Question about Phonak ComPilot
Com pilot does not stay paired with my phone - Phonak ComPilot
How do I pair an Apple MaBook Air with Phonak com pilot
You would need to put the compilot into pairing mode and then go to system preferences on your Mac. Open Bluetooth devices and you should see your compilot there if it's in pairing mode. Consult the manual on the compilot for the pairing mode instructions.
Jun 06, 2015 | Apple MacBook Air
Cardo q2 pairing
hard rest. remove battery and clear any settings from the mobile phone. is discovery ON?
Mar 12, 2014 | Cardo Scala Rider Q2 Pro
I have nortel phone system, voicemail is not working at all and feature 981, 983, 985 all say inactive feature--how do I reactive the voicemail??
Dear Annabelle,
Is the machine call pilot 100 or 150.if 100 the 2 leds in your left hand side should be on also in your right hand side the middle led should be on same for 150 the 4 leds in your left hand side should be on.1) Try to unplug the power cable and re-connect it again.2) Make sure that the the output telephone cable [100 (2 pair) or 150 (4 pair)] depends on the device comming from the call pilot to the Nortel PABX connected properly from both sides. dont hesitate to contact me if you are facing any doubt.Goodluck and Kind Regards;
Ahmed Safaa El-DeebTelecom & Network Engineer
Mar 28, 2012 | NorStar T7316E Corded Phone
How do you re-light pilot light
Turn the knob on the gas valve to the pilot position. Sometimes you have to slightly depress the knob to turn it..don't use a pair of pliers. In the pilot position.. push the knob in and light the pilot..keeping the knob pushed in for 30 seconds. Let go and the pilot should stay on. Turn the knob to the on position and set the thermostat.
Tom
Aug 02, 2010 | Imperial IFS40 Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
08 Acura MDX bluetooth pairing with iphone
i use to work for honda and acura and from what i recall, the iphone is and or wasnt compatible with the bluetooth sytems(factory) i was haveing trouble pairing a custs iphone in a pilot, then was told its not compatible with that phone
Apr 06, 2009 | 2008 Acura Mdx
Phone won't stay paired w/bluetooth
may be software problem..or make sure that your phone is visible for other devices..
Dec 13, 2008 | Motorola Mobility RAZR V3
Can't pair bluetooth headphones with Insignia Pilot MP3 player
the directions from Samsung to pair the headset was way off. You need to hold down the main button then turn on the headset. Only then will the headset go into pairing mode by maintaining a solid blue light. It took me a couple of days of troubleshooting and experimenting to realize this pairing method. I just hope that this problem is only due to my headset because I assume a lot of people who buy this headset and try out Samsung's directions will become very frustrated. I almost returned the product and I am sure many others would too.
Dec 02, 2008 | Insignia Pilot MP3 Player
Bluetooth Motorola Hs801 Pairing
after hs801 is switched on, hold one of the volume buttons till the LED(blue) stays ON, then you can pair device to any phone. Pass code is 0000.
Oct 24, 2008 | Motorola Mobility HS801 Consumer Headset
Pairing h700 to sanyo s1
After your phone has found the H700 you have to tell your phone to pair with it. It will then ask for the code. Punch in 0000 and confirm. After a little bit the H700 will flash blue several times rapidly and then start blinking about every 5 or 6 seconds. It is then paired with your phone.
Apr 21, 2008 | Motorola Mobility H700 Wireless Headset
Phonak ComPilot Logo
Top Phonak Cell Phones Experts
Vladimir Frolov
Brett Duxbury
Brett Duxbury
 Mikey
Mikey
Are you a Phonak Cell Phone Expert? Answer questions, earn points and help others
