Question about Epson TX300F Series
Usb device USB 2.0 driver for TX300F
    Habit-Forming:
    New Friend:
  • 11 Answers
Http://esupport.epson-europe.com/FileDetails.aspx?lng=en-IE&data=0ccCGROWIYPt+77V62rb+jdrtD0spd3xWU4+0JNwf1wU003D&id=321832
Posted on Jul 29, 2013
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Cantscantomycomuterepsontx300f
You think that's bad, your Shift key is broken too, for capital letters; and your spacebar is broken.
One: How did you install the Epson TX300f?
The FIRST thing to do is to get Windows running, and then put the Epson Installation Disk in your optical drive. (CD/DVD drive)
Install the drivers, and the software.
THEN plug the USB cable from the Epson into the computer, and turn the Epson on.
If you didn't install the software, or installed AFTER you plugged the Epson into the computer, this = NO
Why?
Because when a new device is hooked up to your computer, Windows 'breaks it's neck' to find suitable, matching drivers.
If THE drivers are not there, Windows will match up one of it's THOUSANDS of generic drivers.
This = No.
IF you hook up the Epson to the computer first, and turn it on; THEN come back and install the software, you will get a Driver Conflict.
Crudely explained;
Windows: "Which drivers do I use? These or THESE?"
Driver: Small piece of software that allows the Operating System to communicate with a device
The device is the Epson TX300f.
The Windows operating system wasn't stated.
Going on.............
If you installed the software first, then the Espon, you should have Epson listed in your All Programs menu.
I have an Epson also. Epson Stylus CX4800
I am using Windows XP (Home)
I click on Start, hover my mouse cursor on All Programs, and over to the right. If I want to scan I click on Epson Scan.
Need me to go further I can if you wish.
To summarize;
Did you install the software first, THEN plugged the USB cable of the Epson to the computer, and turned the Epson on?
Post back in a Comment
Regards,
joecoolvette
Feb 21, 2013 | Computers & Internet
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
ASUS P4SDX USB Ports not recognized as USB2 HS Ports
The message comes up when a USB 2 device is connected to a slower USB 1 or 1.1 port. It is only to advise you that the devise will operate faster on a USB 2 port. If your computer has only USB 1 or 1.1 ports, you will always see the message. You can buy and install a card with USB 2 ports and install it. It will come with the USB 2 drivers. Install the card and the drivers and then connect your USB 2 device to the new hardware and you should not see the message anymore.
Good luck, And let me know ho it works out for you.
~ Spoem
Mar 30, 2009 | ASUS P4SDX Motherboard
USB ports work at 1.1; s/b 2.0
Your computer is functioning correctly.
The USB ports on your laptop are USB1 ports its pard of the hardware.
Your PCMCIA USB 2 card runs at USB 2 speed and therefore when you connect a USB 2 device to this port you will not get this USB message.
Jan 18, 2009 | Lenovo ThinkPad R51e Notebook
REMOVEABLE STORAGE DEVICE BY FUJITSU
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Oct 27, 2007 | Electronics - Others
Usb
USB port incorrectly set, very rare to have port problem but every printers usb port is uniquely identified to computer unlike lpt ports. Disconnect usb, Delete driver, download complete driver package from epson site, run software then connect printer when instructed
Oct 25, 2007 | Epson Stylus Pro 7600 InkJet Printer
Computers & Internet Logo
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
