Question about Craftsman 1/3 hp 3.5 amp 10" Band Saw 21400
Manual for 1.3 hp Craftsman band saw
I need to change the blade on my 1/3 hp Craftsman band saw but no longer have the manual. Where can I obtain another manual for it?
  • Judith Jul 26, 2013
    The second sentence in the reply is exactly what I needed to know, ie where to obtain a manual for this saw.
    Sergeant:
  • 468 Answers
The blade length of the saw is 70.5" . You can get custom length blades on www.sawblade.com . You may visit sears site to get manual for that saw.
Posted on Jul 26, 2013
  • 2692 Answers
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
  • 3600 Answers
SOURCE: I NEED UPPER BLADE STABILIZER FOR OLD CRAFTSMAN
You can go to the web page I am going to give you and you can enter the model number and you can find the part you have to order it from sears parts store. If if does not come up on the list then there is the 800 for sears to talk to the parts department and they can get you to the right place to order the part. Depending on how old it is it may take a couple of weeks to get it depending where it's coming from. Here is the Web site just click on it and it will take you there and thank you for using fix-ya.
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 23, 2010
  • 32 Answers
SOURCE: My band saw (craftsman 12" tilt head) stopped
Hello'
I have the exact same saw. It sounds like the key stock came out of the pulley attached to the lower wheel. I will give you a quick rundown.
-unplug saw
-you will have to lay the saw on its side so you can remove the motor and drive belt.
-there are 2 seperate pulleys , the one connected to the motor and the one connected to the bottom wheel.
-loosen motor nuts and remove motor, pay close attention when removing motor 3 of the 4 studs have sleeve like spacers.
-once motor and belt are out of the way check the pulley on the bottom wheel,my guess is that the key stock came out and the pulley spins freely.
-loosen set screw,replace keystock and tighten.
-NOTE the keystock may have came out of the motor pully instead,check.
Now this next part is real important.
-once you get it figured out and are ready to put everything back together the 2 pulleys must be perfectly lined up, use a flat ruler, using your eye will not work.line the drive pulley up with the lower pulley. ( the pulley on the motor has a shoulder on it so when it is pushed towards motor it will be set in the right spot) .
It is either the pulley on the motor or the wheel that has lost its keystock.
It should be a easy fix,Good luck
Posted on Nov 15, 2010
puertobori
  • 7733 Answers
SOURCE: I have a Craftsman 10" 1/3 hp band saw, after
Looks like are the motor brushes.
Try open the motor and look for.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 23, 2010
Get a 12 "Sears craftsman band saw blade model no 113.279521c
I'm using Haltbar band saw blades that I got from sawblade.com . They have great quality band saw blades. I ordered 10 blades from them last month and shipping was free.
Oct 18, 2014 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
Manual 1987
In my search, this is the closest band saw to 11.324200 that have almost the same structures and features. 113.24201 band saw . You can download the manual from there. If you need a blade, I recommend you to visit sawblade.com , they custom made blades, I ordered my blades from them .
Dec 22, 2013 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
I have Sears- Craftsman 10" band saw #113.244510. after installing new tire the blade tracks to the rear. Have followed manual but cannot solve proble- any suggestions?
Check this blog first. Are you installing a new blade? If the blade is running backwards, you just have to reverse it, turn inside out. Try watching the Alex Snodgrass' Youtube video Band Saw Tune Up .
Oct 17, 2013 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
How to change electric cord on Sears Band saw
You should check the manual of your band saw. Or just call the manufacturer directly.
Apr 17, 2013 | Olson Bandsaw Blade 57 56-7/8 Inch 1/4 X...
Setting the proper tension on a Craftsman 10" band saw model 124.214000.
Hope this blog will help you http://bandsawblog.com/blade-tension/ .
What's your band saw blade? I am using Haltbar blades and never got problems tensioning.
Feb 11, 2013 | Craftsman Saws
How dow i change the blade
I am not sure if you can apply these steps with your band saw but you may use this blog for reference : http://bandsawblog.com/replacing-the-band-saw-blade-on-your-band-saw/
Where did you get your new blade? I got mine on www.sawblade.com . Works pretty well. Anyways, goodluck then. I wish I can give you more help .
Jan 31, 2013 | Craftsman 12 Tilt Head Band Saw Owner...
I am Looking for a miter gauge (which is an accessory) for a old craftsman model 113.244512 band saw. Is there any around out there?
You may look up to ebay or search on google. I actually order band saw parts with www.bandsawparts.com but I think they don't have the miter gauge for your bandsaw model.
Dec 20, 2012 | Craftsman 1/3 hp 3.5 amp 10" Band Saw...
I am looking for a manual for a Craftsman 10" Band Saw Model No. 103.0101
I have a 10" table top bandsaw and i need to replace the drive belt. Can't find a manual for this and don't know the size of the belt.
Aug 14, 2010 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
Jan 16, 2009 | Craftsman Saws
Craftsman 1/3 hp 3.5 amp 10" Band Saw 21400 Logo
198 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
