patch cables (cat 5e or cat 6).
If you are asking about connecting two computers together directly using a LAN cable, then you will need a "Crossover" cable (cat 5e) wired specially (oranges transposed at one end for the common -B pattern) for direct LAN connection.
Jan 01, 2009 | Computers & Internet
Computers & Internet Logo
85 people viewed this question
Top Cat5e Computers & Internet Experts
KG John Justin
KG John Justin
Vuk B
Rishi Solutions
Rishi Solutions
Are you a Cat5e Computer and Internet Expert? Answer questions, earn points and help others
