Question about iSymphony LED26iF55D 26 TV
NEED a Manual Can get off the TV SCAN FOR CHANNEL trying to setup universal remote
    Top Expert:
  • iSymphony Master
  • 74,136 Answers
Try this link to download it. It can't be send to you this window, as it is in PDF format. http://www.isymphonyproducts.com/IM%20LC42iF56.pdf
Posted on Jul 26, 2013
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
How do I switch from catv to antenna on model mwc13d6
First make sure that the TV/DVD player is on TV by pressing the Channel Up. (The channel up/down will rotate through AUX and any programmed channels.) You'll need the original remote or an universal remote that matches the Set-up function. Then press Set-up on the remote; it's to the left of Mute above Play.
Use the Up/Down arrows to navigate to Channel Setup. Press Enter to access the Channel Setup menu. Use the Up and Down arrows to select Auto Ch Programming and press Enter. Wait for the TV to scan all available channels. Afterwards, you can go back to the Channel Setup menu and choose Add/Delete channels. Press Set-Up again to exit the On-screen menu system.
Unless you have a set-top Digital-to-Analog converter attached to the TV, you will only get one of the few remaining low power analog stations, if you are close to the transmitter. This set only has an NTSC tuner. Most set-top boxes can be attached to the Antenna input and be set to Channel 3 or 4 or connected to the Aux input.
The Magnavox MWC13D6 was manufactured by Funai and the manual is available here: http://www.funai-corp.com/support/manuals.aspx . The direct link to the manual is MWC13D6 is http://www.funai-corp.com/support/om/MWC13D6.pdf .
I hope this helps.
Mar 24, 2015 | Televison & Video
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
I do not know how to do a channel scan, can you help me please? I seriously thought that I could find anything online but I have not been able to find how to channel scan this tv.
What brand/model TV do you have? If the TV has several input options, make sure that the TV is set to the TV mode. (Use the Input or Source button on the remote, some TVs have this on the TV as well but not always)
Some can only do a channel scan with the original remote. My old Emerson CRT (~20 years old) launched a channel scan when I pressed the Add and Delete Channel buttons together on the remote. Fortunately even when most of the buttons failed on that remote, the channel scan still launched.
Other TVs from that time frame have an channel scan button in the control panel. Often these are hidden behind a panel to avoid accidental resets.
More modern TVs usually have the scan as part of the menu. Depending on the TV, press Menu on the remote (or if available on the TV (sometimes can be done by pressing Ch+/Ch- together)). Then look for a Setup option or a TV icon. If you have a Setup menu, you will then need to go to the TV submenu. Then find the option for setting the input signal (TV/cable) and then you should be able to launch a channel scan. (Usually the Ch+/Ch- (up/down) and Vol+/Vol- (left/right) buttons will navigate through the menus.)
Unfortunately, without the make and model, I can't give you any more help. Please write back with your brand of TV and I'll check if I have the manual in my stack.
(low end universal remotes do not always include the menu or source button. If your TV doesn't have them, you may need a different remote. The ones that can be programmed via a USB connection are the easiest to set up.)
Apr 29, 2011 | Televison & Video
1. the newstar universal tv remote contrlol i bought, cannot change the channel, although i can use the adding/minus the volume. 2. in as much as wanted to use also for te change of channel, i follow...
Unfortunately, universal remotes often do not work as well as the packaging says.... but all hope is not lost.
First, try ALL the programming codes listed for your brand of TV. Often, one will work. Be sure to follow the programming instructions, which usually have you trying the POWER ON/OFF button first after reprogramming.
If that fails, most universal remotes have a "scan" feature that, when you start it, will cycle through every code it has stored. During a "scan" you keep the remote pointed at the set and when the set powers off, you hit the ENTER key (or the key specified in the remote manual) to stop the scan and test the functioning of your remote (channel +/-, VOL +/-, etc.)- it takes a long time and can get frustrating, but keep trying and you should find a set of codes that will operate your TV correctly.
If you have no luck, do not give up hope completely- I would next recommend that you purchase a Philips brand universal remote- this is the brand that I have found to be most flexible.
Mar 02, 2011 | Televison & Video
I have a SV2000 TV and DVD combo no remote and need to get on channel 3 for the cable to work. ITs on channel 2 then goes to channel 7 and up .Ineed to get it set on Channel 3 and no setting button on tv...
Try going to a store like Walmart and buying just a universal remote and try different remote codes listen in the instruction manual until you can access the menu and do a channel scan. That's really the only solution I can think of.
Feb 09, 2011 | Funai EWF2004 20" TV
My universal remote went out and somehow the tv-a Sansui-got switched from channel 3. How can I get it back to channel 3 so the converter will work? I tried changing channels manually at the tv but it...
Look in the owner's manual for instructions on having the TV scan channels. Make sure the converter is on before starting the scan. If that doesn't work, you'll have to buy or borrow a universal remote to take care of it (enter 3, 03 or 003 on the remote control). This will happen every time you remove power to the set, whether it is unplugged or you have a power failure, so start saving up for a new remote control.
Dec 07, 2010 | Sansui 27" TV
I lost my remote and only need it to set the TV to channel 3 for cable. Is there any way to do this manually?
If you are able to access menu and channel setup, you can go into autoprogram and it will scan all available channels and store them.
Otherwise you can get a cheap universal or even original replacement remote
Oct 22, 2009 | Toshiba MD14FN1 14 in. TV/DVD Combo
What is the Remote Control Code for FLX1510
taken from their support f&q section word per word
"try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes. If there is another code listed for Element Electronics in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV’s model number for more information."
Oct 01, 2009 | Element Electronics FLX1510 15.4 in. LCD...
Finding manual Nexxtech 1519006
to scan
turn on target unit to program
hold setup til led lights on \
then select device (tv,dvd,other)
then use up channel (or down to go back if you miss)
when unit turns off, push enter.
Jan 21, 2008 | Televison & Video
iSymphony LED26iF55D 26 TV Logo
43 people viewed this question
Top iSymphony Televison & Video Experts
Electro Med Services...
ray gallant
Are you an iSymphony Televison and Video Expert? Answer questions, earn points and help others
