Question about Frigidaire GLEQ2152ES Electric Dryer
KEY TEST
I have a copy of the function test sequence.It says to turn the cycle selector to 12 O'clock position. Where is this position??
  • Official Brand Answer
  • 4,342 Answers
Hello Wilfred, thank you for your question! Typically speaking the 12 o'clock position means to turn the knob in the upward position like if you were setting a clock to 12 am/pm. Hope this information helps to some degree. If you have further questions, please do not hesitate to reconnect.
Posted on Jul 30, 2013
I have a Kenmore washer #11026002010. I am having problems with the water overfilling and not progressing to the next cycle. Would you have info on the fault codes and also the recalibration procedure
Does it sound like it wants to spin? If so more than likely the motor coupler broke causing your washer to not spin. It is one of the most common parts that fail.
Anyhow Sears is the best bet for your answers they even list all the steps needed to trouble shoot.
Model 11026002010 Kenmore Automatic washer Repair
This one is from the link above and credit to:
Natasha12,November 17, 2014
Thank you for choosing Searspartsdirect.com and being a valued member. I can certainly assist you in locating the diagnostics for your washer.
ACTIVATING THE SERVICE
DIAGNOSTIC TEST MODES
1. Be sure the washer is in standby mode
(plugged in with all indicators off).
2. Perform the following sequence of
movement using the cycle selector knob.
NOTE: AFTER RESET, sequence "a" through
"e" must be completed within 6 seconds.
RESET - Rotate cycle selector knob
counterclockwise one or more clicks
to clear sequence.
a. Rotate cycle selector knob clockwise
one click and wait ½ second.
b. Rotate cycle selector knob clockwise
c. Rotate cycle selector knob clockwise
d. Rotate cycle selector knob
counterclockwise one click and
wait ½ second.
e. Rotate cycle selector knob
clockwise one click.
?Successful activation of Diagnostic Test
Modes will be indicated by all status
LEDs (except for Lid Locked) flashing
ON and OFF in half-second intervals.
NOTE: LED names may vary between
makes and models.
FAULT CODE DISPLAY MODE (Pgs 6-7)
To access fault/error codes, perform steps 1
and 2 of Activating the Service Diagnostic Test
Modes. Turn the cycle selector knob until the
status LEDs or display correspond as follows:
?"Done" LED On, "01" Displayed on 7-segment
01
Sensing Soak Wash Rinse Spin Done
Press the START button to enter Fault Code
Display Mode. The status LEDs will flash
ON and OFF and "cl" is displayed on the
7-segment (if display exists).
1. To view last 4 fault codes:
? Turn cycle selector knob clockwise to view
fault codes in the order of most recent to
oldest. (Refer to Fault/Error Code charts
on pages 6 & 7.)
NOTE: A fault/error code will be removed
from memory if it does not reoccur after
10 consecutive wash cycles.
2. To clear fault codes:
? Turn cycle selector knob until the status
LEDs flash ON and OFF or "cl" is displayed
on 7-segment. (See figure 2, page 2).
?Press and hold START button for 3
seconds to clear all fault codes. Press
POWER to exit Service Diagnostic Mode.
You can also visit searpartsdirect.com for parts, diagrams, and repair information.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website: Sears Home Services .
Thank you for your question. Have a great day.
Jan 10, 2015 | Kenmore Washing Machines
I have a whirlpool cabrio washer for a while now here and there i was pulling out soaking wet clothes.and ofcourse my warranty ran out yesterday and now it will not start any cycle all its does is sense...
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Here is a list for the errors.
Post back your results.
Sep 14, 2013 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
My cabrio washing machine want start
start with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
Post the results back to me.
Nov 30, 2012 | Washing Machines
My washer test runs great I hear every thing working correctly but when I do laundry it doesn't spin. How can I fix this issue. I am getting an error code f7 e1
I know how frustrating it can be when appliances do not function properly.
I hope this is helpful. Post back your results.
Click here for image
Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Washer will not start
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc...
If there are no error codes stored, you will need to replace the control board. Here is a link to the part.
Oct 17, 2012 | Whirlpool Washing Machines
If i am getting e68 error can just the button be replaced
Welcome to FixYa.
The E68 is indicating a push button is stuck,
To investigate further the console would need to be serviced/torn-down. I'd try the suggested test program first though. To answer your question "can just the button be replaced"...
No unfortunately, The buttons are a part of the entire control behind the console/panel. The test I'm going to post is quite long so I'll post it in two parts.
