Question about Toro Garden
Wheel stuck on shaft
We have a punctured tyre on our Toro Workhorse mower. I'm trying to remove the wheel to take it to get the puncture fixed. I have removed the retaining bolt that locks the wheel to the drive shaft, but the wheel seems to be stuck on the shaft. Anyone know the safest way to free the wheel from the shaft? Thanks in advance, Keith
  • 182 Answers
Make sure there aren't any c clips holding it on I would use a block of wood and a hammer I have put green slime in my tires that stuff works great it should fix your tire
Posted on Nov 01, 2013
  • Keith Macdonald Apr 16, 2014
    Thanks for all the suggestions, but it wasn't the gearbox, or a bent shaft. In fact it was the end of the axle that protudes through the wheel. The end had got burred enough to be bigger than the hole in the wheel. After removing it with a wooden hammer, some careful filing removed the burrs, and it now slides on and off easily.
  • 202 Answers
SOURCE: Toro 6.5 self propelled Mower - Self Propell won't engage
see if the lever going to the gearbox is cracked or broken. there is a gear inside the box that has a pin going thru the shaft that may have broken but usually it is external. these mowers have a plastic lever to put the transmission lever in gear if the cable is overtightened they wont hold up.if it cracks it leaves practially no tension on the engagment system
Posted on Jul 17, 2009
  • 65 Answers
SOURCE: Toro Recycler 6.5HP recoil start cord pulls hard & snaps back in
This sounds like you have bent the shaft. This happens when you run over something hard. Hope this will help.
Posted on Jul 25, 2009
  • 67 Answers
SOURCE: wheel rear wheel removal on a toro riding mower
take the bolt out of the center or the e clip off and the wheel should slide off but dont loose the key
Posted on Sep 01, 2009
  • 6468 Answers
SOURCE: how do you remove fly wheel on 6.5 toro push mower recycle
with the nut off the top you should use a puller but it i pry under the flywheel against solid metal rotate the flywheel and slowly go around it should pop off
Posted on Apr 06, 2012
SOURCE: TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Posted on Nov 11, 2012
I have a puncture on my front wheel tyre on a rascal 302 le how do i get it off
Remove the axle and drop off the tire. Tools needed are a 5mm and 6 mm Allen wrench
Feb 10, 2014 | Electric Mobility Shoprider Electric Power...
Tip
Removing a 'stuck-on' road wheel
It's dark, it's raining and you have a puncture and you can't get that punctured wheel and tyre off the hub! When you try pulling on the wheel/tyre, the vehicle almost falls off the jack and that could be dangerous. Best thing to do is find a hard piece of wood, about one and half meters in length, turn the steering wheel fully until the front of the wheel and tyre are exposed and then strike the inside rim of the wheel firmly with the wood - you'll find the wheel becomes free. Straighten the wheels and place replacement wheel and tyre on the hub. Scottech.
on Mar 16, 2010 | Honda Accord Cars & Trucks
Puncture in one of my front tyre how do l remove it
To remove wheel there is one center bolt in the middle of the wheel(13mm). The wheel is a split rim so on the inside of the wheel there is more 13mm nuts undo them and the wheel comes apart.(no need for tire levers)
Remove wheel husqvarna mower
Why do you not just pull the tyre off the rim on the outer side & check fot what caused the puncture/leak... Check the tyre valve first....
Dec 09, 2013 | Garden
Rear wheel stuck on shaft
should be ale to take the lug nuts off and simply take the tire off if it is stuck on after taking the lug nuts off take a 2x4 and hit the back side of the rim a untill it comes off they do tend to stick on the hub.
Jul 26, 2013 | Toro Garden
I have a bebecar ip op and i want to know how to detach the rear wheel as it has a puncture?
The rear wheel is held in place by a locking clip which is controlled by a lever. To remove the wheel, simply press the lever rearwards, and pull the wheel away from the housing. Remove the tyre carefully, using appropriate tyre levers, in order to repair the puncture in the inner-tube, or to replace it.
Mar 27, 2011 | Bebecar M City Stroller
Back wheels keep deflating
hi, the chances are you have a puncture os something sharp sticking into the inner tube inside the tyre, what you need to do is buy a puncture repair kit then using the repair kit you take the tyre off the wheel then take the inner tube out.
now blow the inner tube up and place it in bowl of water and you should see bubbles coming off the inner tube, mark this with pen when dry so you know where the whole is, now use the puncture kit and place a patch over the whole, you can buy glue type patches or stick on patches without glue, you peel the back off the patch and put glue on or stick it over the whole if its a stick on patch and not glue.
then whilst this dry run your fingers around the inside of the tyre and check for any thorns or something sharp sticking in the tyre if you feel anything remove it and you should be ok, then when glue dry put the inner tube back in tyre and fit the tyre back on wheel now when you pump it up it shouldnt go back down unless you get another puncture.
if you are unsure what you are doing then taking your stroller into any bike shop and ask them to repair the punctures for you and they will do this for you whilst you wait.
Jul 10, 2010 | Quinny Buzz Three Wheel Stroller
My quinny rear tyre is flat tried to inflate the tyre but still does not work what should i look out for
you have a few choices
but if you want a long term fix you are better off getting a new inner tube as once a puncture occurs with the quinny wheels they will carry on doing it but theey are cheap enough to replace via ebay for about £6
if you dont want to replace you will need to remove the rubber wheel from the hub as you would a bike tyre then remove the inner tube
pump the tyre up put in water so you can find the hole then fix with a puncture repair kit
if you want to carry on using you can fill the tyres with tyre weld as you would a car they dont puncture and makes the quinny a smother ride
and if all else fails you can buy a used or new pair of wheels from ebay between £15 and £30
hope this helps x
Dec 14, 2009 | Quinny Buzz Three Wheel Stroller
My john deere lt155 has a punctured tyre, how do i remove the wheel, there are no wheel nuts??
in the center of the rim remove plastic cap remove c clip retainer then pull rim and tire off the machine
Jun 29, 2009 | Garden
Tyre puncture
if it is an alloy wheel ,it may be stuck around the hub where the wheel is placed.sometime there is rust around the hub thus preventing the wheel from coming out.So you have to slightly kick the wheel tyre from behind hardly and it will come out and if necessary a bit hard.Thanks
Jun 22, 2008 | 2005 Ford Focus
Garden Logo
83 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
