Question about Dell Vostro 1014 Notebook
Touchpad unlock mouse pad unlock
  • 369 Answers
Please hold down Fn+F6 key or hold down Fn+F3 key.
Posted on Jul 26, 2013
Mouse pad not working
Examine your "Function"/"F" keys and look for a touchpad icon. If you find one, hold the "Fn" key and press the touchpad icon button to unlock the touchpad. Move on to Step 2 if your laptop doesn't support this feature. Plug a USB mouse into an open port on your laptop. Click the Windows "Start" button. Click "Control Panel" in Windows XP and double-click "Device Manager." Type "Device" in the search box in Vista and Windows 7 and click "Device Manager" from the results. Click "+" next to "Mice and other pointing devices." Right-click the touchpad and select "Enable." Your touchpad is now unlocked. Hope this helps.
Jan 10, 2013 | ASUS Eee Pc R101d Atom N455 1.66ghz 1gb...
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
Click "Start." Click "Control Panel" in the right panel.
Click "Accessibility Options."
Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys."
Click "OK" to unlock the keyboard, including the keypad.
Unlock Touchpad
Click "Start," then "Control Panel."
Click "hardware and Sound," then "Mouse."
Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
hope this helps
Aug 17, 2012 | Synaptics PS/2 Port TouchPad
I HAVE A DELL M5030 AND THE TOUCHPAD IS NOT WORKING.... I HAVE TRIED USING THE FN AND TOUCHPAD BUTTON BUT i AM GETTING NO RESPONCE
I have the same computer if you look up between >>' and insert you will see the symbol that looks like the mouse pad with an X in the middle click this button by itself and it should unlock your mouse pad.
Mar 12, 2012 | Dell Inspiron M5030 Laptop
Hp probook 5520 mouse pad is locked. The keyboard and mouse buttons are working but the touchpad is locked. how do i unlock it?
there would be a small button right beside the touch pad LED. press the button and LED will turn to white or green and your touch pad is unlocked. pls rate the slolution however you find this....
....thanks...may
Jul 12, 2011 | Computers & Internet
Hi.. My lenovo Y510 laptop mouse pad is locked, so kindly suggest to unlock the mouse pad. Thanks n Regards Ratnadeep Nath 09322136821
First of all check if the hardware is detected. Look in the Device Manager under "Mice or Other Pointing Devices". If it's not detected means there's a problem with your TouchPad.
Normally you won't need drivers for the touchpad. It should be detected as PS/2 Compatible device.
Apr 14, 2011 | Lenovo IdeaPad Y510 Notebook
THe mouse on my lap top is locked .how can i unlock it
The TouchPad is enabled by default. To change the enable/
disable TouchPad setting by using the Fn + F9 keys, see
“Disabling or enabling the TouchPad” on page 234.
You may also change the enable/disable setting as follows:
1 Click Start, Control Panel.
The Control Panel window appears.
2 Click Printers and Other Hardware.
3 Click Mouse.
The Mouse Properties window appears.
4 Click the TouchPAD ON/OFF tab.
The TouchPAD ON/OFF tab view window appears.
5 Select Disable or Enable, whichever is appropriate.
6 Click Apply.
7 Click OK.
The Mouse Properties window closes.
8 Close the Printers and Other Hardware window.
9 Close the Control Panel window.
Or you can get the manual on the link below. Just type in the # code and click on download now. Page 61 tells you how to unlock the mouse pad.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck and please rate 4 thumbs up for the free answer
Sep 02, 2010 | Toshiba Satellite A15-S157 Notebook
How can i unlock my netbook mouse pad? hp mini 210-1000
The keys for unlocking the mouse or touchpad is pressing Fn and F9.
If it does not work, try to reboot and press Fn and F9 again. If it still fails, I suggest to re install the mouse pad driver.
Hope this helps!
Aug 02, 2010 | HP Computers & Internet
Mouse on my dell computer is lock up.
You could unlock it from, dell touchpad icon (you will find it beside the clock in the bottom right),after you open it you will find options for external mouse and such that, you will know your way for unlocking your touchpad.
Jan 30, 2010 | Dell Latitude D610 Notebook
Mouse pad stopped working after kids pressed
I'm assuming you are talking about the touchpad - they may have hit one of your hotkeys - fn+f7 will toggle the touchpad on and off - on my aspire 3050 anyway - try fn+f1 to get a list of the hotkeys and what they do to make sure
Apr 17, 2009 | Computers & Internet
Dell Vostro 1014 Notebook Logo
83 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
