Question about AEG 23 in. Favorit 86070Vi Built-In Dishwasher
Error 10 code stops program. Checked underneath - no leaks visible. Checked drainage hoses and traps - all clear. Water clearly visible to left of salt compartment then level rises and beeps start. Any suggestions?
2 Suggested Answers
SOURCE: AEG 40850 not filling after leak
check pcb board sounds like its blown something
Posted on Mar 01, 2014
Testimonial: "Hi Martyn, thanks for the post. Any idea where the pcb is on the 40850, its not obvious, only pumps and pipes in the bottom tray and some small potted components."
What does E20 mean
The E20 error code indicates a problem with water drainage. Inspect the drainage hose for kinks that could impede the drainage flow. This frequently occurs when the machine is pushed up against the wall without allowing room for the hoses. If there are no kinks, the hose is probably clogged. Carefully detach the hose from the machine, and use a garden hose to force water through it. If the water doesn't pass through, use a plumber's snake to clear the clog. If there is no clog, inspect the drain pump for clogs. Unplug the machine, and open the small rectangular door towards the bottom of the front of the machine. Drain the pump through the emptying hose into a container until the water flow stops, and rotate the pump impeller to clear any foreign objects. Close the pump and restart the cycle. If the problem persists, contact a service center.
May 18, 2012 | Zanussi ZWF1430W Front Load Washer
My Kenmore Elite HE5T front loading washer is giving me an F20 (Water inlet problem - no water or insufficient water supply) code. The Drum fills half way up with water in about 5 minutes and then the...
The F20 error deals with the water coming into the tub. The F20 code indicates the control didn't see any water enter the tub.
  1. There is a flow meter that tells the control water is coming into the washer. If the flow meter is faulty the error usually happens quickly.
  2. Near the pressure switch is a clear plastic hose may be kinked or even have a small hole in it. Check the drain line first and then remove the top of the washer to access the pressure switch and pressure hose. With the washer empty remove the hose from the pressure switch located on the right side of the washer and blow through it to clear any debris blocking the pressure hose or air trap.
  3. If this doesn't help then most likely you will need to replace the pressure switch.
Feb 25, 2011 | Kenmore Elite 45986 Front Load Washer
Water leaks from underneath Indesit WG1130d washing machine.
I had a problem like this and it turned out to be the hose that carried the water out to the drain was overflowing the drain pipe.
Make sure the P trap in your drain line is open and clear. A plumbers snake, draino, or a high pressure nozzle on your garden hose might help to clear it.
Oct 04, 2017 | Indesit W 123 Front Load Washer
Error code e20
error code means that the coin trap/drain pump hose underneath the machine needs cleaned out due to being blocked.
Jan 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
Samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
May 07, 2008 | Samsung WF337AA Front Load Washer
AEG 23 in. Favorit 86070Vi Built-In Dishwasher Logo
63 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
