Question about Garden
Please. Break pedal are stuck Dow and can be moved. Husqvana 2000. M-2000 YTH21K46
  • 4 Answers
As you are pushing down the pedal use your hand to release the pedal lock lever. Or a belt popped off the drive pulleys and is binding the idler pulleys. Or so much grass has accumulated on transaxle its binding brake/Clutch pedal.
Posted on May 24, 2014
My 1995 Toyota tercel brake lights stay on even when the car is off
There is a switch/sensor located at you break pedal, when you hit the breaks this has a small pin that make positive contact telling your break lights to come on. It may be broken or stuck, check it.
Also check all the bulbs on your car, breaks and blinkers etc...
Oct 03, 2016 | 1995 Toyota Tercel
Rear break pedal does not move
If the brake pedal is stuck, but moves ok when brake line is disconnected, then the problem is further up-line!
Check brake caliper to see if that's the problem.
Aug 11, 2013 | Harley Davidson Motorcycles
My C230 Mercedes compressor 2000 model the gear stuck on Park and do not move to N or D. What can i do?
It might be a failing break light switch which is very common to cause this complaint, you can try pressing very hard on the brake pedal when selecting drive - if it selects drive after doing that you need a new brake light switch, If not it could be your shifter module thats at fault - we sometimes see that fail aswell.
Dec 31, 2012 | 2000 Mercedes-Benz C-Class
Brake lights stay on when engine is off. Pulled fuse out and replaced. Lights still stay on
I would say your break switch is stuck. It is a round chrome cylinder above your break pedal. The break stem hits it when you push down the break. Try to loosen the button. It is stuck.
Feb 17, 2011 | 2000 Nissan Frontier
My landrover discovery is stuck in park
  1. try replacing the brake switch located underneath the steering colum right below you brake pedal a quater turn should release it
Aug 18, 2010 | 1997 Land Rover Discovery
How do I tell if I need a break master cylinder. The break peddle feels sluggish.
with the engine running with the emergency brake on place the car in gear and press the brake pedal dow. Keep in down for two minutes and pay attention if the pedal starts moving towards the floorboard more. If it does the master cylinder is getting weak and will need a replacement soon
Mar 18, 2010 | 2001 Volkswagen Beetle
Parking brake pedal stuck up
Possibly one of the pedal or bracket mounting bolts may have loosened up and is jammed against the pedal lever.
Jan 19, 2010 | 2000 Chevrolet Silverado
STUCK IN PARK
Try pushing on break pedal before putting it into gear...if this does not work the break saftey switch telling the transmission you have depressed the pedal is faulty or the fuse to it is blown. :)
Sep 07, 2009 | 2005 Chrysler 300
Brake lights on 2000 Civic EX w/ cruise control do not work when brake pedal is pressed. I had the same problem 2 years ago and the brake light switch was replaced. Where do I locate the brake light...
The break lite switch is located behind the break pedal and it probably doesn't replaced it is probably just stuck. Its fairly easy to get to .
Aug 14, 2009 | 2000 Honda Civic
Break lights are stuck on, why?
look under the dash and find the break pedal. follow the break pedal arm up under the dash. there should be a small switch that the break pedal arm presses in when you push the pedal. this switch can either be bad or it could be out of adjustment and something near by has moved and it is in a bind to where the switch is pressed in all the time.... has it been running your battery down...?
Jun 06, 2009 | 1999 Mercury Cougar
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