PART 1
FUNCTION TEST SEQUENCE
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and "rES" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counterclockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds.
The control will enter test mode, the buzzer will sound 3 times and all LED's will rapidly flash. After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggle back and forth in the display.
SEE Below for remaining test program instructions...
Mar 29, 2011 | Frigidaire Electric Dryer
My dryer will spin and then stop spining reading err68 or err4a what can this mean.
E4A = The drying time has exceeded program time for cycle. Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes. Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Check for any thing that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closetwith solid door, or bad connection in moisture sensor bar cir cuit or dirty bars. If dryer operates normally but code returns, replace electronic control.
68 = One of the keys (buttons) is stuck closed (active). Enter function testmode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists, replace electronic control
Dec 31, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Err68
Hi
Error E68 on Frigidaire dryer means that One of the keys (buttons) is stuck closed (active). Please check whether any button is pressed or stuck. Also try removing the lint filter and clean the contacts of the inside of the filter.
Try performing function test to check which button is at fault. Enter function test mode and perform key (button) test to determine which button is at fault. Carefully free the and perform the test again. If button is free but the key struck code still exists then you'll need to replace the electronic control.
Function Test--
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound 1 time and “rES” will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom. Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode, the buzzer will sound 3 times and all LED’s will rapidly flash.
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power from dryer. Dryer will be reset for regular operation.
Please post back for any further assistance.
Daniel
Jul 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Won't spin
Close the door firmly and make sure the machine is turned on. Press and hold the Chime and Extra Rinse keys until the control beeps to enter Service Mode. All indicator lights will turn off except the "Door Lock' indicator signifying the door is locked.
Press the Rinse & Spin key then rotate the cycle selector knob in either direction to display the most recent error codes if there's any. Press and hold the cycle selector to display the number of cycles since the error occurred. List down at least five most recent codes and post it here for us to determine what the problem could be. Press and hold the Delay and Chime keys for three seconds to clear the list. Press the Rinse & Spin key again to exit diagnostic codes list.
Press the Spin Only key while in the Service Mode to begin the Board Input Test. Set the rotary cycle selector to Super Wash then press it to display the position of the door switch. "OP" will be displayed if the door switch is open or "CL" if it is close. Replace the door lock/switch assembly (part #34001265) when "OP" is displayed even the door is close. Press the Spin Only key again to exit the Board Input Test.
Press the Spin Speed key while in the Service Mode to begin the Board Output Test. If water is present in the tub, set the rotary cycle selector to Quick Wash then press it to turn on the drain pump and drain the water. Press the rotary cycle selector again when the water is fully drained to turn off the drain pump.
Press the Delay button to turn on the motor and the Delay indicator light. The machine should tumble clockwise then counterclockwise with 5 second durations each and 2 second intervals. Press the Spin Speed key again to exit the Board Output Test.
Press Off or press and hold Chime and Extra Rinse keys for three seconds to exit Service Mode. Unplugging the washer will also exit Service Mode.
Perform the tests above and let us know the results for us to determine the cause of the problem or the necessary action to undertake and give you the specific and detailed instructions on how to fix it.
Mar 03, 2010 | Maytag Neptune MAH9700 Front Load Washer
Dishwasher will not run. I have checked the circuit breaker and it seems fine. does the dishwasher have a reset button?
Hello there:
My dishwasher will not work at all. Investigate these four areas if your dishwasher is not working at all:
Power Supply
Your dishwasher may not be receiving any power. It is somewhat difficult to check for power at the plug outlet because the plug for a dishwasher is usually behind the unit. You should make sure all the circuit breakers of your circuit breaker panel are in the correct positions, or check to make sure no fuses of your house fuse panel are blown.
Door Switch
A properly functioning door switch will shut your dishwasher off when the door is opened. A defective door switch may not allow your dishwasher to operate at all. Examine the door switch and test it. If it is inoperable, it will have to be replaced.
Cycle Selector Switch
It isn't very common, but it is still possible that your dishwasher's cycle selector switch has become defective. Test the switch to determine if it is the cause of your problem. Replace it with a new one if it is.
Timer Motor
Your dishwasher timer will not function if its motor is defective. And if your timer is not functioning properly, then the dishwasher itself will not function properly. Test your dishwasher's timer motor, and if it is broken, you can replace either the entire timer assembly or just the timer motor.
Dec 25, 2009 | KitchenAid Dishwashers
Frigidaire GLEQ2152ES Electric Dryer Logo
56 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
